Question about Philips Dvd Video Player
Won't open and have dvd inside
I have 2 of these players, and the neither will open and have dvd inside.... any ideas????
    Problem Solver:
  • 17 Answers
Well if they both dont open its due to the players little gears there either jammed,boken,or just plane need replacing try opening the player and moving the tray with your hands back and forth and try losening the little gears its should work
Posted on Apr 15, 2009
Tray won open
Mine did the same once and when i opened the top cover i saw 2 disks jammed inside. Try it and see. Hope it helps
Aug 18, 2013 | Toshiba SD-V392 DVD Player/VCR
DVD ' s tray won't open when pres OPEN, DVD is inside
There are little gears to open the tray with a little rubber belt that drives it you should be able to open door and pull on tray to get disk out if not unplug it take top off push tray out Cheapper to replace player than to fix but little flap should pull down grab tray and pull
Feb 21, 2013 | RCA DRC247N DVD Player
Portable DVD player won't recognize door is closed.
My guess would be that the switch inside that the tray hits to tell the dvd player it's closed is broken.
Aug 23, 2012 | Philips portable dvd player phillips...
WHY MY PORTABLE DVD WON'T PLAY
It won't play for one of two reasons:
1. There is something inside the DVD player, which keeps it from playing.
2. The DVD player's battery has run out of juice and can no longer play, meaning the player needs to be replaced.
Aug 06, 2012 | Curtis Sylvania SDVD7037 7-Inch Portable...
Why won't theTevion dvd player turn on
1) you must test the power cord for open , of course you must shure if the outlet box is o.k put a desk lamp for to see if work.
2) the fuse inside can be blown or c.breaker tripped reset.
3)swtich power dirty, or defective, replace
4) if doesnot work, the power supply inside is defective, transformer, diode, capacitor, go to the repair shop TV FOR FIX IT.
God bless you
Jul 15, 2012 | Televison & Video
Dvd door won't open
Someone is going to have to open the unit to see what is happening--either a disc is jammed inside or a mechanism problem.
Sometimes with unit apart you may be able to gently probe and free the jammed area--possible also something that does not belong there got inside--look closely.
Jun 16, 2012 | Daewoo DV6T-81N DVD Player / VCR Combo
I have a Panasonic DVD Video Recorder model DMR-E85H manufactured in 2004. It has worked perfectly for all these years but now won't power up at all. I have checked the only fuse I could find inside...
The power supply board is the problem, one of the most common failure is the 1000uf capacitor "open" located near the power transistor that is heat sinked, value may be higher or lower with one or two caps, the second possibility is the power transistor may be open or shorted.
Jun 24, 2011 | Panasonic DMR-E85H DVD Recorder
The tray won.t open
hi,
there maybe two types of occur . maybe problem with mechanism or with electronic side. remove the power and open the player.find out the belt inside the mechanism. if it found open or loose replace it. if it is ok may be the motor faulty or motor driver ic may faulty
ok
Dec 15, 2010 | Sony DVP-S9000 ES DVD Player
WHY WON'T MY DVD PLAYER WORK?
you can try this unplug the unit , you'll need alchohol, q-tips, screwdriver open it and look for all the flat cable connectors. be carefull and remove 1 side at the time ,and clean the contacts, put them back on , see if you can see the optic laser inside the mechanism it looks like a crystal eye, if you can reach it be gentle and clean the dust may it have. or buy at radio shack a cd cleaner. if after that your dvd don't work with dvds try a regular cd. if it plays music the laser its bad nothig else you can do. cheaper to buy a new one
Jun 10, 2007 | Apex Digital AD-1110W DVD Player
Televison & Video Logo
231 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
