I need to change over all my VCR tapes to the latest reasonably priced technology. I need a system that will allow me to record a program on one channel and watch a different program on a different channel. So...please tell me what I need. Would it be something like this: I would like to purchase a dependable no problem easy to program DVD/VCR player/recorder with a TV tuner so I can change over all my VCR tapes to DVD. Or/and: I would also like to purchase the latest DVD system with a TV tuner (or whichever it seems will be the dominate surviving system: blue tooth or competitive model, which ever it seems will be the dominate surviving company)
  • 25 Answers
The best thing that you should do is to buy a brand new latest component. When you go for shopping inside the mall plenty of systems being sold by appliance center which fits your needs.
Posted on Apr 16, 2009
Vcr is eating the tapes
THE VCR NEEDS REPAIRING.THE REASON WHY YOUR TAPE IS EATEN THE TAPE PATH NEEDS RE- ALIGHNMENT AND LUBICATED AS THE HEAT FROM THE TV WOULD OF DRIED THIS OUT.
May 02, 2010 | Orion FTDV2004 20 in. TV/VCR/DVD Combo
Timed recording with cable (new)
If you're referring to programming your VCR for recording, that works just like it did before the cable box was installed, but with two major differences.
The first difference is that the VCR must always be programmed to record on the converter box output channel. Usually this is channel 3, but may also be channel 4. The cable box selects the channel from the cable system, but it's always outputting to your TV on the same channel. That channel is what the VCR needs to record from.
The second change to programmed recording is that you can't program your VCR to record programs on different channels. The reason is because, as mentioned above, the VCR is actually recording from the cable box which is always on the same output channel. Unless you are home to change the channel on the box, you're stuck. For example, if you want to record a show at 10PM on channel 8 and another at 11 on channel 26, those are the cable channel numbers. The box output is channel 3 (or 4) in both cases. The VCR can't switch the box for you. It's only going to record the program on the channel you selected before you left home. You also need to leave the cable box turned on, but the TV can be off. This is probably the thing most people find confusing about dealing with a cable box.
Now having said all that, some brands of cable box do include a timer feature of their own that allows you to program the box to switch channels. This feature is used in conjunction with timer recording on the VCR. You still always program the VCR to record on channel 3 (4), but now the box can be programmed as well to switch to the channel on the system you want to record. This allows you to get around the limitation described above. If your box offers this feature, it will be accessed through its setup menu using the remote control. Ask your cable company if this is available if it's not clear from the setup menus or instructions the installer left you with.
May 12, 2009 | Emerson Televison & Video
Can we tape digital feed on a VCR and play it on an HD-ready tv?
You should be able to accomplish this. Run the antenna to your converter box. Run the video and audio outputs of the digital converter box to the inputs on your vcr. Your vcr should then be able to record the program (select line-in as the channel when setting up the recording). Hook your vcr audio and video output to your tv.
It's best to use a converter box that has an event timer - this allows the converter box to turn on at a specified time and channel. Otherwise you will need to manually set the channel you wish to record on the converterbox, and leave it turned on.
Mar 10, 2009 | Mitsubishi HS-U560 VHS VCR
When I try dubbing from VCR to DVD the machine will only record about half of the VHS to the DVD. I get the following message...Recording Error - this program is not allowed to be recorded. The cause...
The DVD AGG (automatic gain control) is somehow being fooled into thinking the non-commercial tape has macrovision (copy protection). Is this a relatively inexpensive machine?
Mar 08, 2009 | Philips Magnavox MWR20V6 DVD Recorder/VCR
I cannot program the vcr to record i just do not know how to I can play tapes or wath the disk but cannot recore
make sure the tv is on channel 3, and the vcr also on channel 3 -if trying to record from cable or satalite. then make sure tape is rewound all the way. do a test by hitting record on vcr. let it record for a few minutes. rewind it, then just hit play. Dont change any channels until you are ready to record the program of choice. After this test. And recording is successful. Rewind the tape again. And change the channel to your choice. Hit record at time of or go into menu of your vcr and set up a time to record shows.
Jan 04, 2009 | Symphonic WV806 DVD Player/VCR
Recording problem on VCR
try cleaning the heads in the vcr. also use a new tape at least once a week.
Oct 21, 2008 | Televison & Video
Taping
If there is no coaxial cable input on VCR, then it should work by RCA cables. Which is the Yellow , red/white cables. On the back of the VCR. Take a set of RCA cables Yellow for video, red/white for audio to the VCR output.Then do the same to the Television input. Next use the television remote to turn the TV to Video input this will allow you to view what's playing on VCR. Then take another set of RCA cables and reverse the first setup. Attached Cables to VCR input and cables to TV Output. This will allow you record what's on television. Now make sure the cable is screwed to coaxial cable input on television. This will able you to access cable programming on television, view vhs tapes, and record programming directly from television.Good Luck
Oct 12, 2008 | Televison & Video
Picture blinking on a Sharp Quos HD TV
A lot of times with recorded tapes, the tape that's inside doesnot work well with vcr s. I have had this problem with old and new vcrs and if you keep trying then the device will eventually eat the tape.....
Apr 10, 2017 | Televison & Video
Taping to a VCR post converter hook-up
cant you just turn the channel on your DCB and then record on the vcr?
Jun 11, 2008 | Insignia Digital-to-Analog Converter for...
Adapter question
There are no such adapters that would allow 8mm, Hi8 and Mini DV tapes to be played in a VHS VCR. Only the old VHS-C tapes can fit and play in an adapter. There are several reasons why 8mm (or Hi8 and miniDV tapes) cannot be physically played in a VHS VCR: 1. 8mm (Hi8, miniDV) is a different format with different technical characteristics than VHS. These formats were never developed with the intention to be mechanically compatible with current VHS technology. 2. 8mm/Hi8 tapes are 8mm wide (miniDV is 6mm wide), while VHS tape is 1/2" wide, making it impossible for a VHS video head to read the taped information correctly. 3. 8mm/Hi8/miniDV tapes are recorded and played at different speeds than VHS, so even if the tapes could physically fit into a standard VHS VCR, the VCR still couldn't play back the tapes at their correct speeds. 4. 8mm/Hi8/minDV audio is recorded differently than VHS. 8mm/Hi8 audio is recorded in AFM HiFi mode, while miniDV audio is recording in 12-Bit or 16-Bit PCM digital audio format. So, even if the video could be played back in a VHS VCR, the audio could not be read properly. 5. 8mm/Hi8 video is of higher resolution than VHS and is recorded in a different bandwidth length (miniDV video is recorded digitally), so once again, a standard VCR still could not read the information correctly, even if the tape could fit into a VCR.
Sep 06, 2005 | Samsung DouCam VP-D5000i Mini DV Digital...
Televison & Video Logo
44 people viewed this question
Top Televison & Video Experts
Electro Med Services...
