Question about ASUS A7N8X-X Motherboard
PS/2 mouse port not working?
I'm using Microsoft's Wireless IntelliMouse Explorer 2.0 (PS/2 and USB compatible) with its latest drivers. The mouse does work in the USB port, but it won't in the PS/2 port. If you're wondering, I prefer to free up more USB ports so I can use other more important devices. This is why I'd rather use the PS/2 for the mouse. Now I'm not sure how to find any indication of whether or not this port is working. If anybody knows how to find out if the port is working, please inform me. And by the way, just in case, the PS/2 keyboard port does work. It's just the mouse port that's giving me trouble.
  • 4 more comments
  • fredbeer Apr 16, 2009
    I beleive that the link that you had provided shows that the kit is actually a hordware kit, and not a software download, and I do not have this kit. Also I don't think that it's a good idea to plug the ps/2 devices into the non-respective ports. Chances are that it could damage the motherboard (most likely permanently) and make problems worse.
    Alright, I found something weird about this. You may find this weird too, so I'll go step-by-step so you can try to understand of what I did and what happened.
    I intend to work on the problem using 2 mice. The 2nd mouse (which was a wired ps/2 only mouse) was used as a backup in case the 1st (the original mouse that was mentioned above) failed to function. I did not make any significant changes to my system. I plugged the 2nd mouse into the ps/2 mouse port, and when I tested it IT WORKED! But, when I pluged the original mouse into the ps/2 port, NOT WORKING! And here's the weird part: when I plugged the same original mouse back to the usb port, WORKING AGAIN!
    Now if you don't get what I'm saying, it was the SAME ps/2 port that DID function the wired ps/2 only mouse, but NOT the wireless ps/2-usb mouse (which DOES function in the usb port only). Now I don't understand this, but I hope you do understand what I mentioned. So I wonder what was going on here.
    Yes, this is EXACTLY what I use when I plug the receiver of the wireless mouse to the usb port. Even with the use of this, both the problem and the weirdness remains.
    I'm using XP. The mouse isn't that new, it's bought a couple of years ago. The motherboard (which of coarse is the A7N8X-X) was bought in 2004, so it's not that new either. I did plug into the ps/2 port (w/adapter) and rebooted. There were no errors, but the signal from the mouse's receiver is not on. This port was working with this mouse some time ago, but now it somehow not working with this mouse (and for some reason like I said, it did work for the wired ps/2 mouse). Well, for now, it seems that I'll be using the usb port.
  • fredbeer Apr 17, 2009
    Yes, I'm using the latest mouse drivers and sp3 for xp. Even if I use the mouse switch, the receiver's signal has to be on, which at that point is still off and no indication of any connection.
    I do have a 2nd computer, but it's a very old one and it's only running Windows 98. This mouse only works from Windows 2000 onward. I'm not worried about getting a new mouse now since it STILL works in the usb port as I already mentioned.
  • 728 Answers
Hello fredbeer,
Besides the obvious checking with your device manager, you can download a port test kit HERE. That will be able to test if it's working. The other thing you can do is switch the keyboard into the mouse port and the mouse into the keyboard port. You should get some errors, if not, one of them will work and the other won't. Hopefully, you'll get the keyboard in the mouse port to work, so you know the port is working. Also, if you have any other PS2 devices that you can test it with.
Good Luck and don't forget to leave a rating based on my solution.
Thanks
Mark
Posted on Apr 15, 2009
  • 3 more comments
  • Mark Taylor
    Mark Taylor Apr 16, 2009
    Hello fredbeer,
    I don't know where you heard that switching the keyboard to the other port will harm your motherboard, but that's not the case. It's done by millions of computer technicians in case they have a failure. But, I don't want anyone attempting something they’re not comfortable with.
    On the link, there is some hardware that you can get, but they also have the links to the software portion. But either case, Here is the basic jest of troubleshooting the PS2 port..
    Begin by opening the Windows Device Manager. Click the plus sign (+) next to Mouse and for Keyboard. You will see a list of the present PS2 devices installed on your system. If any of the devices have a yellow exclamation point icon, this indicates a configuration problem with the port. If any of the devices have a red "X," the port is disabled.
