Question about Dishwashers
The last one to two inches of water does not drain out
Brand new dishwasher, used 3 or 4 times and worked fine, now the last inch or two of water does not drain out at the end of the cycle. help please
  • 10,865 Answers
It sounds like you have something in the small water pump at the base of the dishwasher that pumps the dirty water through the hose into your sink drain. Remove the lower front panel of the dishwasher, unscrew the hose clamp and pull off the hose, then unscrew the pump so u can inspect it. Usually you will find a chunk of glass, or bone or other debris which is blocking the pump partially.
Posted on Apr 15, 2009
Dishwasher won't drain completely. Several inches of standing water left after last cycle
Sounds like the wash/drain selector valve might be stuck. my Kenmore operating solenoid rusted and hung up. I cleaned and oiled it up. You can also have something that got into the valve and it won't close, or an obstruction in the drain hose or the drain pipe connector. Something is restricting the flow or the pump itself may have a bad impeller. Does it wash with vigor or has it lost a little oomph and sound different? Does it leave any debris on the dishes?
Jan 25, 2012 | Dishwashers
Brand new dishwasher, installed last week. When it is done there is quite a lot of water standing in the bottom of the tub. It has only been run 2 times since installed and both times several inches of...
First was a new garbage disposal also installed? There is a knockout on the garbage disposal where the drain hose connects to.
If that is not the problem make sure it has the correct high loop or also called air gap. If that is not right water can siphon back into the dishwasher. Both are common mistakes usually made by begginers. Here is a link for the correct High loop installation
Oct 26, 2010 | KitchenAid KUDC03IVWH Builtin Dishwasher
DIshwasher doesn't drain. 3-4 inches of water sits in the bottom
A clog in the drain line or air gap (if there is one) is the usual reason that a dishwasher won't drain. Often the problem is at the point where the drain line attaches to the garbage disposer or household drain line. If you remove this line, you can clear any debris from the hose or hose connection. Be sure to reattach the hose before starting the dishwasher again.
Many dishwashers use a drain valve with an electric solenoid. When electricity flows to the solenoid, the valve opens and diverts the water to the drain. Sometimes the solenoid, or the diverting lever, sticks and prevents the dishwasher from draining or filling properly. Try to free up the solenoid to lubricate the lever. Otherwise, you may have to replace the solenoid or pump assembly. With these systems, the motor always rotates in one direction. When it's energized, the drain valve diverts the water.
Other dishwashers simply reverse the direction of the motor to drain the dishwasher. These units don't have a drain valve. Instead, there's a drain hose connected directly to the pump housing.
Sep 25, 2009 | KitchenAid 24 in. KUDI01FLSS Stainless...
Same problem. 2-3 inches of water left in the dishwasher at end.
Inspect for plugged drain screen. Sometimes you have to take apart the bottom area for access...
Sep 18, 2009 | Bosch 24 in. SGS47E02 Exxcel Free-standing...
Bosch SHE4AM
i would check to see if you are using the factory drain hose or if you have extended the hose to reach the sink drain.
the only other thing that might cause this would be a restriction in the hose at the drain pump outlet, but check the drain hose first.
Sep 15, 2009 | Bosch 24 in. SHE44C02UC / SHE44C06UC /...
Doesn't drain; glasses have film; rinses with used, soapy water
The white film problem is hard water. There is a new product out called the dishwasher filtration system. It filters the water before it enters your dishwasher. It works amazing and has a money back guarantee. You will love the way your dishes look after the first load. It is also very affordable (like 70 bucks). Go to www.dishwasherfilter.com to find out more info.
Sep 02, 2009 | Dishwashers
Leaky Dishwasher
The dishwasher was installed with a defective fill valve or the valve was damaged during installation of the dishwasher.
Jun 23, 2017 | Magic Chef 24 in. DC4000 Free-standing...
Brand new dishwasher will not drain at end of cycle.
Check your manual. Some dishwashers actually do leave water in them after the final drain cycle. It has to do with the type of seals they use. Some will leak the very first time they are used but not after that. The seals in these types must remain wet. If this isn''t the issue, wait about 5 minutes fir the timer to finish. Sometimes there is quite a lag at the last cycle. If all else fails, call the customer service number in the manual.
Feb 02, 2009 | Haier ESD300 / ESD301 Built-in Dishwasher
Hotpoint Dishwasher
have you tried adjusting the feet on the front of the washer so it is tilted back slightly .This will stop the water from coming over the little lip on the front of the machine. Some dishwashers also use a little amount of water in the bottom when drying asthis helps to curculate the heat ; leave the washer to complete it's cycle and it should beep to let you know when it is finished
Dec 09, 2007 | Dishwashers
MACHINE DOESN'T CYCLE OUT OF RINSE
Does it spin if you move the timer manually? ist it being used on a delicate cycle@? if so it will stop in the last rinse water
Jul 10, 2007 | Ariston Technologies AWD 121
Dishwashers Logo
95 people viewed this question
Top Dishwashers Experts
Owen Barnes
