Question about Vacuums
The screw that holds the handle to the top of the canister came completely loose. How do I get to it to reattach?
The screw that holds the handle to the top of my canister came completely loose. How can I get to it to reattach?
    President:
  • 1,865 Answers
Buy a epoxy cement and fill the hole with it, then drill a hole a little smaller than the screw, and finally insert screw.
Posted on Apr 15, 2009
Loss of suction
DYSON DC08 ROOTCYCLONE Loss of suction problem.
I had this exact problem and solved it.
No offense to Dyson Customer Service, but that advice isn't nearly enough to explain how to clean the cyclone. I used to work in Customer Service for an electronics company and I never let anyone down because of clear and precise instructions.
So, here is my advice:
NOTE:
Remember properly where all the screws go and how the bits fit together. It's important so that there is no loss of suction due to improper replacement of parts.
Step 1
Remove the canister from the vacuum cleaner and take off the clear bottom bit - the container for dirt. Clean that out well, you can use water but MAKE SURE IT DRIES COMPLETELY.
Step 2
Pop off the conical bit at the bottom of the cyclone. It isn't held by any screws, just nudge it out of place.
Step 3
You will see three holes amongst the vacuum entry holes. These three holes have screws in them. Unscrew those.
The type of screws used are star-like, but I used a small flat-head screwdriver. Make sure the edges of the flat-head fit perfectly into the edges of the slot on the screw. This prevents grinding and damaging the screw.
Step 4
Turn the canister over, the grey handle conceals three screws. Two on top and one beneath the bottom of the handle at it's base. When you remove the two screws that are visible, you can gently pop off the handle from the canister. First pull the handle up slightly, then the hook unlocks at the base, then push the handle away from the air inlet hole.
Step 5
Turn the canister over again. The bit where you removed three screws should come off easily. Beneath that, you will see two more screws, holding the top bits together. Remove those screws.
Then, all of the cyclone is loose and you can clean each bit separately. Again, you can use water, but let it dry very well.
Step 6
Put it all back together.
Apr 13, 2010 | Dyson DC08 Cylinder Bagless Canister...
Frayed power cord on electrolux canister vacuum
1 screw in the front, two in the blower port. take them out and the top bezel comes off. one screw in the bottom and two on the top. need a flat blade screw driver to pry out the cord reel. 4 screws holds the sheild of the reel. take them out and there is a snap ring that hold the reel on the shaft. the reel assembly and drum spring comes out at the same time. 3 screws on the bottom of the reel holding a metal plate and there is also snap ring hold the spring on the metal plate take that off and will expose the cord connection. unhook the the cord and untie the knot and replace the cord and reverse the process
Oct 04, 2009 | Electrolux UltraLux 2000 Bagged Canister...
Handle release catch out of place.
I just took mine apart, and there is rounded grooves on both sides of the base for the upright section to rest in. When I put it back together, it naturally pulled out of those grooves and laid back flat. I had to hold it in the grooves while reattaching the screws. The piece that comes off and allows the upright enough movement to come out of the grooves is on the top of the base in the back middle. There is one screw on the front of it, and then 4 screws in the back of it. If your upright section appears to be not in the grooves, remove those five screws, place it in the grooves (it'll have to be slightly elevated---can't lay it all the way flat or it'll come out) and reattach the screws.
May 06, 2009 | Bissell Lift-Off(R) Revolution(R) Turbo...
Replacing broken handle on filter queen vacume
It is always best to have a cirtified & Authorized Service Tech or Center do the work and only with genuine Filter Queen parts and supplies. Both can be found at 800-344-1840 or in Iowa 888-637-4692
If a Authorized Tech can not come out,
  1. Always unplug unit from electric outlet.
  2. Remove top like you were changing filters, also the crown.
  3. Remove cap under handle.
  4. Remove 3 screws from SN plate then remove plate.
  5. Seperate upper from lower.
  6. lift cardboard piece and Silencing Filter.
  7. Now you can remove the 4 screw that hold the handle.
  8. Repace handle and reverse the above steps.
FQ Master
1-888-637-4692 in Iowa
Your Authorized Filter Queen Service & Supplies
Apr 04, 2009 | Filter Queen Majestic Canister Vacuum
Older electrolux on/off switch
I'm not exactly sure which model you have, but I'll take a guess. Usually there are four screws that hold the cover on the top of the machine. One in the very front, one in the handle, and then two under the sliding exhaust cover near the rear. There are variations of this but it's usually the two exhaust screws that get missed. Good Luck!
Jan 01, 2009 | Electrolux UltraLux 2000 Bagged Canister...
Dyson DC07 vacuum.
you have to remove the hose and wand then you can get to the clip that holds the canister on the machine and with a screw driver gently prise it of the machine
Aug 30, 2008 | Dyson DC07 Bagless Upright Cyclonic Vacuum
ELECTROLUX model 1623 switch replace
Hi jjda..slide the strips/bumper...maybe it's hard to slide off...but try again...this week-end i open my 1623 too...no screws..just the strips hold the top and the base together..good luck!...Joel
Jul 08, 2008 | Electrolux Vacuums
Bosch BUC11700UC Cyclone Jet Upright Bagless Vaccum
I had the same problem. I ordered a new switch from a local appliance place part#417915 (also try 54542), but it can be found on-line for ~$2+shipping. There are 11 screws to remove. Remove all nine screws that hold on the back of the handle (be sure and get the two under the attachment holder). Remove the two screw from the front that hold the top dirt canister retaining bracket. Once you have the back of the handle off, you can remove the single screw at the top of the handle that holds on the top front where the switch is. The front will then 'snap' off.
The wires are soldered to the switch, and there is absolutely no slack in the wires, so I don't recommend that you cut them. Be very careful with the new switch, since the tabs on back can break off very easily if bent too much (speaking from experience). You might also want to order, and keep and extra switch, around for the next time you need to replace it (it will wear out again).
Instead of soldering the wires to the switch you might want to try using some push on female spade connectors (small), but be sure they are insulated. This will make the next replacement much easier.
Apr 08, 2008 | Bosch BUC11700UC Cyclone Jet Bagless...
Eleectrolux canister sweeper power switch
There should be screws holding the handle asembly on to the top. One near the from, another by the handle, then slide the door near the back, there are 2 more screws there. with the handle off, you can get to the switch. Hopefully you can fina a replacement, alot of parts for the older Electrolux is No Longer Available.
Feb 12, 2008 | Electrolux Guardian Bagged Canister Vacuum
Hep! My 3 month old Hoover Mach 5 doesn't pick up!
What is happening is the secondary filters, HEPA and the canister all need to be cleaned. This is vital. What the vacuum repair people are keeping from you is that tidbit of wisdom. This particular vacuum is picky about airflow. Pull the canister, and on the body of the vacuum on top of where the canister sits are the secondary filters. There should be a sticker explaining how to remove them. Clean them throuougly, mine was filthy. Make sure you clean the canister by unlocking it and cleaning out the micro holes and the cone end. Mine was completely plugged. Now brush the dirty side of the HEPA filter with the combo tool. Let the secondary filters dry completely (you can blow dry them on cold) Re-install everything, and the vacuum will run like brand new. I vacuumed the whole house after I completed this maintainence and it works like a champ. Don't return this vac until you clean it completely.
Feb 06, 2008 | Hoover Commercial C1660-900 Bagless...
Vacuums Logo
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
