Bang and olufsen beocord 8000 VHS tape will not eject
Any ideas how to manually eject the VHS tape with the top cover removed
  • 883 Answers
SOURCE: vhs tape gets chewed
Dear William,
the rubber belts and rubber capstan need cleaning/conditioning. you can attempt this with alcohol swabs and if you find rubber conditioner (in the past was easy to find in audio supply stores) apply some of this also. if this treatment does not solve, then may need new rubber belt kit. good luck.
Posted on Dec 27, 2007
  • 77 Answers
SOURCE: VHS Won't play
i had the same problem and it turned out my motor was getting realy weak from exessive use and it would cost me more to fix it then it would be for me to buy a new one
Posted on Feb 26, 2008
SOURCE: Cannot eject VHS tape from Sony SLV-X811
I had a similar problem with a Panasonic VCR. It would not eject the tape and gave an error code. I found that the door does not quite fully open, so that the top of the tape hits the door and cannot eject. If I turn off and then turn on the VCR the error code disappears. Then I press the eject button and simultaneously hold the door fully open with one finger until the tape starts to eject and clears the door.
Posted on Mar 02, 2008
  • 139 Answers
SOURCE: VCR tape won't eject
The flap on the door stays open until the tape is ejected. There are two possible ways to remove the tape. First, with the power off, try to locate the drive pulley or gear on the side of the tape housing. It may be possible to turn it with your finger and cause the tape to eject. The eject mechanism will move VERY slowly when you use this technique.
The second way to do it should normally be done by an experienced technician, because it involves taking it even farther apart...and it may be difficult to reassemble. There are typically four screws that hold the tape mechanism in place...two near the top front and two near the back. It should be possible to remove those screws and pull the entire mechanism out of the VCR. Then you can more easily rotate the eject pulley (or gear) and remove the tape. If this sounds a little scary, I would definitely recommend placing the top back on and acting like nothing happened!
Posted on Mar 17, 2008
  • 3 Answers
SOURCE: VCR
Seems to be a common problem with VCRs. I've seen this so many times. The greased joints and moving parts inside get dry and dusty which sends the sensors into a never ending loop. you could try hoovering out the inside of the unit and applying some new grease to the moving parts.
To be honest its probably easier to just buy a new one but that depends on how technical you feel about having a go at fixing it yourself
Posted on Dec 17, 2008
Beocord 7000
belt kits are available on the internet and the mech is fairly easy to get out to work on
Jan 18, 2014 | Bang and Olufsen Audio Players & Recorders
Small motorla color tv vhs tape is stuck in tv
Remove power to the set - unplug the wall outlet. Remove the screws that attach the back cover. Remove the cover. Remove the cables that connect to the VHS drive to the TV main board. Remove the mounting screws that attaches the VHS drive to the set. Remove the VHS drive. Manually turn the take-up gear which is near a motor to allow the tape to mechanically eject the tape - do not force.
Feb 19, 2011 | Televison & Video
I have a beomaster 5000 which will cut out at any time sometimes it goes for ages,other times it will go almost immidiately,also i have the beogram 5000 and the cueing function doesn't seem to raise the...
O.k. The Beomaster 5000 needs new Quiescent current presets , you can temporarily solve the problem by turning the two presets (in the main amplifiers) fully anti - clockwise .
Your beocord needs new belts for sure .. availiable from CPC of Preston .. Hope this helps ..
Oct 29, 2010 | Bang and Olufsen Beosound 2000 Shelf...
The sliding cover for the tape player sometimes gets stuck when opening.
if we are talking beocenter 9000/8000/9300/8500/9500 replace belt,clean and lube door guide rails
Oct 19, 2009 | Bang and Olufsen Beocenter 9300 Shelf...
Glass panel unstuck
if product is beocenter 9000/8000/8500/9300/9500 remove screw under l/h side of panel, push panel to side and remove.careful to note position of plastic attachments and metal screw socket.lay face down on bench and apply thin ribbon of epoxy resin where double sided tape is,do not clean off old tape.apply glue over top.assemble plastic parts on top and leave to set.refit to machine and refit screw.
Oct 14, 2009 | Bang and Olufsen Beocenter 9300 Shelf...
Hi is the cassette player in the 5000 stacking system belt driven regards cliff
beocord 5000?. if so yes.there is a capstan belt clutch belt and a counter/autostop belt.there is also a deck in/out belt.
Sep 18, 2009 | Bang and Olufsen Audio Players & Recorders
Panasonic VHS Won't eject Tape
unplug then remove the top cover press down on the cassette release and remove the tape then rewind the part of the tape still sticking out by hand push in the button on the side of the cassette to open the cassette cover
May 21, 2009 | Panasonic PV-7400 VHS VCR
BANG AND OLUFSON BEOCORD V8000VIDEO RECORDER TAPE WILL NOT EJECT
turn the motor pulley at the far right corner this is the load/unload motor.unfortuneately the gears in this assy are often the cause for a jammed tape.take to any vcr specialist as the deck is a phillips (turbo) model and well known to engineers.
Apr 15, 2009 | Yamaha DSP-A1000 5-Channel Amplifier
VHS tape will not eject.
Hi and welcome to FixYa,
Initially, the top cover must be removed. Theis would allow you to:
  • manually eject the tape by turning the worn gear/mechanism. The only problem would be slack on the tape causing creases;
  • check/replace belt(s).
Check and perform preliminary visual or necessary inspection. Pls post back result(s). Good luck and Thank you for using FixYa.
Jan 11, 2009 | Sanyo DVW-7200 DVD/VCR
VCR keeps ejecting the tape
It needs Belts/Idler/Pinch roller.. If you UNPLUG IT, remove the cover you can wind the tape back manually....When you can get a DVD player.
Sep 28, 2008 | Sony SLV-N750 VHS/S-VHS playback VCR
Televison & Video Logo
167 people viewed this question
Top Televison & Video Experts
Electro Med Services...
