Question about HP PSC 1610 All-In-One InkJet Printer
"Printing" but nothing comes out......
I loaded the software correctly. I followed all the directions. When I clicked on print the screen on the printer just flashes "printing..." and the green light is flashing but nothing is coming out of the printer!!! HELP!!!
  • r0ck3r Dec 05, 2007
    hi. similar problem but i have a cannon s520.I installed the printer, I replaced the cartridge. says it's printing, printer takes page through but not ink on paper. Is there something else i need to replace. Thanks
  • Anonymous Jan 25, 2008
    I think that I am the only one left on the planet to own an HP officejet 4110 all -in-one.I cannot find it anywhere on the website.I have had it for several years and no major problems at all. Every now and then what I print goes into queue and will not print.I then delete all that is in queue,reboot the computer and all is well but not this time....my response is "printer is offline"....the printer is on and i am able to do a test print from the printer but not off my laptop.....HELP!
    sharon
    Chemainus B.C Canada
    Problem Solver:
  • 35 Answers
Hey dear you did not describe the full detail. Light is continuously blinking and nothing is coming out from the printer OR printer is not printing anything. If the printer is not printing anyting and light continuously blinking. It means printer is not properly getting the data. You have to change the 'encoder' (a transparent strip goes through the carriage) and you have to clear the round transparent encoder present left side in the mechanical with wet cotton. After this your printer will work smoothly.
Posted on Sep 25, 2007
Canon load correct paper
•When copying or printing received faxes, check the following:
1. Paper loaded in the machine
2. The paper size specified in <PAPER SIZE> for <CASSETTE> or <MP TRAY>.
•When printing from a computer, check the following:
1. The paper size specified on the printer driver screen
2. Paper loaded in the machine
3. The paper size set in <PAPER SIZE> for <CASSETTE> or <MP TRAY>.
Oct 15, 2013 | Office Equipment & Supplies
Paper won't feed
Inside of the machine is dirty.
If the inside of the machine is dirty, the printed paper may be smudged.
Follow the steps described below to clean the inside of the machine.
1. Ensure that the machine is turned on and there is no paper loaded in the Auto Sheet Feeder.
2. Place A4/Letter-sized plain paper in landscape orientation, horizontally fold it in half.
3. Unfold the paper, and load the paper in the Auto Sheet Feeder with the inverted-V edge down.
4. Select <Bottom plate cleaning> from <Maintenance>.
5. Select <Yes> on the Bottom plate cleaning confirmation screen and then press [OK].
Paper will be ejected.
If protrusions inside the machine are stained, wipe ink off the protrusions using a swab or such like.
* Important
Before cleaning, be sure to turn OFF the machine.
Paper feed roller is dirty.
Follow the steps described below to clean the paper feed rollers.
1. Ensure that the machine is turned ON and there is no paper loaded in the machine.
2. Select <Roller cleaning> from <Maintenance>.
3. Select <Yes> on the Roller cleaning confirmation screen and then press [OK].
The paper feed roller will rotate as it cleans.
4. Repeat this operation twice.
5. Load three or more sheets of A4/Letter-sized plain paper lengthways in the Auto Sheet Feeder.
6. Select <Roller cleaning> from <Maintenance>.
7. Select <Yes> on the Roller cleaning confirmation screen and then press [OK].
The paper that is loaded in the machine will feed through the machine and be ejected.
8. Repeat Steps 5 to 7 three times.
Inappropriate paper type is used.
Check to see if the paper you are printing on is too thick. See Paper Types You Cannot Use.
Note that smudging may occur at the top and bottom edges of the paper when using Borderless Printing. Ensure that the paper you are using is compatible with Borderless Printing.
Thick paper is used.
When printing on thick paper, set the Paper Thickness Lever to the right.
This widens the gap between the FINE Cartridge and the paper. Try this maneuver if the printed surface is scratched.
Media is curled.
If all four corners or the printing surface of the paper is curled, the paper may become dirty or may not feed properly. Use the paper after correcting paper curl as follows.
1. Place the printing surface face up (A), and cover it with a sheet of non-printing regular paper to avoid damaging the surface.
2. Roll up the paper in the direction opposite to the paper curl as per the figure below.
3. Check the printing paper to confirm if the paper curl is eliminated to within approximately 2 to 5mm / 0.08 to 0.2 in (B).
