Question about White Sewing 1409 Mechanical Sewing Machine
What numbers are the knobs supposed to be set on?
I don't know how to adjust the tension for flannel.
  • 128 Answers
Flannel is a light - mid weight fabric. If your tension dial goes to 8 , set your tension between 3-5ish. Try that and just tweak it to either side to get a smooth stitch on either side of yhour fabric.
Posted on Apr 22, 2009
How do I set the bobbin tension
How to change the tension on a sewing machine?
Adjust your top tension if it's too tight. To decrease your top tension if it is too tight, turn your knob so the numbers are decreasing. Try ½ to 1 number lower, then test the stitches on a piece of scrap fabric. Continue until it looks even on both sides and you can no longer see the bottom thread on the top.
How to Adjust the Tension on a Sewing Machine: 13 Steps
www.wikihow.com/Adjust-the-Tension-on-a-Sewing-Machine Search for: How to change the tension on a sewing machine?
https://www.google.co.uk/webhp?sourceid=chrome-instant&rlz=1C1CHBD_en-GBGB719GB719&ion=1&espv=2&ie=UTF-8#q=Sewing+Machines+How+do+I+set+the+bobbin+tension ..try this link
Dec 04, 2016 | Sewing Machines
Bernina activa 130 tension loose after needle breaking into bobbin area
Is it the bobbin tension that is very loose? Try tightening it. Also check that the bobbin has been installed in the bobbin case, turning the correct direction and that the bobbin tension is threaded properly.
Bobbin Tension How and Why Tension is Adjusted
Understanding Bobbin Tension
Understanding Thread Tension Threads
If it is the upper tension that is loose and creating "thread nests" under the fabric, the machine is either misthreaded or possibly the thread is not seated completely in the tension disk.
Remove the upper thread from the machine.
ALWAYS RAISE the presser foot and rethread the upper thread from the beginning--verify the thread path is correct.
Set the upper tension to the midway point between high & low number (the factory standard--although it may need tweaking later for your particular machine).
Retest your machine. Hopefully, the issue has been resolved. If not, it may need service.
Tutorials Urban Threads Unique and Awesome Embroidery Designs
What causes Bird Nests Superior Threads
Sewing Machine Thread Bunching Up Here Why
Oct 03, 2016 | Bernina Activa 130
How do I set the tension on the thread?
THREAD TENSION ADJUSTER IS A NUMBERED KNOB WHERE YOU PASS THE THREAD BETWEEN ""TENSION WHEELS"" IN
FRONT OF THE MACHINE VERY NEAR AND ABOVE WHERE YOU THREAD THE NEEDLE
Oct 19, 2014 | Consew 226R-1
What is the tension settings for normal over locking with the Elna 4de
First of all ensure that the serger is threaded correctly.
The two setting which you mention are really a 'range' for an 'average' setting.
Using 'average' fabric such as a medium weight cotton, flannel, etc.; set each of the tensions in the middle of the range and test the stitch. There may be minor adjustment required to get a perfect stitch.
Once you have stitched that first sample, here are some possible minor adjustments required:
1. Tear-drop shaped loops on the underside: Check that the thread is firmly set in the tension dial by giving the needle threads a good snug pull above the tension dials while the presser foot is down.
2. The zig-zag like thread on top should meet the ziz-zag like thread on the underside right on the fabric cut edge. If the meeting happens on top: reduce the upper looper tension slightly and increase the lower looper tension slightly ... test sew and recheck. If the meeting is on the underside: increase the upper looper tension slightly and decrease the lower looper tension slightly ... test sew and recheck.
3. If the meeting does happen along the fabric cut edge but the meeting is hanging beyond the fabric cut edge: increase the blade position (that is, move the blade to the right). If the fabric is creating a ridge or tunnel; move the blade to the left slightly.
Please let me know if this has solved your problem. Otherwise let me know what is happening with the stitch quality.
Sep 16, 2014 | Sewing Machines
I have a VX1250. I don't know how to regulate the tension.
There is two places to adjust thread tension: the top tension device controls the top thread tension and is usually a dial or knob with numbers on the front of the machine.
Then there is some form of tension device on the bobbin; in your case I believe the Brother has a removable bobbin case with a tension spring which holds the bobbin thread firmly: the tension spring can be adjusted with a screwdriver but once set, you shouldn't need to adjust this much, just alter the top tension slightly for different weights of fabric. So start by setting top tension dial to 4-5 and test stitch a seam. Use different coloured but the same type of thread top and bottom and take a look at the seam. You want to see a balanced even seam.