    If you see an exclamation point, click the device and then Properties to determine the problem. On the General tab of the properties dialog box, the Device Status area indicates any problems that exist with the device. If you have a driver problem, click the Driver tab and click Update Drivers to install new drivers. If a conflict is the problem, click the Resources tab and look at the conflicting devices list. Devices using the same IRQ or other settings as the PS2 are in this list. Because PS2 ports can use only a few settings, try to change the other device's conflicting settings. If the device is disabled, as indicated by a red "X" next to the device, click Enable Device. Restart the computer if directed, and try to use the port again. (NOTE: Because PS2 are built into the motherboard, you may need to use the system BIOS [Basic Input/Output System] configuration utility to change the port configuration or enable the port. Press the Del of F2 key at system startup time to access the setup program to choose the settings to adjust port.)
    If the port has no driver or conflict problem and the port still don't work, you should test the port with another piece of equipment that is also a PS2 port to determine if the port is working. Typically a keyboard will give an error code on start up, which will indicate that it's functioning, however since you are concerned about the function of the motherboard, you’ll need to find another device..
    If you don’t’ have another device, then it’s going to be very difficult to test it out. If you have another computer that you can test the mouse on its PS2 port, or even a laptop, this will help determine if the cable from the mouse housing unit is bad. You really only have few issues to determine.
    1) The Device Manager has a IRQ Conflict
    2) The Device has the wrong Driver
    3) The Device is not working correctly
    4) The Cable from the mouse housing unit is bad
    5) The Port is dead
    I’ve had mice go out on my before, and I’ve had ports go out before, the trick is determine where the problem lies.
    Good Luck Again,
    Mark.
  • Mark Taylor
    Ok, that's progress!! What it sounds like is that the cable on the wireless mouse is bad. You have to cables right? A USB and a PS2 both from the wireless reciever? So, if this is a new mouse, I'd return it the store, If it's an older mouse, well, they have adapter for $2-3 that you can plug into your USB cable and convert it to PS2 cable in order to free up your USB ports. Here's what they look like, and I mean just like this one.
    Just make sure that you get the one that you can plug your USB into and the other side should be male, just like your mouse. Most of the ones you buy are just the opposite, so make sure it looks like this one.
    Good Luck!
    Mark
  • Mark Taylor
    Is the mouse new? I'd take it back if possible. If not, then you could always add an additional usb card to the computer to give you more ports, which sounds like you need anyway. But that's is weird! Your motherboard isn't that old, it shouldn't have any problems recongizing the adapter. Hmm.... Have your tried to insert the usb with adapter into the PS2 port then reboot the machine? Did you get any errors on boot up? Bios would show no mouse found on the boot up screen on that board. What operating system are you running?
    Mark
  • Mark Taylor
    Mark Taylor Apr 17, 2009
    Have you tried the microswitch on the bottom of the mouse? Sometimes it can shift to the off position. Also, try and download the new drivers HERE. And are you on SP1 of XP? It won't work on XP without SP1. Which you can download HERE. I'm not giving up yet!
    Mark
  • Mark Taylor
    I wish you had a second computer to try it on! But, It more likely it's the mouse, since you indicated that the PS2 port worked with the old mouse. Sounds like you need a new mouse! Best of Luck
    Mark
Can MS Wireless IntelliMouse Explorer 2.0 be upgraded to version 3.0 or 4.0?
I understand that USB dongles come paired from fabric with the mouse, and they don't sell them apart. OK, I'm not sure
Mar 10, 2015 | Computers & Internet
I have a Microsoft Wireless Intellimouse Explorer CE01220 PIN X08-70399 P/D 55083-576-0915355-0 I need the download manual and software user's guide. Please help!
Hi Ken,
You can download the software of your mouse from this link. You should select "Wireless Intellimouse Explorer", and your operating system to find the compatible driver and software. You can see the the help file there.
Hope this helps.
If you would like to vote for the answer, this will help the others to see the similar problems solved and also will be a satisfaction factor for me to continue helping you.
All the best.
