Question about Philips 27PT8420 27" TV
Philips 29PT8419-79R Does not turn on, but the power LED is lighted on but nothing on screen, just blank. I tried turning it off and on again but nothing happens. Whenever i push buttons on the remote control you can see the LED flashes but still the screen is blank.
  • 1 more comment
  • RICHARD P Jan 29, 2008
    HALLO, I HAVE THE SAME TV IT IS DEAD NO LED ON THE FRONT PANEL BUT THERE IS 88.9VOLTS ON THE TRANSISTOR NEAR THE LOPT AND 5 VOLTS ON THE REMOTE RX AND I CAN HEAR THE SPEAKER MAKE A NOISE WHEN I TURN THE MAINS SWITCH OFF.
    CAN SOMEONE HELP ME PLEASE
    TKS
    RICHARD
  • Anonymous Jul 14, 2008
    Dead - same symptoms as you described.
  • Anonymous Jan 09, 2009
    Model 29PT8419/79. LED light on, flashes on and off - No picture TV dead as a doornail. Someone please help.
    Prodigy:
    An expert who has answered 500 questions.
  • 556 Answers
The problem in power supply. if its output is ok than you will have to check horizontal section.
Posted on Sep 15, 2007
Philips 32pf9830 does not turn on
Check its main board. A serial clock-serial data transfer problem occurs. Might be the fault to the main digital board, and be replaced. But, it is best to contact any technician to make it confirm. If you're sound in electronics, check this link. It has details about service help to Philips flat panels. Pull up older posts there, either by its left side bar, or see it in Timslide option.http://electronicshelponline.blogspot.com/ If you're nothing in electronics, do not go forward. Keep it in mind, that the Brand is Philips; even an experienced technician too have to spend some time before it to locate the exact fault location.
Jun 26, 2013 | Televison & Video
Philips 42 inch flat screen TV, making a 'tweeting' sound and no picture
Power supply has failed. The blue LED merely confirms that power is getting to the TV.
Oct 03, 2012 | Philips 42pf9966 42-inch Hd-ready Flat...
Unable to solve Blank screen
hmm confusing but try turning your ps3 off at the wall give it 5mins and try again if nothing happens try it on another tv
Sep 25, 2009 | Sony PlayStation® 3 (80GB) Console
My Philips standard tv picture went out
You may have a corrupt eeprom! Eventually the red light will come on with no audio or video!
Jun 17, 2009 | Philips 27MS4504 TV
Power light is green but screen is black
Do you get anything at all on the screen--like white writing at startup?
Even if your video drivers have become corrupt, they are not used until Windows actually starts.
It very well could be the flourescent backlight has gone bad. Can you adjust the brightness/contrast at all to see anything?
If those controls do nothing for you, then you're looking to get a new monitor.
Your monitor does have a sort of power supply for the backlight and that could be bad, but if you're not into taking it apart, then you are far better off buying a new monitor.
May 27, 2009 | Philips Computers & Internet
Tv screen went blank
sound like the inverter circuit board problem. check & replace back same part# inverter circuit board. hopefully could help!!
Dec 29, 2008 | Vizio L32 32 in. LCD HDTV
Philips 19s lcd monitor
you have to replace the capacitor in the high voltage board inside your lcd if you know how to open it
Nov 03, 2008 | Philips 190S7FS (Silver) 19 inch LCD...
Philips TV model number 27PT543S37A
TV turns on but doesn't stay on goes in and out then blank screen. LED light stays on during the entire time your problem is called hunting you can check power supply of your tv .It common problem in Philips T.V. Thanks
Sep 11, 2007 | Panasonic CT-32SX12 32" TV
Philips 43PP8545
You have no high voltage, like many in this forum, this model of Philips has some of the same problems. Look around here you may find the answer to your set. If not check Vertical IC, TDA8177, audio ic on signal board up front on left. check Power supply first for blown fuse, 1000, 2004, 1300, 1900 etc. No sound or pic means something is open. Does set has L E D lights on front of set?
Sep 02, 2007 | Philips 60PP9202 60" Rear Projection...
Philips 27PT8420 27" TV Logo
340 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
