Question about Microwave Ovens
No display on microwave touchpad for ge Model JKP62G
For Model "JKP62G" - Started the microwave and walked away. Upon return, the "Display and Touch Control Pads" was blank. Cycled the appropriate breker for the kitchen and it remained display-less. No response from any touch pad buttons. The oven light/controls work fine (limited to microwave).
    Problem Solver:
  • 6 Answers
The GE JKP62G Microwave / Oven combination has an internal fuse behind the control panel for the microwave. The oven will operate but the microwave will be totally dead (no light, no clock). Turn off the breaker for the oven at the fuse box (30 Amp double breaker). In order to replace the fuse you will have to open the door to the microwave, remove the two screws (Torx) from the front control panel (located on the left edge of the control panel), wiggle the panel to the left (there are two metal tabs that stick into the metal frame of the microwave on the right of the panel) and then tilt the panel down from the top. There is a metal bracket that holds the control panel to the microwave at the bottom (don't remove it). Look towards the top of the microwave inside the area behind the control panel and you will see a 15 Amp screw in fuse. Replace the fuse and that should fix your problem.
Posted on May 02, 2010
HOW DO I CHANGE OUT THE TOUCHPAD FOR JNM1731DPBB
I'd suggest you contact Matt Fadorsen at eM-Ka Ventures in Chesterland, Ohio. He just repaired my GE keypad on a Model JVM2070CH02 microwave (GE doesn't make just the membrane keypad available--you have to purchase the entire control panel ($548.00 through a local parts distributor). Matt's turnaround from the time I removed the keypad to the time I re-installed it was only 8 days--and it only cost me $100, which included the return shipping. I'm sold on Matt!
Jun 29, 2013 | General Electric GE JNM1731DPBB 1.7 cu ft...
Buttons on microwave
testing every step and fix it. God bless you see the diagram attached
Microwave Buttons Don't Work
Touchpad and Control Panel
If the microwave buttons don't work the touchpad and control panel assembly are probably defective.
Touchpad
If the microwave buttons don't work the touchpad might be at fault. Generally speaking, if the dishwasher display is working and some of the buttons respond correctly but some don't, the problem is with the touchpad.
User Control and Display Board
If the microwave buttons don't work the user control and display board are most likely defective and will need to be replaced. If some of the buttons work and some don't, it is more likely a touch pad problem and the touch pad will need to be replaced.
Main Control Board
If the microwave buttons don't work the main control board is most likely defective and will need to be replaced. If some of the buttons work the touch pad is likely the problem. If none of the buttons work the problem may be in the main control board.1_24_2013_5_23_47_pm.gif1_24_2013_5_24_54_pm.jpg
Jan 24, 2013 | Goldstar MV-1501 Microwave Oven
The touch pod on my microwavw 9je635 wont do anything when i press the boutos for timing fuction
follow this steps and fix it. God bless you
Touchpad
Main Control Board
If the microwave buttons don't work the main control board is most likely defective and will need to be replaced. If some of the buttons work the touch pad is likely the problem. If none of the buttons work the problem may be in the main control board.1_24_2013_5_54_53_pm.gif1_24_2013_5_55_10_pm.jpg
Jan 24, 2013 | GE JE635 Microwave Oven
My microwave keypad wont work the light is on and the reading says please touch clock and set time of dry
SEE THIS CAUSES AND FIX IT. God bless you
Touchpad and Control Panel If the microwave buttons don't work the touchpad and control panel assembly are probably defective.
Touchpad If the microwave buttons don't work the touchpad might be at fault. Generally speaking, if the display is working and some of the buttons respond correctly but some don't, the problem is with the touchpad.
ser Control and Display Board If the microwave buttons don't work the main control board is most likely defective and will need to be replaced.
Main Control Board If the microwave buttons don't work the main control board is most likely defective and will need to be replaced.
Oct 01, 2012 | Kenmore 80809 Microwave Oven
I have GE JVM1540DN1BB microwawe. It beeps all the time and says "keypad sorted" and service needed. The beep sound is annoying and it beeps every 30 seconds
see this causes and fix it. God bless you
User Control and Display Board If the microwave buttons don't work the main control board is most likely defective and will need to be replaced.
Oct 01, 2012 | GE Microwave Ovens
Our GE built in microwave model # JKP62G suddenly started making a loud noise when we try to use it. It does this on any power level and on the defrost setting also. It does not seem to be heating...
It sounds like the magnetron may have either failed or is not being supplied with the extremely high voltage required to run it.
Make sure the !!!!capacitor is discharged!!!!! before attempting any sort of repair.
Check the door interlock switches first then the high voltage diode with either an AVO model 8 on high resistance range for short circuit, the capacitor can fail and go short circuit, the feed fuse on the primary of the high voltage transformer and then finally, the magnetron is best checked by substitution.
Hope that helps.
Jan 01, 2011 | GE Microwave Ovens
Touchpad will not work after boiling water underneath it for 12 minutes without fan humidity cause touch pad to stop working , I have a GE mdv 2040 with green display touch pad
you can change the touchpad to help with this but whenever you have a microwave over a range you are going to have issues with this. you have to make sure you use the vent on high whenever broiling anything to prevent the moisture from getting in the touch pad because all your touchpad consists of is two stickers and some flat wire so moisture can easily getting into it cause it to stop working for a period of time. but changing it is the best thing you can do
Jun 02, 2010 | GE JVM1860 Microwave Oven
Display numbers/words disappear
There are two options for this model:
- You can order an exclusive modified display control unit (#CU440) with proprietary upgrades for $115, then if you return your defective control unit in repairable, good cosmetic condition, you get a core refund of $30. It comes with a one-year guarantee. Details are here.
- Or your existing control unit can be repaired for $39.95 in most cases, also with a full one year guarantee. Details are here.
May 24, 2010 | Dacor DMT2420SS Microwave Oven
My house lost power earlier today, and now my microwave is not heating the food, and has a lower case "d" in the display after the time. Any suggestions?
It is in the demo mode. To turn off here is what the manual says:
The microwave oven and Timer must be off. Touch and hold Timer Off or the number 3 pad (depending on model) for three to five seconds (depending upon model) until two tones sound and “d” or "Demo" (depending on model) appears on the display. Repeat to turn off and remove “d” or "Demo" icon from the display.
May 10, 2010 | Whirlpool GH7145XF Microwave Oven
Sharp carousel R1754 microwave...display screen keeps scrambling
Stay away from Microwavedisplay.com and William E Miller. He will take your money and will not return your display unit let alone repairing it. Do your research. There are a lot of us out there!!!
Dec 27, 2008 | Sharp R-1750 Microwave Oven
Microwave Ovens Logo
844 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