Jun 03, 2010 | Microsoft Wireless IntelliMouse Explorer
MS Intellimouse Explorer 2.0 scroll wheel only scrolls down
There are number of reasons and solutions why your mouse isn't working properly. No.1. Resynchronize your mouse to the Pc. It's best to use the reset button for resynchronization. No. 2. Change the Port (Usb port). Sometimes even the small problem with the port created this problem. No.3. Replace the battery. If you are sure about the battery is Live, you can try with another make eg. Sony to Everydy. No.4. Interfaces Problem. Make sure that no electronic items, metal box, Speaker, etc doesn't obstruct the connection. No.5. Driver Update. Update the driver to the latest version. You must update from the particular website. If you are using Microsoft product, you must update the driver from the Microsoft's website. No.6. Different System. Try out the device on several devices not only one. If you still have difficulty, you can visit this site for more details. http://support.microsoft.com/kb/838398 Good luck
Apr 29, 2010 | Microsoft Wireless IntelliMouse Explorer
I have a wireless keyboard and mouse (Microsoft) I also have Vista operating system. When the computer sleeps when not being used, once awakened, the keyboard doesn't work and computer needs to be...
chances are its a driver problem, windows vista is not very stable, even with the 2 service packs now available. if u can, go to microsofts website and try to find drivers for your model of mouse and keyobard and get the latest drivers. otherwise, disable the sleep function or format the computer with windows 7 when its released, or windows xp.
Jul 08, 2009 | Microsoft Multimedia Keyboard/Wireless...
Strange situation that I am getting annoyed with. Here's what the deal is: I have a Wireless MS Intellimouse Explorer which actually works fine but, the intellipoint software (nor device manager) does...
Sounds like you need to update your mouse's driver, you will find the intellimouse 6.3 driver for Windows XP at the link below "IntelliPoint 6.3 32-bit for Windows XP".
http://www.microsoft.com/hardware/download/DownloadResult.aspx?category=MK&type=Mouse&name=m_imobt&os=XPSP2&lang=en
Feb 22, 2009 | Microsoft Wireless IntelliMouse Explorer
Keyboard want light up but mouse works
The buttons on the top (silver) are linked to your "Favorites" folder in Internet Explorer.
The buttons to the right of that are used for your media player (To skip tracks and adjust volumes, play pause etc)
The buttons on the left (from top to bottom) are:
1) My documents folder will open
2) MSN or Windows Live! Messenger will open
3) Your E-Mail will open (whatever your default email program is)
4) Calculator Opens
5) Windows Update will open
Now... In order for these you HAVE to have the drivers installed. If you didn't get a CD with your keyboard, you can download the drivers directly from Microsoft here:
http://www.microsoft.com/hardware/download/download.aspx?category=MK
Just fill in the drop-downs and press "Go", it should show you a link the the exact driver you need to install. Once it's been installed you can set up your favorites with the software that it installs.
Oct 24, 2008 | Microsoft Wireless Optical Desktop Comfort...
MS optical desktop 700
try one of the method below:
Method 1: Try different ports loadTOCNode(2, 'moreinformation'); Warning If you have to change a PS/2 connection, shut off the computer, make the changes, and then restart the computer. Do not plug a PS/2 device in the PS/2 port while the computer is running.
To determine whether the problem is related to the ports on the computer, use only the two cables that are included with the wireless desktop receiver, or the single cable that is included with a mouse.
USB keyboard and USB mouse loadTOCNode(3, 'moreinformation'); If the USB cable is currently connected to a USB hub, disconnect the device from the hub, and then connect it to a USB port on the computer. If your device is already connected to a USB port on the computer, try to connect the device to a different USB port if one is available.
Note Only one USB connection to the computer is required, even if your device has two USB plugs. If the problem persists, disconnect other USB devices and connect only the USB plug from the receiver to a USB port on the computer.