It is recommended to print on curl-corrected paper one sheet at a time.
The media type is not selected correctly in the printer driver.
On the [Main] tab of the printer driver, ensure that the [Media Type] selected matches the paper loaded.
In the [Print] dialog box of the printer driver, select [Quality & Media] from the pop-up menu, and then ensure that the [Media Type] selected matches the paper loaded.
Paper is loaded incorrectly.
Load in the portrait orientation regardless of the print direction of the Auto Sheet Feeder.
Ensure that paper is loaded correctly. Slide the paper guides against the paper stack.
Oct 18, 2009 | Canon Pixma MP500 All-In-One InkJet...
I am using a S4m printer to print on non zebra labels, by direct printing ( not thermal paper) I cant get what i'm printing to print in the middle of the page. I have tried every possible setting but I...
You need to make sure the printer is calibrated correctly. If you press the feed key, does one label come out and stop at the gap? Do the labels have a black mark on the back of the liner? This would tell us if the printer is set correctly. (Mark or gap). We need to make sure the labels are loaded correctly and the printer is set correctly. Then we move to driver and software settings. I have 10 years experience working for Zebra, so I will get you the resolution once we determine the current setup.
Oct 16, 2009 | Zebra S4M Thermal Label Printer
Added small business server. IRC 2550 will no longer print.
Most IRC2550's come standard with UFR printing and not PCL or PS3. If either or the 2 are installed instead of the UFR driver, it will act as if the print is going to the printer but nothing will come out. Verify which driver is installed and if needed, load the correct one.
Here is a direct link to that models download page Click Here
Aug 27, 2009 | Canon iMAGERUNNER 2830 Copier
Getting "printing application has stopped working"messaage
You will need to uninstall and reinstall the printer driver. Please follow the steps given below:
To uninstall:
1. Click on "Start" and "All Programs."
2. Go to the "Lexmark " " Series."
3. Click on "Lexmark Uninstall."
4. Click on "Next."
5. Click on "Finish."
6. Click on "Restart Windows."
To install:
1. Make sure no other programs are open.
2. Insert the CD and wait for the installation window to appear.
3. Connect the USB to your computer when prompted to do so. If an "Add New Hardware Wizard" appears when the cable is connected click on "Cancel."
4. Click on the "OK" button on the Install screen to begin running the software. Follow the prompts and accept the Licensee Agreement to allow the software to load.
5. Once the software has loaded, click on "Finish."
6. Once the software has loaded, you will be able to click "Finish." Your software is now installed.
Aug 24, 2009 | Lexmark P4350 All-In-One InkJet Printer
Not able to print directly on CD/DVD
Printing Directly onto a CD or DVD in Roxio Express Labeler
  1. Make sure that the product is turned on and that the USB cable is connected to the product and the computer.
  2. Click Start , click All Programs , click Roxio , and then click Roxio Express Labeler v3 .
  3. Click Disk Label , then click Options . Figure 1: Options c01452912.gif 1 - Options button
  4. The Options screen appears. Figure 2: Options screen c01452913.gif
  5. Make sure that LightScribe 12cm Disc is selected from the Disc Label menu, then click OK to return to the Roxio Express Labeler window.
  6. Click Disc Titles , type the title and subtitle for the CD or DVD, and then click OK . Figure 3: Disc Title option c01452914.jpg 1 - Disc Titles button Figure 4: Edit Disc Title screen c01452915.gif
  7. Click Background , then click Import Background to use an image on the computer as the background on the CD or DVD. Click OK to return to the Roxio Express Labeler window. Figure 5: Background option c01452916.jpg 1 - Background button
  8. Insert a LightScribe CD or DVD into the LightScribe drive of the product. Make sure that the label side of the disc is facing down.
  9. In the Roxio Express Labeler window, click Print . The LightScribe label is printed on the CD or DVD. Figure 6: Print c01452917.jpg 1 - Print button
Jun 18, 2009 | HP Office Equipment & Supplies
Hp6310 officejet all in one
here is solution..
Solution Step one: Make sure that the product prints correctly
  1. Print a self-test page from the product control panel, from Windows, or from the product software. (See the product user guide, available online, for instructions to print a self-test page.)
  2. Check to make sure that black and all colors (if using a color product) print on the self-test page.
    • If the self-test page does not print correctly, an issue might exist with the product hardware. See the product user guide, available online, for further troubleshooting steps.