Here is a link to a great info site for this:
http://www.sewusa.com/Sewing_Machine_Repair/Thread_Tension_Settings.htm
If the bobbin thread is too loose, then you probably will need to finess the tension spring on the bobbin case and adjust this slightly. The best way to set the tension on the bobbin case is as follows. Load the bobbin into the bobbin case and pull the thread tail into the tension spring, then suspend the bobbin by holding the thread tail up in the air (the dangle test). You want it to be just tight enough to hold its own weight, but still able to release thread when you pull gently downwards on the bobbin case. If it isn't doing this then take your little screw driver and adjust the screw on the leaf tension spring by ONE QUARTER TURN ONLY. Lefty looser, Righter Tighter. Then test again, and adjust again until its right.
Now test stitch again and finess your top tension to get the seam even. Remember to change the needle for each new sewing project too; this will impact tension also.
Jan 04, 2012 | Brother Sewing Machines
Pfaff varimatic 6091 sew a rag quilt with jean and flannel,I can't get my tension right it seems to be funny on the bottom stitch,where shoulf the top tension be set at 4 1/2 ,when do I adjust the bobbin...
Hi! The bobbin tension rarely needs to be adjusted. First, make sure you're using the appropriate size needle and thread for your fabric (I'd probably use either a 'denim' needle or a universal size 14) and also that the upper thread and bobbin are threaded absolutely correctly. These can throw off the tension! Also, take the time to clean out the bobbin area. That can throw your stitch off also.
If the stitch on the bottom is loose, so that you see the top threads, then the top tension is too loose. If the top stitch is too loose and you see the bobbin threads on top, then the top tension is too tight.
It helps to thread the machine with different color thread on top and in the bobbin, and then stitch an inch or so on the same type of fabric as you're using in your quilt. Check the stitch. If you need to adjust the top tension, make sure the pressure foot is down! Adjust a little, stitch a few inches, and check again. Repeat until you don't see any (or very little) bobbin thread on the top or top thread on the bottom.
If you go through all these steps, and the bobbin thread is still loose (and you've tightened up the top tension), then there is a tiny little screw on the side of the bobbin case that you can use to adjust the bobbin tension. Turn the screw just a little bit (less than a quarter turn), stitch, check, etc. Once the bobbin tension is set, you shouldn't ever have to change it.
Let me know if this helps, ok?
Happy sewing!
Feb 10, 2010 | PfaFF Sewing Machines
I want to know which knob I use to make the stitching narrower
there are generally two variable controls .. one adjusts the stitch length (distance between stitches measured in stitches per inch) ... the second is stitch width .. that adjusts how far the zigzag moves left and right .. thats usually just a number from 0 to 10 or so .. 10 would be maximum width .. 0 would be used for straight stitch ..
so you need to adjust the stitch width control to make the stitching narrower .. the controls are called different things on different brand sewing machines .. if you have the brand and model number then there may be instruction booklets available ...
Jan 04, 2010 | Sewing Machines
I am having trouble adjusting the 4 knobs at the top and the 2 on the side. What do the numbers (1-9) signify? and how do I adjust the tension?
Check there is no thread or lint in the 4 tension units.Tension for threads (1 - 9) should be all set at 3 ... this is the factory setting.
The two knobs on the side are: Stitch length regulator, set at 2.5 for most purposes.
Differential feed is the other knob and it is used to feed left or right at a "different" rate, rather than evenly....for around arm holes etc where a curve is required.
Sounds like you need to just play with some scrap to see how things go, and get yourself a manual for the fine details.
Aug 26, 2009 | Janome MyLock 644D
Hello I have misplace the manual for my Janome 234D. I bought it a few moths ago and i set all the tension right and had it going good. But my young grand daughter got to it while i was out and turned all...
Tensions all should be set at "3" for general sewing if there is no other damage or lint trapped in the tension discs.
Try "flossing" each tensioner with a piece of cloth to remove lint.
If you are still uncertain, try 4 different colours and with all set at 3 to begin, adjust to suit what you see to be loose or tight (small adjustments each time)
If the little one has removed the knobs (they just pull off towards you) and turned the white adjustment wheel beneath, you need to set until happy as above, then put the outer knob back with number 3 in the 12 o'clock position.
Best of... www.bargainbox.com.au
Nov 26, 2008 | Sewing Machines
White Sewing 1409 Mechanical Sewing Machine Logo
171 people viewed this question
Top White Sewing Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Are you a White Sewing Sewing Machine Expert? Answer questions, earn points and help others
