Question about Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft. Front-Loading Washer
Streaks in towels/sheets
I have problems with towels getting streaked (almost as if bleached) in my washer. I noticed that one of the most recent ones was against the window of the washer when I took it out. Sometimes sheets get streaks or blobs where the color is lighter as well. I use bleach on all white loads but never on colors. Any ideas, please? Thank you.
  • bandbhost Sep 15, 2007
    I thought the same thing--so I went for months without using any bleach. Still got the streaks. My drum is stainless steel. I used Costco detergent (HE approved liquid) for a long time. Now switched to one that is supposed to be easier on the environment called Ecos (still from Costco). It may be just my imagination, but the problem seems worse. I can certainly believe that the bleach is part of the problem, but there may be more. Any more ideas, please? Thank you.
From experience, Bleach will stay in the machine and bleach load after load (esp with an enamel or poly drum). Normally have to run a HOT empty cycle to clean it out.
Posted on Sep 15, 2007
SOURCE:
Brown streaks on white cloths?
Hi Ralph,
It may be important to have an idea as to what caused the stain/discoloration. Carbona (http://www.carbona.com/home.php) has different products specific to the various reasons for the problem. You may be able to use bleach, depending on the fabric affected. Some white material turn yellow with bleach
Hope this helps ~ Good luck!
Alexander
Mar 02, 2015 | Kenmore 45081 Front Load Washer / Dryer
How do i re align the head on aMX432 cannon
  1. Open the printer driver setup window
  2. Click Custom Settings on the Maintenance tabThe Custom Settings dialog box opens.
  3. Switch head alignment to manual
    Check the Align heads manually check box.
  4. Apply the settings
    Click OK and when the confirmation message appears, click OK.
  5. Click Print Head Alignment on the Maintenance tab
    The Start Print Head Alignment dialog box opens.
  6. Load paper in the machine
    Load three sheets of A4 size or Letter size plain paper into the front tray.
  7. Execute head alignment
    Make sure that the machine is on and click Align Print Head.
    Follow the instruction in the message.
  8. Check the printed pattern
    Enter the numbers of the patterns with the least amount of streaks in the associated boxes.
    Even if the patterns with the least amount of streaks are clicked in the preview window, their numbers are automatically entered in the associated boxes.
    When you have entered all the necessary values, click OK.
    [img src="http://ugp01.c-ij.com/ij/webmanual/PrinterDriver/W/MX450%20series/1.0/EN/PPG/images/i_note.gif" alt="" >Note
    • If it is difficult to pick the best pattern, pick the setting that produces the least noticeable vertical streaks.
      (B) Most noticeable vertical streaks
    • If it is difficult to pick the best pattern, pick the setting that produces the least noticeable horizontal streaks.
      (A) Least noticeable horizontal streaks
      (B) Most noticeable horizontal streaks
  9. Confirm the displayed message and click OK
    The second pattern is printed.
  10. Check the printed pattern
  11. Confirm the displayed message and click OK
    The third pattern is printed.
  12. Check the printed pattern
    Enter the numbers of the patterns with the least noticeable horizontal stripes in the associated boxes.
    Even if the patterns with the least noticeable horizontal stripes are clicked in the preview window, their numbers are automatically entered in the associated boxes.
    • If it is difficult to pick the best pattern, pick the setting that produces the least noticeable horizontal stripes.
      (B) Most noticeable horizontal stripes
Jan 05, 2015 | Cannon Office Equipment & Supplies
Vertical streaks
Or OPC is damaged, or there's something on it. If you want to see yourself DO NOT TOUCH ROLLER. To move it, try to push the gear. You need some power to do that. Stains can be removed from OPC with paper towel and isopropanol.
Jan 08, 2013 | HP Cb540a Cb541a Cb542a Cb543a...
My canon pixma 480 has thin horizontal lines. tried cleaning and deep cleaning where is the head alignment tool?
The instructions as copied from the Pixma 480 "onscreen manual." (Only the text -- not the images -- could be pasted into the solution. Hope you can follow the text.) Steve G.
Prepare 2 sheets of A4 or Letter-sized plain paper
1. Make sure that the power is turned on, and load 2 sheets of A4 or Letter-sized plain paper in the Rear Tray.
2. Open the Paper Output Tray gently, and open the Output Tray Extension.
3. Print the print head alignment pattern.
- Press the Menu button.
- Select Maintenance, and press the OK button.
- Select Print head alignment, and press the OK button.
Note: To print the current head position adjustment values, select Head alignment print in the Maintenance menu and press the OK button. See Selecting Menus on the Top Menu Screen.)
- Select Yes, and press the OK button to print alignment sheet.
- Check the pattern is printed correctly, select Yes and press OK button.
- Confirm the displayed message and press the OK button.
The Print head alignment screen appears.
4. Adjust the print head position.
- Check the printed patterns, and use the (Left) or (Right) button to select the number of the pattern that has the least noticeable streaks for column A.
Note: If it is difficult to select the best pattern, select the pattern that has the least noticeable white streaks.
(A) Less noticeable vertical white streaks
(B) Noticeable vertical white streaks
(C) Less noticeable horizontal white streaks
(D) Noticeable horizontal white streaks
- Repeat the same procedure to input the pattern number for each column from B to L, then press the OK button.
- Select Yes to continue printing, and press the OK button.
- The second page of print head alignment sheet will be printed.
- Confirm the message for print head alignment, and press the OK button.
- Check the printed patterns and use the (Left) or (Right) button to input the number of the pattern that has the least noticeable horizontal streaks for column M.
- Repeat the same procedure to input the pattern number for each column from N to R, and press the OK button.
Jan 12, 2011 | Canon Pixma MP480 All-In-One InkJet...
GWL10 leaving dark streaks on my cold water whites.
Hi Barla 2,Just read your posting.Now are the dark streaks like an oily substance?Is you machine leaking or has become noisier on the spin cycle?The only place this machine will get oil into the water is from the main bearings.But this is only the case if your main seal is faulty.Please reply with the additional information and I can help you rectify this problem.
Jun 22, 2010 | Fisher and Paykel GWL11 Top Load Washer
Leaves streaks vertically on paper changed cartridge still there. 2600n printer
when you open the front of the print you will see the streaks on the black transfer sheet.
Close the front door half way or until all the cartridge doors open.
You will see the same streaks on the problem cartridge(s) as on the transfer sheet.
Change that particular cartridge, let the printer recalibrate, and presto streaks are gone.
Feb 13, 2010 | HP Color LaserJet 2600n Printer
Brown streaks on white clothing in front loading washing machine
more than likly it is coming from the dryer. get a paper towel or a towel and run it between the inside of the drum and the front where they come together. stick it through the slot and run around the drum. do the front then do the back see if you see the same streaks. and let me know thanks
Jun 02, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washing machine
What actually will happen over time is the stainless steel retianing hub and nut diseningrate and the tub becomes loose. Then the spin cycle will destroy the top balancing ring. When this happens - the washer is junk - not worth repairing.
Before that thou - other mechanical problems can happen, like u-joint breakage. These washers are absolute junk.
Nov 27, 2007 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft. Front-Loading Washer Logo
70 people viewed this question
Marvin
Marvin
Gerry Harvey
Gerry Harvey
jimorris77
