Question about Craftsman 10.5 Hp 33" Commercial Cutting Width Zero Turn Lawn Mower
Lawn Mower begins then stops before in use
My Craftsman Rotary Lawn Mower 7.0 HP mower will start, but then stops before I begin to push it. Just replaced the spark plug.
  • Anonymous Mar 28, 2014
    re placed coil still no spark
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Mine did this.
It means that either not enough gas is getting into the engine. The gas you pump in when you prime is enough to start the engine but not to keep it going.
There could be several things that cause this.
1. Old fuel:
Solution: Replace the fuel. Dump out the old stuff. If it is a year old it won;t work.
2. A dirty carburetor:
Solution: Clean the carburetor.
Easy carb clean:
Pull the bowl off and use carb cleaning solution to clean it. (you can buy carb cleaning solution a Wal-Mart in the automotive section. I have also heard acetone will work but I have not tried it.) Make sure not to loose the little parts like the pin.
Better carb clean:
pull the carb off the machine and clean each part with carb cleaner. There is a youtube video someone else posted on how to do this.
3. Your gas/air flow is not adjusted properly.
To check:
Pull off or out the air filter. Try to start it.
Solution:
If the machine runs longer there are two options: The air filter is dirty so replace it, or the air flow is not adjusted proberly. There should be a screw like thing sometimes called the "main jet" that you turn to adjust the air flow. It is on the carburetor side or bottom.
If the machine dies faster or won't start there is probably too much air flow and by removing the filter you added more air. Adjust the "Main Jet" as above.
Posted on Jun 27, 2009
  • mary_a_allen Jun 27, 2009
    Normal
    0
    false
    false
    false
    font-size:10.0pt;
    Mine did this.
    1. Old fuel:
    won;t work.
    Easy carb clean:
    like the pin.
    Better carb clean:
    To check:
    Solution:
    as above.
Looking for service manual
Craftsman Lawn Mower Manuals - Lawn and Garden Manuals
lawnandgarden.manualsonline.com/manuals/.../craftsman/craftsman_law...
Products 1 - 50 of 473 - Craftsman Zero Turn Riding Mower Operator's Manual. Pages: 0 .... Craftsman Hi Wheel Self-Propelled Rotary Mower Owners Manual.User Manuals - ‎Lawn and Garden Craftsman
Aug 27, 2015 | Garden
Craftsman tractor how do I engage freewheel control rod?
Craftsman Lawn Mower manuals - ManualsLib
www.manualslib.com/brand/craftsman/lawn-mower.html
. PDF manuals. User manuals, Craftsman Lawn mower Operating guides and Service manuals. ... 28910 - Lt 2000 20 HP 42" Lawn Tractor · Operation Manual.Craftsman Lawn Mower manuals - ‎Craftsman 247.370310 - ‎Craftsman 247.37030
Aug 02, 2015 | Craftsman Garden
How do i take off the pull start from a craftsman model 917.377582 lawnmower
engine numbers would be helpful buttttt.... the perimeter of the recoil assy should be 3-5 small screws. remove them and it should come off, the is as long as you have a eagerbeaver engine ( tecumseh ohv )
Apr 15, 2015 | Sears Garden
How do I install part no.183281 ( engine zone control cable ) onto a craftsman rotary lawn mower model no. 944.366362 ?
Hi Robert,
I'm not usually a Lawn Mower Expert, but I think I may have an answer for you. Assuming your craftsman rotary lawn mower is similar to this self propelled craftsman mower (they should have the same basic parts), this video should help!
Self-Propelled Craftsman Lawnmower Drive Cable Repair
Sep 05, 2013 | Garden
Would like to find manual on craftsman eager-1 model 389591
Hi and welcome to FixYa, I am Kelly If I got the model correct this is a 6.75 Hp rear discharge mower.
Go to this page:
http://www.hammerwall.com/Manuals/Craftsman/Description/917.389591/Craftsman%206.75%20HP%2021%20in.%20Rear%20Discharge%20Rotary%20Lawn%20Mower/L0103219 and then after you see the front page of the reduced size manual cocl on "Manual Location" to begin the download of the manual.
or
http://www.managemylife.com/mmh/lis_pdf/OWNM/L0103219.pdf Direct download.
Thanks for choosing FixYa,
Kelly
Aug 07, 2011 | Toro Lawnmower 20099 Mower Mowers Lawn
Lawnmower runs for 2 or 3 minutes then stops running craftsman 6.5 hp push mower
Sounds like you might have a fuel flow restriction, maybe an in line filter?
Apr 27, 2010 | Craftsman 55 Torque 158cc 22" Push Lawn...
Craftsman riding lawn mower steering shaft fell. Mower will not steer. I just started mowing, and the mower quit steering. Looked underneath, and it appears the shaft came loose that is used to steer. Any...
Look under the seat of your tractor and note the complete Model number.
(usually begins with 917. _ _ _ _ _ _ )
Next, go to THIS PAGE and use the Model Number to find an exploded view of the steering components and how they assemble.
Hope this helps,
Dolf-
Oct 15, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Mower starts runs begins to back fire and run
Sounds like it is leaning out, running out of fuel. That can be the strainer at the gas tank, any fuel filters it has. Disconnect the fuel line from the carb and see how good the flow is to it, and check for water. A new spark plug never hurts.
Apr 29, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Pull cord on Sears 4.5 mower binds up
check, or have someone check the flywheel key, it is probably sheared off.
Apr 20, 2009 | Craftsman Garden
Craftsman 10.5 Hp 33" Commercial Cutting Width Zero Turn Lawn Mower Logo
268 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
