Question about Yamaha DSP-A1000 5-Channel Amplifier
BANG AND OLUFSON BEOCORD V8000VIDEO RECORDER TAPE WILL NOT EJECT
I have a tape stuck in B&O beocord v8000 any ideas how to manually eject the tape when the cover is removed.
  • 122 Answers
Turn the motor pulley at the far right corner this is the load/unload motor.unfortuneately the gears in this assy are often the cause for a jammed tape.take to any vcr specialist as the deck is a phillips (turbo) model and well known to engineers.
Posted on Jan 11, 2010
I have a beomaster 5000 which will cut out at any time sometimes it goes for ages,other times it will go almost immidiately,also i have the beogram 5000 and the cueing function doesn't seem to raise the...
O.k. The Beomaster 5000 needs new Quiescent current presets , you can temporarily solve the problem by turning the two presets (in the main amplifiers) fully anti - clockwise .
Your beocord needs new belts for sure .. availiable from CPC of Preston .. Hope this helps ..
Oct 29, 2010 | Bang and Olufsen Beosound 2000 Shelf...
Tape Stuck
I've checked the entire user manual which notes problems like this need to be referred to authorized service personnel. Myself, I would unplug the entire unit, put it on a kitchen table using a phillips (cross-tip) screwdriver to remove the top metal shell. Remove at least 2 screws each side and 2-5 rear screws securing the top. Nothing like peering inside to see what is causing the VCR to get stuck and help remove it. No release pinhole or tape freeing ejector will work if the unit's tape is tightly wound around some internal object or the tape is stuck because something foreign is inside the unit. Best of success. ZT3000 "Beta tester of "0"s and "1's"
Aug 17, 2007 | Panasonic DMR-EZ47V DVD Recorder/VCR
VCR tape is stuck - will not rewind or eject.
There schould be a release buuton on the rear of the machine. It's usually recessed and may be difficult to see. Press this with the yip if a ballpoint pen and extract the tape. If the tape is wrapped around the record/playback heads your only option is to remove the top cover and manually remove the tape. Sounds difficult but if you take your time it's not too bad a job.
Mar 08, 2010 | Sony Televison & Video
How do I reset the pin on my Bang & olufson tv as no one can remember it.
if you have not changed your pin from the one supplied when new ring the supplying dealer, they will have it on record.If you have changed it and cant now remember contact your local B&O dealer who will request a mastercode for the set but this will require proof of purchase.
Oct 25, 2009 | Bang and Olufsen Beocenter 9300 Shelf...
Tape stuck in recorder.
remove battery start over repeat constantly till tape comes out. very tedius but be patient it will take a few times. once tape is out DONT PUT IT BACK IN !!!! try other tape first
Jun 02, 2009 | Sony Handycam DCR-TRV310 Digital Camcorder
Tapes won't go down, and then eject.
Have you tried to force eject the cassette. May be the ribon of the tape has come out. Try using another cassette.
Mar 24, 2009 | Panasonic PV-V4522 VHS VCR
VCR ejects blank tape only
It sounds like the cassette is not releasing the tape so the machine can put it around the heads. This could damage the machine. Don't use it. A two dollar tape is not worth damaging your vcr. Throw it away.
Oct 09, 2008 | GE Televison & Video
Ultrium tape stuck
I highly recommend that you contact Certance for assistance. Tape drives are expensive and you don't want to risk damaging it.
If you are feeling brave you could see if you can manually eject the tape.
Remove the tape drive from the chassis and look for a manual rewind screw on the bottom or back of the drive. This is provided on some drives to allow you to manually wind the tape back into the cartrige and eject it.
I hope this helps.
Jul 25, 2008 | Certance (CL1001-R) Ultrium Tape Drive
Warning indicator C:32:00/C:32:11
I had the same problem (error c:32:00, beeps and tape would not eject. Cassette was halfway ejected) on my Sony CCD-TR416. I found the fix here:
http://www.camerahacker.com/Forums/DisplayComments.php?file=Video%20Camera/Sony/DCR_PC5E_Error_code_C_21.00.html
To summarize: remove the battery, unplug from the wall and smack the **** outta the bottom of the camera. It worked for me. It looks like my problem was that the tape had started coming out of the cassette body and caused a jam.
Feb 05, 2008 | Sony Handycam CCD-TRV43 Camcorder
VCR Tape Stuck
my tape got stuck too, i opened the bottom, then located the mechanism that started the eject program. After turning some wheels the eject automatically started. Try that...
Yamaha DSP-A1000 5-Channel Amplifier Logo
109 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