PS/2 devices loadTOCNode(3, 'moreinformation'); If your devices are connected to PS/2 ports on the computer, verify that you have the following configurations: • Verify that the USB plug for your mouse is connected to the green USB-to-PS/2 adapter and that this adapter is plugged in the mouse PS/2 port on the computer. The mouse PS/2 port on the computer may also be green. If you are not sure which PS/2 port is the mouse PS/2 port, see the documentation that came with the computer. • Verify that the USB plug for the keyboard is connected to the purple USB-to-PS/2 adapter and that this adapter is plugged in the keyboard PS/2 port on the computer. The keyboard PS/2 port on the computer may also be purple. If you are not sure which PS/2 port is the keyboard PS/2 port, see the documentation that came with the computer.If you have to change your configuration, shut off the computer, make the changes, and then restart the computer. If your mouse or keyboard has both USB and PS/2 connections, try using the other connection.
PS/2 keyboard and USB mouse loadTOCNode(3, 'moreinformation'); Verify that the USB mouse is plugged in a USB port on the computer and that the purple keyboard PS/2 plug is connected to the purple PS/2 port on the computer. If you have to change the PS/2 connection, shut off the computer, make the changes, and then restart the computer.
uparrow.gifBack to the top
Method 2: Install fresh batteries loadTOCNode(2, 'moreinformation'); Both the wireless keyboard and the wireless mouse rely on AA alkaline batteries for power. If the problem persists, install a fresh set of batteries in the device that you are experiencing problems with.
Method 3: Resynchronize your device to the receiver loadTOCNode(2, 'moreinformation'); To resynchronize the mouse or keyboard to the receiver, follow these steps.
Note When you synchronize the mouse or the keyboard with the receiver, put the device near the receiver and put other wireless keyboards and mouse more than six feet away. 1. Press the button on the receiver, and then verify that the light on the receiver starts to blink. 2. If a dialog box appears on the screen in several seconds, follow the instructions that appear on the screen.
Otherwise, go to the next step. 3. Press and release the Connect Channel button on the bottom of your mouse or keyboard. 4. Check the green light on the receiver. A steady green light means the synchronization was successful. If the problem persists, try steps 1 through 4 again.
Method 4: Install the latest software loadTOCNode(2, 'moreinformation'); If you are troubleshooting a wireless mouse, download and install the latest Microsoft IntelliPoint software. For more information about IntelliPoint software, visit the following Microsoft Web site:
http://www.microsoft.com/hardware/mouseandkeyboard/Download.mspx (http://www.microsoft.com/hardware/mouseandkeyboard/Download.mspx) If you are troubleshooting a wireless keyboard, download and install the latest Microsoft IntelliType software. For more information about IntelliType software, visit the following Microsoft Web site:
http://www.microsoft.com/hardware/mouseandkeyboard/Download.mspx (http://www.microsoft.com/hardware/mouseandkeyboard/Download.mspx) uparrow.gifBack to the top
Method 5: Clean the mouse lens loadTOCNode(2, 'moreinformation'); This problem may occur if you are using an optical or laser mouse and the lens on the mouse is dirty. To clean the lens of an optical or laser mouse, follow these steps: 1. Use a dry cloth to clean the bottom surface of the mouse. 2. Check to see whether the mouse functions correctly. 3. If you see dust on the bottom of the mouse, use a can of pressurized de-ionized air to blow away the dust on the lens. 4. Check to see whether the mouse functions correctly. 5. If the pressurized air canister is not available, blow dry air on the lenses by using your mouth one or two times. 6. Check to see whether the mouse functions correctly. 7. If these steps do not resolve the problem, use a cotton bud to clean the lens without scratching it.
Sep 18, 2008 | Microsoft Wireless Optical Desktop Comfort...
Wireless Intellimouse Explorer Not Working.
Normal 0 Normal 0 Recheck the magnifier to see if its set right.
Go to Control Panel and click on the Mouse icon. Then the mouse properties will appear showing the mouse buttons. In the Left column is the button settings. The bottom one is the Right Button, which is set for Magnify. Whenever you hit the Right Side button the magnifier will turn on. To turn it off, hit the Right Side Button and off it goes. You can change any of the button settings by clicking on the drop down.
Hope this helps. Bud
Sep 01, 2008 | Microsoft Wireless IntelliMouse Explorer
Wireless Intellimouse Explorer 2.0 problem
DEAR, Once again install fresh driver of your mouse
Sep 25, 2007 | Microsoft Wireless IntelliMouse Explorer
ASUS A7N8X-X Motherboard Logo
2,873 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
