Nedd to Find Non Standard Screw Size Required for Hinge
Hi, I have a Kennore front load washer with rusted hinges and screws. I bought the hinges from Sears Parts direct but they do not come with screws. I purchased 2 thinking it was two sets as they charge $3 for them but found out that is per screw when I only received 2 screws! I've tried to find these screws everywhere but no one carries them as it is apparantly a #8 screw with a #6 head. It is a flat head, Phillips head screw, silver in color and threading looks like a wood screw. Home Depot said it is not a rust proof type. Do you know of anywhere else to purchase 16 of these screws? They are 3/4" long for the washer door hinges but the dryer uses the same hinge with a shorter screw. Sears sku# is 134424700. Only description is "screw, comb fla" shows "49-H10-31" and "L 23 022 Z 317". Tried a regular #8 but screw does not sit flat so door wouldn't be able to close properly. Any help you can offer would be greatly appreciated! Thank you.
  • 10,865 Answers
Go to any hardware store and purchase plastic anchors for the #6 screws. Tap the anchor and then your screw will fit and snug down as it should.
Posted on Apr 15, 2009
Reverse door swing
check if there are little plastic screw hole covers on the non-hinge side of the door. If there are, then simply unscrew the hinge, remove the plastic covers, and swap it to the other side!
Nov 17, 2011 | Whirlpool GHW9200L Front Load Washer
Door is locked, wont open
remove bottom acces panel 1/4 screw sometimes torx bit ubplug washer reach in on non hinge side against doorshould be door lock latch assymbley, bottom of latch assymbley is a round plastic end thats spring loaded ,pull downward and open door replace door lock assymbley
Jan 23, 2011 | Whirlpool Duet GHW9150P Front Load Washer
THe door hinge on my GE front load clothes washing machine model # wssh300G1WW has rusted and bent and the screws are rusted. I would like to replace the hinges and screws but I don't think the...
I have the same washer & its 3 years old today. Rusted hinges & door & screws too.
Door is really hard to shut so I called GE to complain & they are overnighting me a new door, hinges, & screws. You should call!!
Oct 11, 2010 | General Electric WSSH300G Front Load...
How do install the door hinge to a LG Washer Model WM1812CW? What is the size of the screws and do you need a nut to secure the hinge to the frame of the washer?
No nuts required, but the original screws are installed with lock tight, and are very difficult to remove. Taking the entire front panel off the machine and then heating the screw with a pencil thin torch generally helps. If I remember correctly, the screws are 10 mm.
Jun 11, 2010 | LG WM1814CW Front Load Washer
I have a maytag front load mah4000aww. i replaced the wax motor and motor board put it back together. when i tried to wash a load water started to come out of the door. any suggestions would be gratefully...
The door is most probably out of alignment with the front shroud. Slightly loosen the door hinge screws and close the door firmly making sure it is fully and evenly seated into the shroud. Retighten the lower hinge screw but not fully tight. Retighten the upper hinge screw but not fully tight. Fully retighten the lower hinge screw then the upper hinge screw.
Feb 12, 2010 | Washing Machines
Fit a new door hinge
Remove the wire clamp securing rubber seal to front of washer, pull seal of front of washer, this will give you clear access to tjhe door hinge, ondo the 2 screws securing the door hinge, remove door ,and seperate the 2 door halves by removing the screws securing it together
Replace with new hinge, fit back in reverse order.
Please rate my solution.
Thanks.
Nov 12, 2009 | Creda W120VW Front Load Washer
I have bought a new door hinge for a hotpoin wd63p washer dryer but was wonderig do you have to take the front of the washing machine or the rubber
hi from uk easiest way is to turn off/remove water supply hoses disconnect power then remove top screws from rear panel(these also secure top panel if yo look ?) then lift rear of top panel slightly and pull back/then lift off you now have access to rear of front panel where door hing is secured by 2 screws from the front of panel/hing into a metal plate theaded inscrew door from plate whilst you hold plate thenremove door with hinge assy you will now see the inner plastic cover of door is secured remove this cover to access hinge screws renew hinge and whilst door is at this point might as well lift glass window and clean any **** around the edge ? reassemble in reverse to strip down hope this is clear enough for you ? good luck
Nov 04, 2009 | Hotpoint Aquarius WD63 Front Load...
How to replace hinge lid pins
At the back of the washer just below the control panel there are two 8mm metal screws remove them there are 2 clips they will alow you to lift the top up in the front of the washer the top cover has 2 spring type holders if you slide a small screw driver in the opening and push gentle on the spring clips they will release and you can lift the top off the washer there is a screw on each hinge this will remove the old hinge then replace with new ones hope this will help
Jan 24, 2009 | Maytag PAV2300 Top Load Washer
Door hinges broken and door fell off
yeah very easy and it should only cost at most about £10 undue the old hinge with the 2screws now the door will have two little covers that held the old hinge in place take these out and make sure u get the broken pieces out of them once u have the new 1 put it on the washer and screw down first and then place the covers on the ends of the hinges and put the door in place now redue the screws on the door
Jun 01, 2008 | Candy CN146 Front Load Washer
Door hinge
Firstly if you haven't already done so remove the door and the old Hinge. You can do this by undoing the screws at the back that hold the top of the machine on and remove the top of machine. Now you will see a piece on the inside where the hinge screws into. Hold onto this piece and undo the screws from the outside. Carefully remove the inside piece (because I dropped mine inside and it took me an age to get it out!!). Now undo the screws on the door and pull it apart. Replace the old hinge and screw door back together. Now holding the inside piece back in original position screw the hinge and back onto the machine. (You might need someone to hold the door in place for you....it makes it much easier). Finally screw the top of the machine back on.
Apr 21, 2008 | Creda W100FW Front Load Washer
Washing Machines Logo
164 people viewed this question
Top Washing Machines Experts
