Getting Fatal error 020 on my Okidata 7300 printer. How do I fix.
Getting a Fatal error 020 on an Okidata 7300 printer. what is it and how do I fix it
    Problem Solver:
  • 9 Answers
A 020 error is the TNY on the controller board. If you take the controller board out (it's the board that the usb/network cable plugs into). You find 2 banks. Ones for memory, the other bank is your prom board they refer to as a TNY.
Call Okidata, order a TNY for the C7300, probably bout $130.
Posted on Oct 31, 2009
  • 95 Answers
You could take the controller board and reseat the dimms. But the Rom Dimm is usually bad and needs to be replaced.
Posted on Apr 15, 2009
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 76 Answers
Rom issue
Posted on Nov 02, 2013
What is the problem on a okidata C5300 error codes 020
This code relates to a fatal error with the ROM. You may want to contact Oki # 800-634-0089 and see if they are willing to help.
Aug 14, 2014 | OKI C5300n Led Printer
I have changed the fuser unit in a okidata c9300 and still getting a 174 fatal error. how cani i fix this problem?
First of all unplug the printer from the mains (safety first). Get the toner out again and check for dirt on the contacts. Also check the contacts inside the printer itself.
In case of a problem or clarification, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs".
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
May 11, 2010 | OKI C9300 Led Printer
925 fatal error
www.okidata.com/canada_en/downloads/C9600_Bertl_4Stars.pdf
all in manual above. http://www.okic3200n.co.uk/index.asp?printername=C3200n&menumode=0&content=errorcodes
error codes above.
Your printer display or status monitor may read "Fatal Error". This simply means a problem has occurred requiring action to clear.
A "Fatal Error" does not mean your printer will "die". Fatal Error explanations are not usually found in the User's Guide or Handy Reference Guide.
RECOMMENDED NEXT STEP: First, try turning off your printer then turning it back on. If this does not clear the message or remedy the problem, check to see if your printer is on a power strip (or not plugged directly into the wall). For testing purposes, be sure the printer is plugged directly into the wall. Often, the issue is power-related.
Second, if the issue persists after this, write down the message (including the 3-digit error code number) and email us at "support@okidata.com" or call Oki Data Customer Support (1-800-654-3282) for assistance.
NOTE: If you see a series of letters and numbers(scrolling across the display) after the 3-digit error code, be sure to write these down also and report them when call or emailing Customer Support.
May 08, 2010 | OKI C9600hdn Laser Printer
Fatal error : 144 on a Okidata
this is indicated when the toner feed switch error
or the toner locklever-open error occurs repeatedly when new toner is used.
it has to do with the yellow.
3 possible solutions.
Confirm that the lever is in position.
Replace the toner feed unit.
Replace the ID units.
Aug 28, 2009 | OKI C9600hdn Laser Printer
I just replaced the fuser unit in my Okidata 5200 and it will print for awhile and then stop with a fatal error #177. How do I fix this?
lift your top cover up and check the ribbon cables to the black leds (4) under the cover 2 on each led, these have been known to be loose and cause those fatal error codes
Jul 09, 2009 | Office Equipment & Supplies
Fatal error 980 OKI C5500 printer
I had a paper jam and removed the jammed papers. The paper jam cleared and then the Fatal Error 980 appeared. OKI C5500 printer
Mar 15, 2009 | OKI C5100n Laser Printer
Fatal Error
unplug and plug back in.
Jan 15, 2008 | OKI C5150n Led Printer
Service Call 020 Fatal Error
Error 020 is a ROM dimm error, could be as simple as reseating/replacing Rom Dimm or a expensive main PCB, you need to get hold of a oki dealer, contact oki to find closest OKI repair agent.
www.oki.com
Jan 08, 2008 | OKI C9300 Led Printer
Fatal error
That is a control board error.
i dont think that it would be hard to change out.
but the board price may deter you from fixing it. Considering it about 5 or 6 years old.
here is a list of parts for your printer. I cant find prices for it . you can call Okidata for it.
http://belgium.oki.com/binaryData/20824/c515300_rsplddr1.pdf
Nov 04, 2007 | OKI C5300n Led Printer
641 people viewed this question
k24674
jasbo
jasbo
