Question about RCA HD52W59 HDTV Projection Television
HDTV If I have a 400 watt refrigerator on the same circuit as my HDTV will it burn out my power supply prematurely? The fridge is the only other thing on the circuit.
  • 10,865 Answers
You have a circuit breaker sending power to that circuit. It is most likely a 15 AMP breaker which means it can handle 1500 watts. If it is a 20 AMP breaker you have 2000 watts.
Your TV will draw up to about 200 watts on start up. There fore, your have more than enough power even with a 15 AMP circuit.
Posted on Apr 15, 2009
  • Joe Hogan Apr 15, 2009
My soket 13A fuse is loaded wit a fridge of 400watts,it keeps burning it,what is the permanent solution?
A normal wall socket is good for 15Amps (in U.S.)
400 watts is 3.3Amps @ 120V.
Either the fridge is drawing more wattage, or something else is plugged in the same wall circuit or the fuse or breaker is faulty.
Or the wall outlet is 220V .
May 09, 2015 | Refrigerators
Can 9690 -5AU Tower take 400 watt?
There are switch mode power supplies that have a rating over 400w.
I suggest you Google the Internet for these power supplies for suppliers and price comparisons.
May 29, 2012 | Computers & Internet
The Power Supply box burned out where can I get a new one?
that is the only way to get the replacement : the manufacturer
Mar 10, 2012 | Koolatron CocaCola Fridge Red Compact...
Turn on the computer nothing happen then smell burning from the power supply! turned off right away.
That power supply is probably dead. try your motherboard witha known-to-be-good power supply to determine if your system has survived. IN my experience the failrate for antec sp450 watt psu is close to 40% over 4 years (300 pc:s at university), so there is a high probability that your psu is unrecoverable.
Feb 13, 2011 | Antec SP-400 400-Watt Power Supply
I recently purchased a Dynex 400 watt atx power supply for my Dell optiplex gx280 (slim form). The reason I did this is I have a new PNY geforce 8400 GPU and my old power supply is only 160 watts (1/2 the...
Sounds like the power supply is not compatible with the motherboard. If the motherboard can't support a 400 watt powers supply you will either get a blinking light or nothing at all. Those optiplex's use a proprietory power supply because of the pin connectors and how a power supply is supposed to fit in there. If you can't find a 400 watt power supply that fits then get a hold of Dell and see if they sell one for that computer.
Sep 22, 2010 | Dynex 400-Watt ATX CPU Power Supply
A ups mosfet ckt one mosfet burnt out og 16 can i replace only one
Usually the mating one has been degraded or damaged as well. Replace as a pair, or all of them that are in the same function.
OFTEN driver transistors and drive diodes are also damaged. Carefully check all associated components to avoid burning out freshly replaced ones.
Mar 14, 2010 | Vector VEC 024 400-Watt Power Inverter...
I need a manual or product number for power supply power supply order #
No you don't. If you think the power supply is bad, then unplug it, unscrew it, and take it to a discount place like Fry's to simply match it. Compaq does not make its own power supplies, so they use generic ones, like everyone else does. The only thing you have to choose is how many watts you need. The original may have been rated too small if it went bad, and you many want one with more power, like 500 watts.
Jan 17, 2010 | Compaq Presario SR1120NX 2.66GHZ Tower w/...
I think my inverter burned.
it depends on what burnt in it, you should check it out to know
Jan 13, 2009 | Vector VEC 024 400-Watt Power Inverter...
RCA HD52W59 HDTV Projection Television Logo
41 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
