Question about RCA HD52W58 52" TV
Screeching sound, no picture
Tried a new bulb, which we've done before, but that isn't working this time. Color wheel? Fan? Ordered a color wheel but it's on back order. Anything else I can try while I'm waiting? Thanks.
  • 129 Answers
SOURCE: Color out of wack
There are only two things can cause that problem out of value resistors on video stage. or weak picture tube . the first one 60 to 80 dls dependig on the tech ,at shop service 125.00 if is the picture tube more than 450.00 good luck and let me know thanks
Posted on Jun 12, 2007
SOURCE: Color wheel and lens
You have 2 problems, your color wheel is making the noise, and you have a shifting of mirrors in the light engine tunnel which is something you cannot repair yourself
Posted on Jul 28, 2007
  • 17 Answers
SOURCE: Zenith A32B43W color problem
Classic symptoms! Most of the last TV's made by the old, original Zenith company (Rauland division) had bad picture tubes even when new. This probably had something to do with their going out of business and being taken over by a much better Korean company (LG Electronics AKA Goldstar). Another lovely thing they did before biting the big one was to only sell a complete chassis as a repair part. If your TV is older and has a small white paper tag inside somewhere on the picture tube (usually near the larger brand and type number label) with the code "EIA 1101" on it, discard it. I have NEVER seen one of these work correctly! If the CRT is made by someone else, there may be slight hope. Even if the TV is not very old, if it was really made by Zenith, and not LG, the possibility of repair is slim simply because of the change of ownership. I was sad to see Zenith die such a horrible death. They used to be fairly good, but somehow never made the transition to color TV. After 1954 they were essentially moribund.
Posted on Oct 19, 2007
  • 4102 Answers
SOURCE: Has sound, no picture, just color
usually if the tube has gone you will get no sound and all you will get is the telly on standby so the best thing to do is take it to repair shop and they should tell you for free what is wrong but usuall it costs more to repair than it does to buy another one sorry i couldnt be any more help
Posted on Oct 29, 2007
ctf1800
  • 4402 Answers
SOURCE: rca 36" tv
are you on outside antenna or cable? does vcr or dvd do the same?
sounds like tunner in dvd or vcr works.
Posted on Dec 03, 2007
Samsung p6163wx - lamp sign flashing with a loud noise fan on, no picture. Replaced with a new bulb - did not solve the problem
This set may use a color wheel if it has a lamp. A bad color wheel will make a fan like or high pitched sound.
If the wheel actually shatters (it can) the set will not function and will turn the lamp off.
See photo of color wheel and if you need to know I can tell you how to look at it.
Mar 14, 2012 | Samsung Televison & Video
Samsung DLP HLN5065W tv Black & White Picture
Yes,the problem is the colors wheel it dead.That one of the cause by the colors wheel,other are alots of squiling noises and making very loud buzzing sound.The cooling fan that u think is overheating,does it stop sometimes,when the tv is still on?Yes,than replaced it also,no than it still ok.Just hire the tv repairman,the parts he'll take care of it,don't order the parts,u might get the wrong parts or different sizes,that will not fit in ur tv.
May 23, 2010 | Samsung DLP HL-P5663W 56" TV
Infocus 61md10 ScreenPlay projects "BLUE PEOPLE"...HELP!
sounds like the color wheel isnt spinning at the right index speed, most likely due to bad bearings in the color wheel.
Jul 10, 2009 | InFocus ScreenPlay 61" Rear Projection...
Buzzing sound with volume off/mute samsung 6163
It sounds like your color wheel. If you are handy at all you can change it pretty easily for the price of the part (probably around $90-$110) and a couple hours of your time. Here is a link to a video showing you the step by step process. http://www.youtube.com/watch?v=Cx4pbNjsxfU good luck..
May 28, 2009 | Samsung HLP6163W 61" Rear Projection...
I have a Samsung 50 inch DLP - I heard a pop and the picture immediately disappeared. The 3 lights were flashing on the front which according to the book said it needed a new lamp installed. I ordered it,...
Sounds like the color wheel may have also gone bad. I recently saw a 56" Samsung where the bulb and color wheel went at the same time. The color wheel could produce a crying noise while trying to spin up.
May 05, 2009 | Samsung DLP HL-P5663W 56" TV
My RCA is screeching
To install the color wheel, turn off and unplug the tv, take off the lower back casing (17 star type screws), remove the lamp door, remove the lower back casing. Look just left of the lamp you will see 3 smaller star type screws near a small circuit board (which is on the color wheel), remove those screws unplug cable from color wheel, unplug other end of 2nd cable from tv circuit board (just to the upper left nearest to the color wheel.
All you have to do is install the color wheel, plug in both cables, put the back on and place the lamp door back in its position, the lamp door pushes in a lillte blue lever which allows the lamp bulb to light up.
I'm in the process of doing the same myself on my RCA same model. Where did you buy the color wheel from?
rw9704
Jan 06, 2009 | RCA HD50LPW42 50" Rear Projection HDTV
I saw your post about your HLP5063W
Click here to find information on how to replace the color wheel on your TV.
Good Luck.
Oct 28, 2008 | Televison & Video
No picture on Samsung HLN5065W
sounds like the color wheel has gone bad..the part is not very expensive but it takes some work to replace it
Nov 29, 2007 | Samsung HLN5065W 50" Rear Projection...
Loud noise from tv
if this is a very annoying screeching or sqeualing type sound, it is, in my experience, the "color wheel" which is located inside the lite engine. this is a replaceable component whick costs about $110....i've done this repair many times with no problem....
Oct 30, 2007 | RCA D44LPW134 44" HDTV
RCA HD52W58 52" TV Logo
53 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
