Question about D-Link AirPlus Xtreme G DWL-2000AP 802.11g/b Wireless Access Point
How to make my DWL-2000AP works like a wireles card and is there any driver for it?
  • megax01
    megax01 May 11, 2010
    U want to make it work like a wireless card?? Do you mean work with a wireless card? Cause an AP can't function like a wireless card it allows wireless cards or devices with wireless cards to connect to it.
    Problem Solver:
  • 17 Answers
It sounds as if you want to use your access point to connect into a wireless network. A typical, simple wireless network includes (1) access points and (2) clients such as a wireless card in your laptop. Access points can only communicate with clients and clients only communicate with APs. However, many access points can be configured to be clients. Usually you would find that in the basic wireless setup page. I don't know if the DWL-2000AP can be set up that way, but you can check in the manual. If it can, then you would select that mode, then specify the SSID of the network you want to join.
Posted on Apr 23, 2009
Hello, i resetted a dlink dwl 2000AP wirrels acces point, and now afther set up, the wlan led doesn't light up any more
If the WLAN light wont come, first thing that you can try here is to reset the unit again, by pressing the reset button for 10 seconds to correct the problem and once you're done resetting the unit unplug power for 10 seconds and then check if the wlan light is back....
Dec 01, 2009 | D-Link AirPlus Xtreme G DWL-2000AP...
I have a dwl-2000ap, the problem on the lan port does not function, led indicator lan does not work. I have input cable type Straight-Through or crossover, but it still does not function whether dwl-2000ap...
It should work with either cable. The LED will only come on when a connection is made to the computer or router. Is the LAN adaptor working correctly at the other end.
Jul 19, 2009 | D-Link AirPlus Xtreme G DWL-2100AP...
I want d-link ip for DWL-2000AP
The default IP address for the DWL-2000APis 192.168.0.50
Apr 12, 2009 | D-Link AirPlus Xtreme G DWL-2000AP...
How to install a password in a DWL-2100AP
The usual setup IP address for DLink wireless routers is
192.168.0.1
and the user login = admin and no password is required.
If you have not changed the password and the default SSID then it is recommended that you set a password and change the SSID so that it will help prevent someone hacking into your DLink wireles router and changing your setings to their advantage..
Feb 19, 2009 | D-Link AirPlus Xtreme G DWL-2000AP...
DWL 520 D Link Wireless PCI
disable the firewall and check the configuration of the ap
Dec 02, 2008 | D-Link AirPlus Xtreme G DWL-2000AP...
Network with two D-Link DWL-2000AP
Yes,If it is all on one network. That is the same IP scheme and Gateway.
Just set up a Home Network and give permission for all the PC's to access your "server"
No need to buy anything, just go into the Control Panel, Network Setup Wizard.
Nov 17, 2008 | D-Link AirPlus Xtreme G DWL-2000AP...
IMPOSIBLE INSTALAR
No es necesario controlador. Usted debe configurar el router mediante un navegador web (Internet Explorer).
http://support.dlink.com/products/view.asp?productid=DWL-2000AP
Aug 16, 2008 | D-Link AirPlus Xtreme G DWL-2000AP...
Connection Problem
Is your access point connected to a router?
Aug 13, 2008 | D-Link AirPlus Xtreme G DWL-2000AP...
Laptop can see the desktop where access point is connected and yet not connect on internet
The way this should be connected is..
Modem connects to DWL-2000ap (wan port)
Peterscomp connects to DWL-2000ap via ethernet
Laptop connects to DWL-2000ap via wireless.
May 15, 2008 | D-Link AirPlus Xtreme G DWL-2000AP...
DWL2000AP+ install
Whats the exact problem does it not connect at all?
Most routers don't need a disk to install anything.
Just plug everything in go to START click CONTROL PANEL go to NETWORK CONNECTION see if you have any connection at all. If you do your router could be blocking incoming data from the internet or other computers connected.
However in doing some research in your stated problem i did find drivers. They can be downloaded at the link below.
http://www.nodevice.com/driver/DWL-2000AP/get33728.html
This may not be what you need but let me know and i'll try to find what you are actually looking for.
Jan 24, 2008 | D-Link AirPlus Xtreme G DWL-2000AP...
D-Link AirPlus Xtreme G DWL-2000AP 802.11g/b Wireless Access Point Logo
219 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
