I cannot turn on my Gateway m-6309 notebook. When i try to press the power button all I see is blinking light on power button and wi-fi for 1 minute and then it stops. I had a familiar problem 6 month ago and was able to fix it by re-installing vista. But at this time I cannot do the same operation it just does not wont to turn on. Please help me.
  • 2 more comments
  • arthur_zeidi Apr 15, 2009
    No the light is not green nor yellow. it is gust blue. And i have tried to do this before it does the same thing all i just see the blinking blue light on power button and wi-wi indicator.
    No it did not worked I tried this before. I guess some of the hardware failure. Another problem is that warranty is past do. Can i extend my warranty and asked gateway tech.. to fix it? would it work?
    thanks
  • Raymond Ramirez
    Raymond Ramirez May 11, 2010
    is the light green or yellow? Try this if it is yellow. Remove the battery and unplug the power plug. hold the power button down for 15 seconds. then put the battery back and plug it in. If the lights are yellow this is an indication of the unit not getting enough power.
  • 45 Answers
Have a few things for you to try. First take the battery out of the laptop and keep the power adapter connected, next press the poewr button down for about 1 minute. Then press the poewr button normally. should correct the problem. If the doesn't work then try external monitor to see if it works on another connection. If it works then your laptop has a hard ware problem causing the problem. If you have a warranty now would bea good time to call them if the steps don't work
Posted on Apr 15, 2009
  • bherman503 Apr 15, 2009
    i do believe you wouldn't be able to extend the warranty if it's past due...but you could always call gateway to see. If you don't have a warranty you will have to take it to a local computer repair shop to get it fixed. But call gateway first to see if you can extend the warranty.
My toshiba tablet wont connect to my wi-fi please help
1. Make sure that your wi-fi settings are turned on.
2. Scan for local wi-fi
3. Select your desired wi-fi and provide password if required.
Many times, the settings from the menu are not turned on, so the tablet will not try to link to a wi-fi site.
If you need more help, please provide the model number and the operating system currently being used on the tablet.
Feb 04, 2015 | Toshiba Tablets & eReaders
Tip
Toshiba Bios Password Deletion Satellite P100 & Satellite Pro P100 With...
With notebook turned off;
  • Open Wi-Fi Cover
  • Remove Mini Card Wi-Fi card
  • Locate & Short Out JP8 for 5 Seconds
  • Remove short and turn on
  • NO BOOT
  • Press & Hold Power button to turn off
  • Turn on again & password is cleared
Satellite L10, L20, L30 & Satellite Pro L20
  • Open Wi-Fi Cover
  • Locate & Short Out JP1 for 15 Seconds
  • (Satellite L10)
  • Satellite L20/Pro L20 short out G1
Satellite M100 & Tecra A6
  • Open Memory Cover
  • Remove Memory
  • Remove Black plastic insulation
  • Locate & Short CMOS CLR1 for 15 Seconds
NOTE:
All the following models use the same password removal process.
Satellite: 17xx Series, 1000, 1110,1130, 1200, 1900, 2430, 3000 P20,P30, P33, A30, A70, A80, M40X, M50,M60, M70, M100
Tecra A3/S2, A5, A6
  • The jumper is always located under or near the memory modules
  • Depending on the model the jumper could be labelled J1, J2, J5, J7, J9 or CMOS CLR1 (M100 & A6)
Satellite A100 & Tecra A7
  1. Remove Strip cover
  2. Remove 2 x K/B screws
  3. Move K/B Unit up but don’t disconnect
  4. Release & Remove Mini Card Wi-Fi Card
  5. Locate & short C88 Pin 1 & 2 together
  6. Power on Machine while still shorting Pin 1 & 2
  7. As soon as the TOSHIBA logo appears, remove short
  8. If machine boots, Password has been removed
  9. Satellite A100 (PSAA2A-02C01N)
    1. Remove Memory Cover from base of machine
    2. Release & remove right side Memory Module
    3. Lift black plastic insulation
    4. Locate & short PAD500 Pin 1 & 2 together
    5. Power on machine while still shorting Pin 1 & 2
    6. As soon as the TOSHIBA logo appears, remove short
    7. If machine boots, password has been removed
    TECRA A4 & Satellite M40
    1. Open modem & Wi-Fi card cover
    2. Remove mini PCI Wi-Fi card
    3. Lift up black plastic
    4. Locate & short C738 Pin 1 & 2 together
    TECRA S1
    1. Open palm rest cover
    4. Locate & short C5071 Pin 1 & 2 together
    TE 2300
    1. Remove 2 x B12 screws from bottom of system
    2. Remove strip cover
    3. Remove keyboard screws 1 x B2.5 & 1 x SF4
    4. Remove 1 x 4mm screw & Wi-Fi cover
    5. Remove mini PCI Wi-Fi card if fitted
    6. Locate & short points as shown in picture below
    7. Power on machine while still shorting points
    8. Short for 5 seconds
    9. Nothing will appear on the screen
    10. Turn system off holding down power button
    11. Password is now removed
    Satellite A60
    1. Open Wi-Fi slot cover
    2. Lift up black plastic
    3. Locate & short C561 Pin 1 & 2 together
    4. Power on machine while still shorting Pin 1 & 2
    5. As soon as the TOSHIBA logo appears, remove short
    6. If machine boots, password has been removed
    If you need your Toshiba bios password removed and your model is not listed above then chances are it's a procedure that can only be done at an authorised repair centre.
