Question about General Electric DHDSR46EGWW Dryer
Dryer Timer Won't Advance in Auto Mode
Model: Maytag MDE2301AYW
The dryer timer will not advance in AUTO DRY modes. It works fine in timed mode. Dryer appears to heat properly and I have ensured the vent is clean. The vent appears to be installed properly--goes straight out the back of the dryer for about 8 inches, does a 90 degree sweep upwards, and then straight out the top of the roof on a single story home. The temperature coming out the vent exhaust at the back of the dryer cycles between 130 degrees to 160 degrees on a regular basis. I called Maytag and there are two sensors/thermostats. One is the Upper Limit (part number 303396) and the second is a Multi-temp (part number 307249). I suspect it may be one of these sensors not sending a signal to the timer to advance but I'm not sure. Any suggestions?
  • 4 more comments
  • Huachuca Apr 15, 2009
    Thanks for the quick response. I double checked and there is no metal strips or moisture sensors that I can find.
    Also, the posts automatically indicated this was a GE Dryer and it is not. It is Maytag MED2301AYW.
  • Huachuca Apr 16, 2009
    Sorry... I got the model number right in the original post but I mistyped it in my comment. It was Model # MDE2301AYW. I looked at the manual and it doesn't mention anything about moisture sensors. I called Maytag and they confirmed there is no moisture senors in this model. Of course they won't help me troubleshoot... they wanted to send out a tech.
    I changed the timer and still have the problem. The clothes dry just as well on Auto Dry as they do timed dry.
  • Huachuca Apr 18, 2009
    Thanks. I'm thinking of trying the multi-temp sensor/thermostat. If the parts store is open tomorrow, I'll purchase, install, and see if that fixes the problem.
    Again thanks for your help.
  • Huachuca May 06, 2009
    I looked at the electrical schematic located inside the dryer's control panel behind the timer. It showed a connection from the multi-temp sensor/thermostat to the timer. I found another posts that suggested the multi-temp sesnor does send a singal to the timer to advance it based upon cycles of the multi-temp sensor. I changed the multi-temp sensor and all is well. Thanks for all your help. Problem Solved. Electrical Schematic attached.
    Novelist:
  • 108 Answers
Inside the dryer there should be two small metal strips (about 6-7 inches long and about 1/4 inch wide). These are the pieces that detect how much moisture is in the clothing. If possible, unscrew the plastic piece that they mount to, and see if the wires are still attached.
Bear in mind that "auto dry" doesn't usually work well unless you have a well filled dryer (one or two items may not come in contact with the sensors enough to tell the machine to continue heating— since it isn't coming in contact with wet clothing, it thinks the load is "dry".
The problem could also come from the circuitry in the control panel, but I would check these first. The fact that the machine works fine in regular timed cycle indicates that the upper limit and multi temp thermostats are working correctly.
As always, unplug the unit before unscrewing anything.
Posted on Apr 15, 2009
  • 3 more comments
  • StanStihl Apr 15, 2009
    hmmmm... I couldn't find anything about that model number. Does it have a special name on the control panel?
    Perhaps they have put a moisture sensor in the venting inside the unit... tough to say for sure.
  • StanStihl Apr 16, 2009
    After reading your post again, I'm leaning towards a problem with the timer itself, since as you say it works fine when in timed dry.
    Granted, the timer is a bit pricey, but these guys will let you put it back in the box and return it if it doesn't solve the problem.
    http://www.repairclinic.com/SSPartDetail...
    Do the clothes stay wet in auto dry, but dry more quickly in timed dry? Or is the problem just that the timer doesn't advance?
    Well, I guess it's time to get those sensors!
    Tell you what though... I've never heard of this exact problem, but then again I haven't been an appliance repairman for /that/ long. I'll call the Maytag tech line tomorrow, and see what they say.
  • george Jun 16, 2013
    yes when i disconect one of the lower sensor...it works fine
    but i dont think i have it to replace............what can i do?
Maytag Dryer MDE6400AYW. Dries clothing but does not shut off in Auto Mode. Tried Timer mode but the knob does not advance on its own and dryer does not shut off in that mode either. Replace Timer?
Some of them timer can be oiled, (just a little zoom oil no wd-40) if it is real hard to turn, the knob can become cracked and the timer motor itself it may not have enough ump to move the gears and sometimes oiling the timer and moving it around many times loosens em up.
Jan 11, 2017 | Maytag Dryers
Our Maytag Centennial Electric dryer is not cycling in auto dry mode but will in timer mode. Any thoughts?
There is a sensor that the clothes have to touch when the drum spins. This sensor measures how wet the clothes are. If you don't have enough of a load in the dryer then the sensor wont detect the dryness. Or it could be a bad sensor or connection or main board.
Nov 02, 2015 | Maytag Centennial 7.0 Cu. Ft. Super...
Maytag dryer wont turn off
I thank you need a new Timer part# 3979617
Jan 21, 2013 | Maytag Dryers
Dryer timer will not advance in any mode.. timed, or auto mode. Dryer works, but will not turn off unless you open door or advance timer. Do I need to replace the timer?
the timer will need to be replaced if it's stuck in the mode as you stated. the timer is built with cog teeth gears that rotate slowly as the timer operates normally. If a cog tooth breaks off the timer is stuck in that position causing your problem here
Jul 11, 2011 | Whirlpool LEB6200 Electric Dryer
My Maytag MDG6400AWW timer does not advance in the Auto mode. The clothes will dry but it will spin and spin for hours until you open the door. In timer mode everything appears to work normally
sounds like it is not sensing the temperature, which is the thermostat, here is a website that will help you out, #6 dryers basic, Good Luck Tim:
http://www.applianceaid.com/general.html#timers
Nov 27, 2010 | Maytag Atlantis MDG7400AW Gas Dryer
Dryer Timer dial will not move but dryer works
Will the dryer move forward in timed dry? if it does not then you need a new timer. If if will advance in timed dry but does not advance in auto mode then the high limit needs to be replaced on the heater.
Apr 10, 2009 | Roper REX4634KQ Electric Dryer
Timer does not advance, even in timed mode
My parts sources list 3 different timers for this dryer depending upon the MAN.#.
They are
33002855
33002808
33002854
Feb 22, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Dryer will not turn off in Automatic mode
look to a faulty/clogged/blocked vent befoer switching partsno your machine. nost common fault for too long to dry on auto-- or wont advance on auto dry is innadequate venting
Jan 27, 2009 | Dryers
Maytag atlantis dryer model # mde6400ayw
sounds like the timer is not completing the cycle in this mode will the dryer shut off if you manuelly advance timer in that mode
Oct 21, 2008 | Maytag Atlantis MDE7400AY Electric Dryer
General Electric DHDSR46EGWW Dryer Logo
1,469 people viewed this question
Top General Electric Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Donni Steen
Are you a General Electric Dryer Expert? Answer questions, earn points and help others
