Question about Actiontec GT704WG Wireless Router (gs583ad3-01)
HELP PLEASE ASAP
I have a home desktop (dell) and a second desktop (gateway). I have the wireless router and i want to set up a network. The dell is wired into the router via network cable and the gateway is accessing the routers internet through a wireless usb adapter. Thanks :)
  • kenton frederic Nov 26, 2007
    Having trouble adding wireless access to an additional laptop. Using Actiontec GT704WG Wireless Router. My PC receives internet via ethernet. Setup wizards can't seem to get me past a "connection with limited access", X'ing out internet.
    -staggerwing88
Is there way to update this router
ASAP
Posted on Jan 17, 2008
I CANNOT SET UP MY WIRELESS NETWORK
NO MATTER WHAT I DO IT WILL NOT EXCEPT MY PASSWORDS, EVEN THE ADMIN/PASSWORD
Posted on Dec 14, 2007
  • 12,061 Answers
OK well I think it is better to set it up like this... Connect the Modem to the Phone Line, Connect the Modem to the Router with an Ethernet Cable, Use a CABLE connection from the Main PC to the Router. (Ya gonna ditch the USB WiFi) Set that Main PC connection up to connect to the internet from the Main PC, thru Router thru Modem.... Then from Slave, install the USB adapter in this PC, and use this to connect DIRECTLY to the WiFi Router... and thus to the internet. This way will give the best transfer rates, and reliability
Posted on Sep 15, 2007
SOURCE:
Bt Homehub 3 + dell 1450 wireless router asking for network key
if the routor is wireless then the key is on the bottom or side of router. the ip address should be on it too and pass key to change the settings on the routher
Jul 01, 2017 | Dell 1450 (D1450U) Wireless Adapter
IP Address Conflict... So I have two computers at home. Two Dell Desktop computers running Windows XP. Both have USB wireless network adapters. I don't own internet (Don't shun me. My fam...
although I don't support IP Pirates(if they can afford not to be). there is one trick that may help but not if the security on the router is strong as they can set it to only hand out 1 number. However if you know the IP(192.168.0.2) that is being handed out. then you can manually set the wireless adapter on the second system to have an IP that is +1(192.168.0.3) (instead of a DHCP setting)of the number you are given. make sure the gateway and subnet mask is exactly as is handed out to the first system.
you can easily view this info. from a command prompt and typing:ipconfig /all
GL
hope this helps
Don't forget to vote for me
Thank You
Jammer
Aug 17, 2011 | Dell Inspiron 530s Desktop Computer
My daughters Dell inspiring computor no longer logs onto the Internet at home through our wireless network. It seems to have frozen onto an unidentified network from a public place and I can't seem to get...
The router's password is a Passphrase or the WEP or WPA orWPA2 encryption key. The Passphrase generates the WEP or WPA or WPA2 encryptionkey and this is in the router's wireless settings. To connect to your wireless router, it needs the router'swireless settings configured ie SSID, WPA or WPA2 encryption key and also thewireless cards in all the laptops and or computers needs to be configured withthese router's wireless settings. Then the laptops and desktop computers cancommunicate with your wireless router.
Mar 11, 2011 | Dell Computers & Internet
I unable to connect my desktop through cable but same time i can connect wireless connection with my labtop...now i request you please advise me n help me asap.....
Make sure your ethernet cable is connected properly into lan port and it is working fine.
Make sure in desktop networka dapter driver installed and enable.
ALso check ip settings in network adapter property it must be in your router network settings range.
Set gateway as your router ip in desktop .
if you want ip automatic from router then enable DHCP in router.
Let me know if you need further assistance.
Thanks for using FixYa.
Jun 27, 2010 | Computers & Internet
Can't connect work laptop to router (wireless or
Your work laptop probably has proxy settings in the browser. If yes, please remove it adn try. That should help .
Thanks
Ranjit
Jan 05, 2010 | Actiontec Electronics (GT724WGR) Retail...
I want to secure my network because my neighbor is using my connection. Can you please help me. I have tried all of the links I was told to use and 192.168.1.1 and nothing is working. Please please help...
to secure the wireless network , you will need to access the router set up.
You said that you tried all the links like 192.168.1.1, but nothing is working.
Did you check the IP address on the computer ?
First check the IP address on the computer and Default gateway number.
Default gateway will be the number that you will use to open the set up.
Click Here to know more about the router set up
Nov 12, 2009 | Gateway Wireless-B Router (wbr-100)
We have a Linksys G Router. It works fine on my son's (Host) computer. My work laptop will recognize the wireless network but will not connect. My home desktop will not recognize the network. What are we...
There are wireless networking capabilities of the gateway that will prevent or allow specific MAC Addresses from connecting to the network. Go into the wireless settings and adjust the settings to accept the MAC address from your work computer. To find the MAC address from your computers network adapter go into a command prompt by typing cmd in the run box and typing "IPconfig /all" in the window. The MAC address is there it may be called Physical Address. It is always a 16 set of number and letter combinations divided by ":" between every 2 sets of number / letters. On your home desktop this same window will help you diagnose the problem. Your son's computer will help you with this, do this on his as well and compare the IP address with your home computer the address could be something like "192.168.1.?" the last number is going to be unique if the first three numbers match. If the IP address on your home computer doesn't match the first three octets "192.168.1" it will not get out through the gateway. If they don't match you can force it to be on the same network by setting up a static IP address by opening up the Control Panel / Networking icon and finding the icon for the network adapter that you are using and opening it up and clicking on "Properties" and clicking on IPv4 and clicking properties and clicking on Specify IP address and typing the first three octets of your son's computer and adding a fourth number that isn't "0" or "255". You can use any number between those two numbers except those numbers, and isn't the same as your son's IP Address or the Default Gateway which is the Linksys. The "Subnet Mask" will auto install but will be "255.255.255.0". The default gateway and DNS server will be the IP address of the Linksys which most likely will be "192.168.1.1". Click "Ok" on all the open dialog boxes and the computer should be able to get on the internet.
Sep 17, 2009 | Linksys Wireless-G Broadband Router
Trying to take a new wireless built in laptop, home to my current wireless network. The new laptop recognizes my home wireless network, but unable to connect to it. The laptop is a Dell studio 17 and...
If you are hardly doesn't connect even your wireless station is been detected why not try to set your settings manually in your wireless card.
This is when you are behind a router.
Goto Network and sharing center. Click on Manage Wireless Network. Click on Adapter properties. Click Internet Protocol version 4. Click properties, then set the ipaddress of your laptop it doesn't have to be identical to any of your existing connection, your subnet, default gateway. And also input your IP DNS.
May 18, 2009 | Computers & Internet
Home network
please configure the router properly, see if you have enable dhcp on the router and the dell machine is may be using a static ip address, if that is the case disable the static ip from the dell machine and enable the get ip dynamically.
Nov 28, 2007 | Dell Dimension 2350 PC Desktop
SETTING UP WIRELESS NETWORK AT HOME
Yes your computer based on your model number should be able to support a wireless router.
Now... you did not specify if this is or is not a second computer that is trying to access the router which is hooked up to another computer and modem. If you are trying to access it you will need a wireless nic adapter installed on the Dell. To access the router. Please comment on what the case may be in your situation.
Oct 10, 2007 | Dell Dim.9150 Pentium D 820 Dual...
Actiontec GT704WG Wireless Router (gs583ad3-01) Logo
217 people viewed this question
Top Actiontec Computers & Internet Experts
Prashant M
Prashant M
Ekse
Are you an Actiontec Computer and Internet Expert? Answer questions, earn points and help others
