Question about Xerox WorkCentre M940 InkJet Printer
Xerox WorkCentre M940 - Not printing from the computer.
My M940 will not print documents from my computer. I went online and installed the neccessary drivers that would be compatible with XP and still no results. I'm not sure what the problem is because all the diagnostics tests that were ran on my PC failed. Can anyone help?
  • 62 Answers
Does the printer power on? How do you have it connected to the computer? I.e., does it use a usb cable, parallel cable, or is it connected through the network?
Posted on Sep 15, 2007
SOURCE:
I have Xerox M 20i .When ever I feed papers from ADf. Print is not coming normal.Some time it shrink the text,I checked the roller are fine.
The Xerox is a business machine and has a setting to reduce the size of scans by percentage.
Read the instruction manual to turn it off or play with the buttons.
WorkCentre M20/M20i Documentation - Xerox Support and Drivers
www.support.xerox.com/support/workcentre-m20-m20i/documentation/enus.html
  1. Cached
  2. Similar
Product documentation for WorkCentre M20/M20i. ... WorkCentre M20/M20i Firmware Installation Instructions. Setup and Installation Guides. Description.
[PDF]WorkCentre M20i System Administration Guide - Xerox Support and ...
www.support.xerox.com/support/workcentre-m20i/file-redirect/enus.html?...en... Xerox WorkCentre M20i System Administration Guide. Page i. Table of Contents. 1 Welcome ................................................................................. 1-1. Introduction .
Xerox 20i Google Search
Nov 19, 2016 | Xerox Office Equipment & Supplies
Workcentre 5655. How do I complete the install phase?
[PDF]Xerox® WorkCentre® 5632 / 5638 / 5645 / 5655 ...
www.office.xerox.com/latest/W56BR-01.PDF
Xerox5632 / 5638 / 5645 / 5655. Multifunction System. Inspired redesign. WorkCentre®. 5632 / 5638 / 5645 / 5655. Tabloid-size. Black-and-white. Multifunction System ...
Oct 07, 2015 | Xerox Office Equipment & Supplies
Error C0...Xerox WorkCentre 5020DN Printer
C-0 declares that the size of the document you are trying to print is incorrect with the paper size you have in your machine's tray. To remove the error, press the red button on the control panel and check the size of the document within the printing properties. If the papre size of the document and the paper in the tray are correct then try to use another tray or bypass tray. If the problem still persists, call for service.
Dec 06, 2013 | Xerox WorkCentre C2424DN All-In-One Laser...
Xerox workcentre 5775 I sent a 1-page document to
All you need to do is uninstall your printer to remove everything and then try re-installing again because otherwise it may be difficult for you to cancel all jobs at once.
Oct 02, 2013 | Canon imageCLASS® MF4150 All-In-One Laser...
XEROX WORKCENTRE 7328 IS RUNNING SLOW WHILE PRINTING PDFs
Are you printing to the printer using the Xerox Global Print Driver PCL6? If so, this will be the cause of your problem. Earlier versions of the driver werent as bad when processing PDF documents. I would suggest that you download the Workcentre 7328 PCL6 driver and try that - the problem should clear.
Cheers
Jon.
Dec 17, 2010 | Xerox WorkCentre 7328 Multifunction laser...
Can i buy a manual for xerox m940 workcentre and where do i get it
You can download and print the instruction manual in PDF format from Xerox website by clicking this link.
You'll require Adobe PDF Reader installed on your computer to view the manual. If it is not already installed on your computer, download it free from: http://get.adobe.com/reader/
Thanks for using FixYa.
Aug 26, 2010 | Xerox WorkCentre M940 InkJet Printer
Xerox Workcentre M940 lost CD
Call, 1-800-828-5881 then follow prompts 4 then 3. They should be able to look that up and order you the proper disks. If not they will direct you to who can.
Jan 03, 2008 | Xerox WorkCentre M940 InkJet Printer
Xerox M940 Multifunction printer
Check if u have put on cartrigdes correctlly and check for driver
Oct 16, 2007 | Xerox WorkCentre M940 InkJet Printer
Xerox WorkCentre M940 InkJet Printer Logo
69 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Clive
Clive
Philip Hughes
docukaaf
Level 1 Expert
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
