Question about Lands Phones
MDF Krone Adapter
G'day All, Hope you are all well. I was wondering, i work as a Pabx Engineer, and used an adapter in the UK that attaches to the bare mdf frame, then you add the krone strip to terminate your cables. Once you have terminated all your pairs, you take the adapter off, and this gives you your exact cable excess. Does anyone know where i can get one of these adapters..???
3 Suggested Answers
SOURCE:
SOURCE: Free download connectivity adapter cable CA-45
I HAVE BUY USB CABLE TYPE CA - 45 AND THE INSTALLATION CABLE, BUT IT DOES NOT INSTALL IN THE COMPUTER, HOE SHALL I GET THE CORECT SOFTWARE.
Posted on Aug 18, 2010
consultel1
  • 860 Answers
SOURCE: What analog terminal adapter do
On Partner systems the port works for both digital and analog telephones.So if you have a digital port in your conference room for your Partner phone you can unplug the phone and plug in your polycom.
Posted on Nov 16, 2010
Attach a database without the corrupted log file
There might be other options out there. This is something that worked for me once but there are no guarantees that it will work at all times.
Stop SQL Server instance -> Copy MDF and LDF files to another location -> Delete original MDF and LDF files -> Start SQL Server instance again -> Create new database with exact same name and file names -> Stop SQL Server -> overwrite newly created MDF and LDF.
After this your database should be back online. If it is then go ahead and put it into EMERGANCY mode and SINGLE USER mode.
Finally go ahead and execute DBCC CHECKDB like this
DBCC CHECKDB (databaseName, REPAIR_ALLOW_DATA_LOSS) WITH NO_INFOMSGS
More information you can dig out from resources directly connected with SQL Server databases and database corruption in MS SQL Server any version...
http://itknowledgeexchange.techtarget.com/itanswers/how-to-restore-mdf-file-as-bakcup-databe/
https://www.repairtoolbox.com/sqlserverrepair.html SQL Server Repair Toolbox
May 15, 2015 | Microsoft SQL Server 2008 Enterprise Full...
Creating a new database using an MDF file
An MDF file isn't a backup file isn't the main data file (or master data file depending on who you ask) hence the file extension MDF. You can attach the MDF to the database by right clicking on the databases folder in Enterprise Manager (SQL 2000) or Management Studio (SQL 2005) then selecting all tasks and then Attach Database.
When you do this you will get an error about the log file missing. This shouldn't matter as SQL Server will simply create a new log file for you.
This will only work if the SQL Server was stopped when you copied the MDF file from the old SQL Server. If you copied the file while the SQL Server was running this file probably will not attach either and you will need to get a valid backup of the database.
Download help tool for sql database - SQL Server Restore Toolbox.
http://www.sqlserver.restoretools.com/
You can read up more on SQL Server here.
http://www.filerepairforum.com/forum/microsoft/microsoft-aa/sql-server/498-creating-a-new-database-using-an-mdf-file?_=1416149856104/
Nov 16, 2014 | Microsoft SQL Server 2000 Standard Edition...
What headphone connector do I use for inflight entertainment
Hello!
First, enjoy your wonderful headphones! I used them now for almost an year and enjoying every minute.
For your question, if I understand it right so you ask how to use them in a plane.
So I just got an airplane adapter with my headphones. Picture attached. hope you got the adapter as well.
Regards,
Tal Zoor
Jul 05, 2014 | Bose QC15 Headphones
Conair problems
Hi Anonymous! A couple of questions:
  1. I hope you will forgive me asking the obvious, but did you ensure the location selector on the side is firmly locked in the UK position? Have you tried (while it's unplugged) sliding it from UK back to US and then back to UK?'
  2. Does this happen when using the USB alone or does the adapter behave this way when using the power itself (i.e. shaver/dryer/etc.)?
Also, and I imagine you already know this, but remember that the AC portion of this product does not convert electrical voltage. You will require a converter or transformer for your single-voltage appliances. If the appliance has an internal 110/220 (60Hz/50Hz) switch, then you are fine.
If you have already tried these things and the adapter still is malfunctioning, you may want to see about warranty exchange.
Hope this helps.
Jun 10, 2014 | Travel Smart Lectronic Smart LS1ADR...
How to recover deleted Microsoft SQL server MDF files?
Recover and repair MDF files with simple and efficetive tool to repair and recover MDF files from corrupt and damaged SQL server, which tool support all king of SQL server version and Windows OS. Visit here: http://www.en.mdfrepair.net
Read blog post: http://exchangerecovery.hubpages.com/hub/How-to-perform-SQL-Database-Recovery Corrupt MDF File Repair Utility
Apr 17, 2014 | Computers & Internet
I NEE TO BUY NETGEAR POWER SUPPLY (OUTPUT 12V 1A)
Hi
You can take this adapter any elictrical shop,and asked them to give 12v adapter,if you show them adapter that will help you get the correct one
Hope it will resolved your query
Thanks for using Fixya
May 24, 2010 | NetGear Power Supply
Cannot connect to internet
Ring up your server provider its free - Here's the US and UK's numbers. If your countries none of them please comment back with your country and I'll get your counties freephone for belkin for you. UK 0845 607 7787 USA
Hope I helped
Dr Reed 00 223 5546
Apr 03, 2010 | Belkin (F5D7050) 802.11a/g/b Wireless...
Require ISDN connection diagram for Ericsson BP 250 PABX
you wanted to connect the isdn pri to btu d , from the modem 1,2 will go to pair 8 og krone block and 4,5 will go to pair 6 in krone block.
Mar 14, 2010 | Lands Phones
Can I use ther Targus Adaptor for Inspiron 1525
On the long term, a power adapter with a bigger amperage can damage battery and battery charger.
Better to get an adapter with same specs as the 65/70W one , or an original replacemant:
Dell Inspiron 1525 New AC Power Adapter Supply $14.29 - Buy.com Dell Inspiron 1525 65 Watt Original AC Adapter $25.00 - parts4nb.com Dell Inspiron 1525 Power Cord PA-12 $16.95 - AmeriMax Advance
DELL Inspiron 1525 DC Power Laptop Adapter ... £25.23 - B2C Shopping UK DELL Inspiron 1525 Laptop AC Adapter power adapter £38.99 - Very Good Battery Dell Inspiron 1525 Ac Adapter Charger Power ... £16.50 - eBay UK
AU/NZ - DELL INSPIRON 1505 E1405 E1505 AC Adapter Power Supply
Dell : Lind Electronics 70-Watt DC Power Adapter for Dell Inspiron
Apr 22, 2009 | Dell Inspiron 1501 Notebook
Interconecting 2 Panasonic KX-TDA 200 & KX-TDA600
You are asking for some very advanced setup features, as far as connecting them you need the IPGateway cards. They are cat5 cards that will do the trick. However programming the setup to do what you want will be VERY time consuming and not to easy to walk someone through. On-site tech is highly recommended for that much programming and work.
Feb 24, 2009 | Panasonic KX-TDA0410 (KXTDA0410) Network...
Lands Phones Logo
309 people viewed this question
Top Lands Phones Experts
Ekse
Marvin
Marvin
Are you a Lands Phone Expert? Answer questions, earn points and help others
