Question about Car Audio & Video
Using 12 gague wire on a 250 watt amp blowing fuse
What should i do blowing fuse on my amp should i go bigger with the ground and power wires
    Scholar:
  • 59 Answers
The wires are not the case(I suppose). But you might want to move to 8 gauge(though 10 could be enough,but in Hi-Fi enough is never enough) , but 6 would be the real thing if it's 4x250W(sinus?) placed in the rear of a car(while the battery is in the front)than this is actually just a FAIR minimum. An upgrade to the battery's ground wire is to consider, too, must be thicker than the actual, so a 4-gauge I reckon?
But back to your question :) What fuse did it blow actually? Is it in the car's fuse box/ Is it inline on the wire between the battery and the amp?/ or is it the amp's own fuse(on the amp) ????
Posted on Apr 15, 2009
  • dushko
    dushko Apr 16, 2009
    Yes, right, but do we want the wires to be more expensive than the amp itself? There's no sense of putting zero gauge in front of this amp.
    Rather buy some serious 4 or 6-er(rather 4) and get a capacitor with it(if you already don't have one)
    As for the fuse, answer the question in my first post(which fuse do you mean)
    Scholar:
  • 152 Answers
Oh my yes. I would recommend number 4 as a minimum. Use the same size for the ground. Bond it to the body in the best way you can. Use a CAD welder if you know anyone in the pipeline industry.
But ideally, run the biggest guage you can afford. and FUSE IT!! Zero Guage or better, and buy a fuse block and put it at the battery. Otherwise your crash could be a crash and burn.
After tapping into the ignition wire to connect the remote wire for a amplifier the 15 amp fuse keeps blowing when I try to start the car. What should I do?
a car amplifier should use an outdoor 2or so gague (very thick_) wire, ran, not to the fusebox, but to the battery, with a 20-30 amp under the hood, within a foot of the battery. the amperage your fuse will rewquire is based on the formula amps= wattsdivided by volts. a 240 watt amp on a 12 volt line would need a 20 amp fuse, just for the amp alone.
Dec 21, 2014 | Car Audio & Video
My amp keeps blowing its fuses whenits plugged in
Go over all your wiring. Make sure your power wire isn't grounded somewhere. If your power wire is touching any bare metal it will spark and blow the fuse the second you touch the power to your amp. Make sure your in-line fuse is about a foot from your battery, and make sure you have your ground wire grounded securely to the main chassis of the car/truck and that it is either same size gauge as your power or even a little bit bigger gauge. Also make sure no strands of wire from your ground or power wire are loose and reaching over touching the other where you plug them into the amp. If the ground and power touch eachother they will blow the fuse and possibly cause permanent damage to the amp.
Jan 06, 2011 | Pioneer Car Amplifier GM-5100T - 2CH 760...
I have a lanzar opti drive plus 500 old school,i have 2 12'' 1200 watt pyles,running in parallel at 2 ohm. when i bridge it at 2 ohm 1000 watts it blew my 40 amp in line fuse.
The 40 amp fuse is too small. 1000 watts = 12 volts @ 83 AMPS. Bigger power wire my friend. If you want to sell, let me know.
May 15, 2010 | Car Audio & Video
Amp blows fuses
Are you using the correct fuse? if so,
more then likely, you don't have a good ground. Try grounding to something else that has more direct connection to your frame. If that doesnt work, try getting larger power cables.
I had the same problem with my 2500w xplodes all I had to do was get a thicker cable for the ground and battery connection. What was happening, was it was needing more power then the wire and fuse could handle, so it would blow the fuse, since the higher you have it, the more power it needs to feed the watts.
I would try grounding it directly to the frame on a good part of the frame before spending another $70 on new power cables though.
Mar 09, 2010 | Car Audio & Video
Just installed new steam shower, it produces steam for about 5 minutes and then blows the fuse
Based from your comments, a new steam shower that blows the fuse in five minutes. You could have installed a new steam shower that is much bigger than what you previously have.
1. For a 5000 watts steam shower at 220 volts
power must have a fuse rating of 40 amps, supply
wires of at least No. 6 AWG Type THW ; and at
110 volts a fuse rating of 80Amps, supply wires
of at least No. 2 AWG type THW.
2. For a 4000 watts at 220 volts, Fuse: 30 amps,
Supply wire: No. 10 AWG type THW. At 110volts
60 amps, Supply wires : No. 4 AWG Type THW
3. For a 3000 watts at 220 volts, Fuse: 20 amps
Supply wire: No. 10 AWG type THW; At 110volts
Fuse: 40 amps, Supply wire: No. 6 AWG THW
4. For a 2000 watts at 220 volts, Fuse: 15 amps
Supply wire: No. 10 AWG THW and at 110 volts
Fuse: 30 amps, Supply wire: No, 8 AWG THW
Nov 27, 2009 | Hammering
Why doesnt my 2400 watt amp turn on?
The size of the wire affects the performance of an amp, but the amp should still turn on. 12 volts is 12 volts. So you tested with another amp, on the same wires, and it works fine.The only thing you can really check on the new amp is the fuses in the side. If those are blown, then you should be able to (Unless the amp is fried, and that's why it blew the fuses in the first place) fire it right up. If the fuses arent blown, and you have all your power, and ground, and still nothing.. Well then in that case the amp is just bad, and regardless of the wattage, you just don't fix a Pyle amp.
Aug 08, 2009 | Kenwood KAC-8152D Car Audio Amplifier
Amp blowing fuses
Your amp is blowing fuses to protect your circuit. The type of 12V battery does not matter. For whatever reason you are over driving the amp. 2 Ohms sounds like a very low impedance for a car amplifier output. I am assuming you have the two 12" speakers wired in parallel. Most are rated at 4 Ohms which means you are pulling twice the current with the 2 Ohm load. Also, the bigger the speaker, the bigger the magnet, the bigger the coil, the larger the inductance, the heavier the load. Make sure these speakers are matched with your amp. A small amp driving large speakers will shut down at high volumes. Try putting them in different channels. Good Luck.
Jun 17, 2009 | Kenwood KAC-9152D Car Audio Amplifier
I have a 25 wat fuse in my power wire connected to my amp and i keep blowing it. should i put a bigger fuse in it?
Hello grabert205,
You do not say if the fuse blows immediately upon powering up or while the amplifier is operating. If it blows immediately, I'd check the power and ground.
If it is blowing the fuse while operating, I'd try a 30A and see if it holds. At maximum output of 100 watts times 4, the amplifier needs about 31 amps of current at 12.8V. So driving it hard could certainly blow a 25A fuse.
Hope this helps.
Jun 13, 2009 | DHD LCD-9444 Car Audio Amplifier
1984 ford ranger keeps blowing the running light fuses. when i let it sit at idle it won't blow the fuses but as soon as i start driving with in 5 mins or so it blows.... any ideas?
short in the wires will need a wiring diagram and ohm/volt meter to locate the problem, test lights work well to.
you will need replace the fuse with a light bulb so that the power will not go away. and you will have to search for power going straight to a ground source.
usually a raw wire from rubbing somewhere. can do a quick visual inspection first for the obvious, and then use the meter at certain points till you find a volt drop.
May 13, 2009 | 1984 Ford Ranger
Car amp blows 12 volt wire fuse
the wire from your battery is blowing fuses? and you are using 20-30 A fuses? mine has a 100A fuse..look into getting new wire plus my wire is 4 gauge.., 1600 watts is too powerful for a 12 g wire and a 30 A fuse
Jul 26, 2008 | Car Audio & Video
Car Audio & Video Logo
160 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
