Router will not work in garden office-sky wireless
Broadband connection lost
  • 4 more comments
  • kpsantoor Apr 16, 2009
    Hi
    thanks- I am about 100 feet away from wireless router- at the moment I am playing about trying to change channels from 1-till 13-now trying 8
    Regards
    Kiran
  • kpsantoor Apr 17, 2009
    Many Thanks -how do I get a repeater-how much?
    I am wireless-the router is in fromt room so 3 walls thich plus 100 feet distance
    Kiran
    Hi
    Thanks my wireless is standard Sky wireless router called
    SAGEM
    its black
    skybroadband
    thanks-- I cant get enough sigmal to my garden about 100 feet away
    kiran
    skybroadband SAGEM-its black
    Thanks
    kiran
  • kpsantoor Apr 18, 2009
    sky provided me with a standars wireless router-sagem
    they will not let me use my own netgear-please help-very weak or no signal - i have just joined 1 month ago sky
  • Arthur Hoffmann
    Arthur Hoffmann May 11, 2010
    How far away from the Wireless device are you when you can no longer connect?
  • 526 Answers
You are not really being specific enough, but i assume you are using wireless. most likely you are out of range and require a repeater to extend the range.
Posted on Apr 15, 2009
  • 1 more comment
  • adi Apr 16, 2009
    the distance is close to the max. Some of the newer routers give more distance, but it also depends heavily on what is surrounding the router. Metal walls or gates can affect the distance, so does the old metal heaters that come out from the walls. Getting a repeater solves most of the problems.
    thanks adi
  • adi Apr 17, 2009
    what brand and model is your wireless
  • adi Apr 18, 2009
    i've never heard of that brand, but I like linksys, they make a wireless repeater called a wireless g-range expander
    part number wre54g
I lost y E1000'spassward and cannot access wireless connection
Have you installed Cisco connect software while setting up Your E1000 router?
If you have installed the Cisco connect then you will find all the settings there. If not then you can open the setup page of the router and check the wireless settings. Read Linksys E1000 Cisco connect
Nov 20, 2011 | Cisco Linksys E1000 WirelessN Broadband...
I forgot my e1000's passward and lost wireless connection. How do I get passward for it?
you will need to access the setup page of the router and check the wireless settings manually. On the wireless tab you will find the WEP WPA network key
My Wireless-G Broadband Router was working fine until yesterday when I lost the connection. I have tried everything I know to do to get the connection back. I turned off all the computers; the modem, and...
If you can access the configuration page of the router then check the IP configuration. Check WAN and LAN configurations. IP 192.168.1.1 or 192.168.0.1 will able u to access configuration page. Username and password hopefully be admin admin.
Regards;
Hasan
Dec 27, 2009 | Linksys Wireless-G Broadband Router
Cannot send a fax
For a fax to work you do not need a broadband. What you need is a phone like. It seems that you are trying to use broadband for fax because it is the same phone line that they both are on. Sorry, will not work that way. If you trace back you will find that there is a little box that has the phone line coming into from outside. The box splits it into phone and dsl. It is this phone line that should go into the fax and not the dsl line.
So please remove the dsl line from the fax and connect the phone line and you will see that the fax works.
Dec 14, 2009 | Lexmark X1240 All-In-One InkJet Printer
The area connections with internet were lost
Try updating its firmware, if its not yet making any improvements, consider buying a new one.
May 08, 2009 | Linksys EtherFast BEFSR41 Broadband Router...
We have just changed our broadband provider and now cannot connect to wi fi, and have lost instruction booklet!! any ideas?
Call tech support for your new broadband provider. They will be glad to assist you in setting up your system to work with their service. They have settings & tech info on just about all hardware to make it work with their service. Hope this helps.
Feb 19, 2009 | Lexmark X4550 InkJet Printer
I need to find the procedure for at&t 2wire DSL modem wireless connection. I lost the security code and password. The Serial N# is 140811022206 and another # is (2701HG-B) could be the model number. ...
Try going to http://Helpme.att.net your support site or try calling your Internet provided and asked them to create a new username and password for your wireless connection.
If your asking for the username and password that you set in the modem configuration page more likely you are going to reset it and call your Internet service provider for the default username and password for your 2wire modem configuration page.
Jan 04, 2009 | Sprint PCS Merlin S720 Mobile Broadband...
When i hook up ther router my internet connection is lost
Did you install the routers software? It should have had step by step instructions to walk you through the procedure of connecting all of your computers, hard wired and wireless, to it. If you've followed the steps, and it still doesn't connect, turn off everything involved, the computer, router and if there is a separate modem. Then, power the broadband modem on first, wait until the lights all stop blinking, then the router, then finally the computer.Most of the time the tech support for your broadband connection will help you connect, up to a certain point, if still unable to connect they will refer you to contact the manufacturer of the router.
Aug 20, 2008 | D-Link 802.11g Wireless Router WBR-1310...
NH1005
connect your broadband modem into hub. configure your broadband modem to PPPOE. then u can access internet in both pcs.
Mar 10, 2008 | Linksys (NH1005) 5x10/100 Mbps Networking...
Connection Issues Occur When I Try to Connect Through a Broadband Network Adapter
To resolve this issue, remove the network bridge. To do so, follow these steps: 1. Click Start, and then click My Network Places. 2. In the left pane, click View Network Connections. 3. Look for any connection that is bridged. 4. Right-click the bridged connection, and then click Remove From Bridge. 5. Repeat step 4 for each connection that is connected with a bridge. 6. When the bridge is removed from each network adapter, right-click Network Bridge, and then click Delete. 7. Click OK. When the all the bridged connections and the network bridge are removed, the broadband hardware is automatically detected.
Feb 16, 2006 | Microsoft Broadband Networking MN-100...
Computers & Internet Logo
152 people viewed this question
David Payne
David Payne