    • If the self-test page prints correctly, continue with the next step.
Step two: Determine what portion of the page is set to print Many Web pages use frames. Frames divide the screen into multiple windows. Follow these steps to determine what portion of the page is set to print.
  1. Click the Internet Explorer icon on the desktop. The Internet Explorer window opens.
  2. On the File menu, click Print . The Print dialog box opens.
  3. Click the Options tab to view the print settings.
  4. Change the settings if required, and then click Print .
Step three: Change the Encoding setting in the Web browser
  2. On the Menu bar, click View .
  3. Click Encoding to view a list of encoding options.
  4. Check the Encoding settings.
    • If Auto Select has a check mark next to it, click to clear the check box.
    • If Western European Windows does not have a check mark next to it, select it.
Try printing again. If the issue continues, proceed to the next step. Step four: Check the page setup settings for the Web browser Web pages are designed to be viewed at a certain screen resolution. If the resolution of the screen is lower than the resolution of the Web page, the whole screen might not display or might not be printed.
  1. Make sure that Internet Explorer is open.
  2. On the File menu, click Page Setup . The Page Setup dialog box opens.
  3. Review the Margins information.
  4. Make sure that the margin settings are greater than or equal to the minimum printable region margins for the product. The margins vary slightly among HP All-in-One products. As a general rule, the settings should be at least the values shown in the following table. Side Margin Top Margin Bottom Margin 6.3 mm (0.25 inch) 6.3 mm (0.25 inch) 6.3 mm (0.25 inch)
  5. Make necessary changes to the margin settings.
  6. Click OK to save the changes.
Try printing again. If the issue continues, proceed to the next step. Step five: Print using Smart Web printing software HP Smart Web Printing is fast, free, downloadable software that enhances how Microsoft Internet Explorer and Mozilla Firefox print Web pages. Use HP Smart Web Printing for the following tasks:
  • Select text and graphics from any Web site
  • Save paper by combining portions of numerous Web pages
  • Preview and modify clips before printing
Thank you.......
Jan 29, 2009 | HP Officejet 6310 All-In-One InkJet...
CONNECTED HP OFFICEJET G85 DIRECTLY TO LAPTOP, WON'T PRINT
Make sure this printer is selected as the default printer. Check printer preferences to make sure all settings are correct then try printing a test page using the windows software. Hope this helps.
Dec 26, 2008 | HP OfficeJet G85 All-In-One InkJet Printer
HP 3330 Printing Problem
1)right click the my computer icon
2)click properties and then click hardware n go to device manager.
3)uninstall all usb ports and then scan for hardware changes
4)ur pc will detect your printer and ask for printer drivers
5)re load drivers and your pc will communicate with your printer
6)for reloding install the cd follow the instructions on the screen and click next
7)restart when the printer is loded.connect the wires and cords properly.
Aug 29, 2008 | HP LaserJet 3330 All-In-One Printer
IJ650 Printer
Make sure you have properly loaded the paper into the printer. If there is an error message on your screen, follow the instructions on it. If still nothing works try the following: > Check the printer cable. Is it securely plugged into the printer and your computer? > Check the printer status: a From the Start menu, click Settings Printers. b From the Printers folder, double-click the icon for your printer. c From the Printer menu, make sure: > Default Printer is selected. > Pause Printing is not selected. > If you have connected your printer to a device such as a scanner or fax machine, disconnect the printer from that device and connect the printer directly to your computer. > Check the printer port: a From the File menu of a software application, click Print or Printer Setup. b In the Where area, make sure your printer port is set to USB. > Make sure you have not installed multiple copies of the printer software: a From the Start menu, click Settings Printers. b In the Printers folder, make sure there is only one icon for your printer. c If you have two printer icons for the same printer, try printing a test page from each icon. Right-click the icon, select Properties, and then click the Print Test Page ? button. If the test page prints from one icon and not the other, delete the icon for the printer that does not print. If there is still a problem, uninstall and then reinstall the printer software: 1 From the Start menu, click: Programs >Compaq IJ650 >Uninstall Compaq IJ650. 2 Follow the instructions on your screen. 3 To reinstall the printer software, go here: http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&cc=us&dlc=en&product=217392&lang=en& Good luck!
Apr 09, 2006 | Compaq Inkjet IJ650 Printer
HP PSC 1610 All-In-One InkJet Printer Logo
399 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
