Question about Music
Shut off My Behringer mixer just shut off out of nowhere during recording, what do I do? what's wrong with it?
  • Music Master
  • 5,603 Answers
You don't tell us what model unit it is. If all the lights go out on it, suspect the power supply or power connections.
Posted on Jul 26, 2009
Can't hear playback through Headphone socket, only through speaker monitors!
i suggest you contact Behringer Customer Service for advixce. Without the setup in front of me, it's hard to figure out the wire routeing, switch positions, ect. that may be leading to this problem. As they would be the people most familiar with the gear, they'sd be the people to ask. http://www.music-group.com/support/behringer/askquestion
Oct 28, 2016 | Behringer Music
Where do you connect a midi controller on a Behringer Xenyx 1204usb mixer?
You can connect where it is possible. I hope you will understand.
Aug 04, 2016 | Behringer Music
Why does my recording having a clicking noise
What DAW are you working in? Also.check your buffer size. You may also need more ram,check your ram usage after recording for a while. most DAWs come with a ram usage monitor
Oct 01, 2017 | Behringer XENYX 1202 Premium 12-Input...
I need instalation diagram for tascam DR-1 to behringer 2442
We don't have any graphic means of diagramming. You also don't say if this is for recording or playing or both. Assuming it is both, your best way would be to get two 1/8 stereo cables that split into two RCA plugs. Go from the headphone out of the DR1 to the CD inout jacks on the mixer. Then with the second cable go from teh CD out jacks of the mixer to the line in of the DR1.
Mar 31, 2011 | Behringer XENYX 2442FX Mixer
I can't hear sound from my PC when I'm using the mixer. I plugged it in with the USB to the computer and tried to record using Cubase 4 LE. I seem to get sound in, but i can't hear any sounds from the...
In the "Sounds and Devices" of teh control panel under the Voice and also recording tabs amke sure the 2442 is selected instead of teh computer internal audiop system.
Feb 18, 2011 | Behringer XENYX 2442FX Mixer
I have a behringer xenyx 1204usb mixer with a mxl 990 mic and i have problems with static. thats all i have hooked to the mixer so i dont think its a conflict. i have tried recording in audition, pro...
Yep ! First thing is to eliminate any processing resource "hogs" that **** respources and can cause buffer overruns. Eliminate Antivirus, antispyware, and network communication and wireless network programs running in the background while recording.
Next make sure that ALL equipment is powered from the same receptacle or power source. In your case that should be the mixer and the PC.
Next remember that the condenser mic picks up everything... I have 5 of those mics and seemingly noise free environments turn out to have little things that generate fast rising pulses that you don't notice till they are recorded.
Lastly, the air here is very dry and plain old static electricity is rampart... Lady shuffling her feet was sending pulses through the mic cable at our church. They are NOT audible until they get into the sound system as clicks.
I have found that trying to record directely to a USB stick often has ooverruns and clicks... also burning a CD from stick to the CD results in noise due to buffer underuns. Burn from Hard drive to CD and make sure all the other hog programs are shut off.
Jan 04, 2011 | Behringer Xenyx 1002fx Mixer 10 Input 2...
Im thinking about buying a djx750 and have rokit 5 monitors. would this work? what is the best way to connect them, to have good sound? it is just for a home dj setup, all on one desk, two cd decks,...
Here is alink to the manual:http://www.behringer.com/EN/downloads/pdf/DJX750_P0956_M_EN.pdf You should have no problems hooking them up (RCA to RCA). I've been using a Behringer XenyX1222FX board in my recording system for about 4 years now and have been quite satisfied with it's reliability. Try to find a dealer who will demo the mixer for you.
Aug 24, 2010 | Behringer DJx700 5-Channel Pro DJ Mixer...
Behringer mixer power goes off after running about 5 0r 10 minutes then power turns on.what is problem with the power supply board
That time lag would indicate a thermal problem.
Likely the power supply is a switching type that has some three terminal regulators after it such as 7805, 7815, 7915.
These have thermal protection in them and one may be shutting down.
Use circuit cooler to isolate the part that is shutting down.
May 20, 2010 | Behringer Xenyx 1002fx Mixer 10 Input 2...
I have a behringer Xenyx 1622 mixer and am using cubase when i plug it in the it says its ready to go but, something happens and theres no volume..and i cant set it up in cubase?...any suggestions..
When you open Cubase you MUST open a new project.
Then select 24 track audio for example... unless yoou are doing MIDI record and playback.
Then open up a mixer panel and select a channel to read or connect to a file.
There are too many options to describe and the "says its ready to go " is not enough information to know where you are.
You may have to imprt files or record music... Don't forget to select a track on the display of tracks.
Apr 27, 2010 | Behringer Xenyx 1002fx Mixer 10 Input 2...
How do i hook 1202fx to computer?
just connect a baby plug to rca from the pc to the mixer respectively
Feb 14, 2010 | Behringer Xenyx 1002fx Mixer 10 Input 2...
Music Logo
46 people viewed this question
Top Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Are you a Music Expert? Answer questions, earn points and help others