on Jun 08, 2010 | Computers & Internet
Wifi button location
To enable Wi-Fi you may try following the below steps:
    (1)Turn on the computer.
    (2)Keep tapping the F2 key at the startup, BIOS screen appears.
    (3)Move to wireless tab.
    (4)Select Internal Wi-Fi and enable it
    (5)Now move to wireless hotkey and select Wi-Fi & BT.
    (6)Save this settings and boot to windows.
    (7)Now press FN key+ F2 key to enable Wi-Fi.
    Thanks and Regards.
    Kiran Kumar.
    #iworkfordell.
Jun 16, 2014 | Dell Precision M90 Notebook
My ipad and my iphone wont connect to the wireless,
The password that my Iphone required was the 20 digit key located on the sticker as WPA-PSK. Hope this helps someone!
Dec 31, 2010 | Arris SURFboard Gateway SBG6580 DOCSIS 3.0...
I am unable to pickup internet wirelessly with my computer.
Hi Fred!
I have checked the specification of your laptop here and found that your laptop is Wi-Fi capable and wi-fi drivers are available and can be downloaded and installed here. (if required)
Most Gateway notebooks have a designated multi-function button or function key to turn your wireless on and off. There should be a tiny slide switch or button with a small antenna symbol. There should also be a light with the same symbol to show when it is on and from the keyboard Press Fn+F2 to enable wireless.
Let me know if any further clarification/ assistance is required.
Good Luck!
Dont forget to appreciate the solution if I could have been of any help!
CreativeTECH
Dec 14, 2010 | Gateway MX6421 Notebook
Gateway laptop wireless button
Hold down Fn key and hit F2. It will be used to turn on and turn off the wireless switch.
If you have window vista, Click Start, All Programs, Accessories, Window Mobility Centre, Turn Wireless On.
Apr 15, 2010 | Gateway T-1625 Notebook
Wi fi button
Look carefully on your "Function" keys example, F1, F2, F3 to F12 that are located above your keyboard. On each function keys, there is an icon. One of those is wi-fi. Find which function key has the wi-fi icon then find key to activate those functions. It is called "Fn" key (located in the bottom of your keyboard near "Ctrl" or "Alt"). Now press and hold "Fn" + "F#" then release. This should turn on your wi-fi. On mine, I have wi-fi on "F8" so I would press "Fn" + "F8".
Jan 12, 2010 | Computers & Internet
Gatweway lap top button light up, but wont turn on
I'm afraid this sounds suspiciously like a motherboard problem. It would help to know what model etc, as some Gateway & EMachine model laptops have had extended warranties due to motherboard issues, or just go to Gateway.com and research it yourself.
Jul 20, 2009 | Computers & Internet
After shutdown of gateway laptop blue power button stays lit.....
Hi this sounds like your computer is in hibernation mode as opposed to shut down mode. Could you check and see as if running Vista many people assume that clicking on the brown power type selection under start that they are shutting down where as this actually only hibernation mode and clicking on the little arrow to the right of this and selecting shutdown is the way to go.
I hope this helps
Apr 07, 2009 | Gateway MX6441 Notebook
Computers & Internet Logo
561 people viewed this question
David Payne
David Payne
