Question about GE Refrigerators
Have a GE GSS22VGMD side by side with icemaker in the door. Both the freezer and the refrigerator seemed to have stopped working and are not staying cold.
I have a GE GSS22VGMD side by side with icemaker in the door. Both the freezer and the refrigerator seemed to have stopped working and are not staying cold.
  • 74 Answers
SOURCE: side by side GE refrigerator psf26pgta
The fan should be a standard 12v DC computer style fan , test that you are getting voltage to the fan connector . You should also be able to get the fan to run by connecting it to a suitable supply . Once you have eliminated the possibility of fan failure then it gets more involved.
Posted on Aug 28, 2008
  • 833 Answers
SOURCE: GE Monogram freezer side working but refrigerator side is not.
Did you clean the condenser?  Is the unit FULLY defrosted?   Defrost fully!!!!!!
Did he check the amount of gas in the unit?  If your unit has low gas...it is in need of more.  R12 is expensive.
Check gas level:  Shut unit for at least one hour.  View compressor.  Several pipes...we're looking at the largest.  Start the unit.  This pipe will begin to frost.  If it does not clear to dry, ice or wet...stays frosted...it is low.  Get the repair guy back ... but ask how much he'll charge first.
Posted on Dec 12, 2008
  • 3 Answers
SOURCE: GE model TFX24FA side by side
If solution #1 fixes the problem, but it happens again, then check to see if you have water leaking from the ice maker area. I had a similar problem with my same model, and found that the ice maker water fill tube was leaking where connects to the connector in the back wall of the freezer. Water was leaking onto the freezer coils, causing it to go into defrost for long periods and both the freezer and fridge would warm up.
Getting to the fill tube is not an easy job. If you just pull it out without disassembling the fan compartment, you will probably not be able to get it back in.
You will likely want to move your food, unplug the fridge and thaw it out. Disassembling the top compartment on the inside of the back wall of the freezer is a tedious and time consuming task. After that I was able to just pull the tube out and turn it around and push it back in for a snug fit. You might consider using a sealer.
Posted on Apr 03, 2009
ginko
  • 19396 Answers
SOURCE: Icemaker not working, freezer not getting cold enough....
Try using an hairdryer or defrosting the unit completely , this often get rid of blockage caused by frozen lines fixing the problem.
The water lines can also be unblocked from dirt using a thin flexible shaft. This after defrosting.
If all that does not fix the problem, then you may need to replace the water valve, the icemaker solenoid, or the whole icemaker assembly.
Enter the model number on one of two websites below to get parts and diagrams for your appliance:
Appliance Parts From PartSelect
Appliance Parts Pros
Posted on May 22, 2009
Sea Breeze
  • 4655 Answers
SOURCE: GE Profile Artica PSH23PSAASV side by side refrigerator not cool
You will need to unplug the refrigerator and remove the back panel inside the freezer. Check for ice or a frozen over evaporator coil. If frozen defrost and we will need to examine the defrost heater at the bottom of the evaporator. It may have a glass tube covering the heater element inside. I want you to check to see if it is burned out. The part number for the defrost heater is WR51X10042
You please let me know what you find. If the element is burned out I recommend you replace it and the defrost thermostat part number WR50X10068
You and order the parts by clicking the link below and entering the part number into the part number search feature and click FIND IT. Let me know what you find, Sea Breeze
PART NUMBER AND MODEL SEARCH FEATURE
Posted on Jul 24, 2009
Ge tfx22kr
Have you checked the light switch. It is common for the light switch to also keep the icemaker from driving the ice through the door. It shouldn't keep the icemaker from making ice though. It could be the icemaker being bad or the water valve being bad.
Aug 17, 2014 | GE (PSS26MSRSS) Side by Side Refrigerator
Replaced the defrost heater,defrost thermostat,worked good for about 3
If the icemaker refill solenoid does not close properly or stays open too long excess water enters freezer compartment and that will freeze over the ice making machine plus other areas of freezer. There is an adjustment on the ice maker to regulate the amount of water going in - locate the screw (behind front panel of maker) and turn counter clockwise to lessen time of fill operation). Problem is not with the GE
Sep 06, 2017 | GE GSH25JFR Side by Side Refrigerator
Ice melts in freezer
check your inner box liner for cracks also your door seal's you have a air leak
Jan 13, 2010 | GE Profile Arctica 25.4 Cubic Feet...
GE Profile Arctica Icemaker
YOU CAN PULL THE FRONT COVER OFF TO SEE IF THE GEAR WHEEL IS BROKE,OTHER THEM AT CALL YOUR LOCAL APPLIANCE PARTS STORE AND YOU CAN GET A NEW ONE FOR AROUND $70,THANKS-MIKE
May 29, 2008 | GE Profile Arctica Stainless Steel Top...
Side by side GE profile
I have a GE side by side refrigerater freezer. I thas the diagnostic center on the freezer door. The de symbol started flashing afew days ago and the refridgerater side isn't getting cold. the fan is on and doen't seem to cut off, If someone could steer me in the right direction I would appreciate it.
Jan 29, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Profile French Door Bottom Freezer not cooling
I am experiencing the same problem with my GE fridge. We have already tried the Turbo Cool, but nothing seems to help.
Thanks
Carol
Nov 13, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
Water leaking inside freezer ice maker
sounds like the line was frozen but the water fill indicator is faulty.
Jun 05, 2007 | Hotpoint HSS25GFP Side by Side...
Refrigerators Logo
149 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Gene Tuck
