Question about Alpine MRV-1507 Car Audio Amplifier
I get no power light or any sign of life at all...checked the fuse, it is fine. This is an old used amp I just aquired and I was wondering if the problem might be something simple or is the amp most likely dead??
  • 578 Answers
If you have all power check the signal to amp from rca if you do all that and stiil the same possibility am p done its days;lolo
Posted on Jun 26, 2009
Sanyo DP26640 has no power at all. It worked well for a little over a year and was plugged in with a playstation in the same outlet. No problems with the playstation. Wondering if buying a power boar
If there's no sign of life at all, the power supply is probably dead. It may be something as simple as a blown fuse but not all of those are replaceable. If you're comfortable around electronics, you could open it up, check the fuses (there are usually two or three), and replace the bad one (probably the main power fuse) if you find one. If you're not comfortable around electronics, or can't find a bad fuse, you should try to find a TV repair shop if they even exist anymore.
Hope this is helpful! Good Luck!
Nov 18, 2014 | Sanyo Televison & Video
VR550 : no signs of life at all after period of absence
Seems that way since repair not cost effective.
Sep 22, 2017 | Philips VR550 VHS VCR
When I plug the battery in for charging, the charge light does not come on. only the power light on the charger
There are several solutions to this problem which I have seen twice in my technical career.
You indicated that the power light on the charger comes on which indicates it is plugged into a working AC wall outlet. Check to make sure the power switch of the charger is turned on. Make sure that the round charger plug is plugged all the way into the battery charger receptacle on the battery box.
Next, check the on-board fuse AND the circuit breaker. I have had this little 5 Amp automotive style fuse burn out on several go go's and the charger does not work. Pull back the cover over the charger port and look for the fuse in its center slot. With a good set of fingernails it can be pulled straight out and inspected. Use fine needle nose pliers if necessary. I am assuming the go go runs and the push-button for the 15 Amp circuit breaker is pushed in. If it is out and the go go is not running reset the breaker by pushing the white button in. There is a clear rubber boot over the button. In my experience, the 5 amp auto fuse is your most likely problem. By holding it up to the light you can see if the fuse wire inside is burnt causing an open circuit. Most auto and hardware stores have this fuse in stock. Bring the old one to the store for comparison. It is a 5 Amp ATO fuse.
The question my clients often ask is what caused the charger circuit to overheat and the fuse to blow? The simple answer is that the two 12 Amp hour batteries in the go go are probably old and weak. This causes the charger to work too hard and the circuit to overheat and the fuse to blow. These small batteries have a short life span of between 6 months and 1 year depending on type. I recommend the AGM (advanced glass mat) batteries for longevity. Also make sure the charger being used on the chair is the 2 Amp small charger that came with the chair (There is a label on the charger to verify this). A larger charger will burn the batteries(shortening their life) and burn out the 5 Amp on-board fuse. Hope this helps.
Oct 31, 2010 | Pride Mobility Products Go Go Ultra X 3...
FUSE IS GOOD BATTERY HAS LIFE BRAKE LIGHT IS ON. YAMAHA BWS 2004
Yes instrument lights at least should come on.
Power goes from the battery to the ignition switch via the main fuse, & then splits to ignition & lights (via auxiliary fuses if present) which are separate circuits.
The problem could be an auxiliary fuse (if fitted) then contacts inside the ignition switch or wiring/connections from the ignition switch out to the ignition circuit
That is presuming the cluster light bulbs work!
Hope this helps ( if so please mark as very helpful)
Ride Safe
Bike-Doc
Apr 15, 2010 | 2005 Yamaha DT 125 X
No power but car cranks -2002 Oldsmobile Intrigue 250,000KM - Not sure if related but the car just sat for 10 days when I was on Vacation. It started firt time this morning no problem, I put on the heated...
The check engine light is interesting considering everything else is out. I would go to the fuse panels and trace power to the ignition switch. Other than the check engine light, this seems to be most likely.
Dec 02, 2009 | 2002 Oldsmobile Intrigue
Tv won't turn on
I assume you do not have any red light showing on the front of the TV to indicate it is receiving power? Again assuming the your mains electric supply is functioning & the fuse in the TV plug is ok, if there are no signs of life & then most likely a fuse in the power supply may have blown. If you have a multimeter you could remove the rear of the TV & check the fuses in the power supply, if these are ok then you will need to check any supply voltages coming from the power board. If one of the fuses are open circuit, check some of the doides or transistors for any short circuits. If you are not comfortable doing this, then it would be advisible to contact a repair service centre.
Jul 28, 2009 | Televison & Video
Nespresso aeroccino
if it was working fine before wiggle the power cord at the wall observe the machine for any sing of life lot of time is just the plug on the wall if not open the machine follow the power cord inside the wire inside check for power with a little tester fuses should be beside it cheers
Jan 27, 2008 | DeLonghi Caffe Parma Espresso Machine
Aiwa AV-D58 wont power on
this happened with mine two. all i did was press powert and enter at the same time and it clicked for like 2 hours or so and then it turned on. it was cool
Dec 09, 2007 | Aiwa AV-D58 Receiver
Car Audio & Video Logo
76 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
hoyzee1
Jaime Hernandez
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
