Power up problem
When i turn on my computer, it goes through the powerup but then there's a message stating that my battery is low and that i should connect my computer to a power source. the problem is that it is already connected to wall power. When i turn the computer off, the battery charges and it lasts for a little while (with the comp plugged to the wall) but then it shuts down after another message stating that my battery is at critical level appears. when i say shut down, it just turns off. it doesn't go through the power down process. I switched out the ac adapter but it still does the same thing. The computer is 4-6 years old. it has the same battery and on some days, it decides to work on other days, it doesn't. I took the battery out and just tried to run the computer off the wall power but it won't even turn on.
    Scholar:
  • 136 Answers
The DC jack inside the laptop may have a cold solder joint around it or it may be loose all together. When you plug it in watch the charge light on the laptop and wiggle the plug in the jack. If it cuts on and off (the charge light) then the jack is at fault. Also the wires coming from the charger itself could be twisted enough to break inside the insulation. try wiggling the cord as well looking at the charge light.
Posted on Sep 15, 2007
    Sergeant:
    Champion:
  • 293 Answers
Your laptop needs a new battery. Buy a new one and have it replaced by a service technician for free.
SOURCE:
Riptunes mp 1874R won't charge
Mine wouldn't charge and it Was New out of the box .
as It Turns out My Laptops USB port looses power when the computer goes into Power saving mode which was set to go into a low power state to conserve its Batteries when not in use , That was preventing it from charging fully when It was plugged in and I was away from my computer.
Dec 25, 2012 | Audio Players & Recorders
I just had the trans on my 1998 caravan fixed. 4 days later my did not turn on I turned the key and just clicks. The speedometer light states trip odometer.. reset. what does that mean?
It sounds like you have a dead battery.
The trip odometer thing is simply your information center asking you if you want to reset your trip odometer. If you did not initiate this by pressing the information/reset button, then the low battery condition could have caused the information center to "default" to this part of the menu. (Computers tend to get delirious when they are suffering from malnutrition.)
Sep 17, 2011 | 1998 Dodge Caravan
Hi i have hp 6735s laptop & i it's battery was very good but in last couple days it began to shut down after i plug off the power by 2 or 3 minutes without showing any message to notify me &...
NO OS stated ?Operating system" we cant never ever guess that.
remove the battery , test the PC with no battery?
does it run perfectly now ? yes/no.
if yes and not with battery then the battery is bad or not charged.
this is step 1. of a long process.... PCs are complex
I can not understand your post at all. (cept its power issue)
the full PCs model was not stated,
Is this LT mobile? or always on a desk.
I cant just know how you use a laptop ever.
on desk or in an airplane or at STARBUCK's is 3 different usages.
on a desk? Ill answer, the others are vastly more complex !
DESK bound 110 LT:
  1. turn off sleep and hibernate modes (CP + power settings)
  2. turn on , the same page, "laptop power button turns off PC":
  3. make sure the your software is from HP at your HP support page, we are NOT HP. here.
  4. keep the battery out, of the pc, charge it and park it so when need it not bad or dead. leave it out. run on AC power only.
  5. my wild guess is PC goes to sleep and sucks the battery dry as all do eventually or all do on weak /bad batteries. keep the AC power pack plugged in to wall power all the time. hint hint.
this PC is a very old COMPAQ
HP does not support this now, it's too old (why not upgrade)?
so to fix it , takes tedious steps.
my post above begins this process....
the one thing I cant unstand is this.
plug off? (what? is this)
Jul 27, 2017 | HP 6735s Notebook Laptops
MY COMPUTER WON"T TURN ON YET INDICATOR LIGHT WHERE CHARGER GOES INTO IT SHOWS LIGHT> Plugged in but will not powerup screen black. THIS IS A G60 HP Laptop
Take out the battery and try running it on the power adaptor alone. If this works, you have a dead battery. If not there's something more serious wrong in the machine.
Apr 16, 2010 | HP G60-235DX Notebook
Won't start - battery critically low
You should have a light on the notebook indicating that the power supply is plugged in (this should come on with or without the laptop being turned on). My acer has a green light for power, and the battery indicator shows amber for charging and green for full. If you are not seeing the power or charging indicators, you either have a damaged power jack, or a damaged power supply. Power supplies can be purchased usually for fairly cheap online, but if your power jack is damaged, the laptop will have to be serviced by a service center, or by someone who is skilled with a soldering iron and the disassembly and reassembly of laptops.
Feb 28, 2010 | Acer TravelMate 2413LCi Notebook
Ga-7N400E powerup problem
VRM Circuit problem found there
disconnect only core voltage connetor and power on motherboard
if motherboard on so confirm that your vrm circuit is sort
replace vrm circuit mosfet
Feb 23, 2008 | Gigabyte GA-7N400E-L Motherboard
Level Warning
battery level. charge it or replace it if it does not come up to full power state. the camera has a batter meter. refer to the manual and see if the battery is low. it requires you to push a few buttons while looking at the data window.
not really difficult.
the battery that might be dead or extremely low is the small battery that keeps the date etc, which is much like a large watch battery.its usually coin shaped, but on some models its a small version of a aaa battery only slimmer and shorter. not sure which that unit uses now.
if these are both ok, then you probably have a service issue
good luck
mark
Dec 12, 2007 | Canon Digital Rebel / EOS-300D Digital...
Intermittent power up problem
Sounds like a weak or low charged battery. If you're using rechargeable batteries, be sure to charge AT LEAST 14 hours before using them. If alkaline, be sure they're fresh.
Nov 24, 2006 | Canon Powershot SD450 / IXUS 55 Digital...
"Backup Battery Very Low"
NEC has identified an issue where the system can erroneously generate the "Backup Battery Very Low" message. There are two possible solutions that will eliminate this erroneous low battery warning message (the first method is the preferred solution, the second method can be used if the update file is not available). Solution I. Install a new version of the driver that controls the battery monitoring circuit. 1. Download the Low battery warning fix to your desktop. 2. Using ActiveSync or a compact Flash Card, copy FixBatt_HPC2K.EXE to the MobilePro internal disk. 3. On the MobilePro, double click the FixBatt_HPC2K icon. 4. When the message "Low Backup Battery Issue" is displayed, tap the "Patch it" button 5. When prompted turn unit over and momentarily depress the Reset button using the stylus. Solution II. Change the default power management configuration. Configure your MobilePro 900 to suspend when the LCD lid is closed on battery power and AC power. To ensure that the device suspends whenever the lid is closed, please make the following changes and perform a soft reset: 1. Go to Control Panel. 2. Open MobilePro Settings. 3. Go to the LCD Suspend/Resume tab. 4. Place a check next to "Enable suspend while on External Power." 5. Click the "Advanced" button and place a check next to "Enable suspend while on External power. 6. Click OK to close the Advanced Setting window and click OK to close the MobilePro Settings. 7. Turn unit over and momentarily depress the Reset button using the stylus. NOTE: Both the software update and power management settings are cleared on a hard reset and must be re-applied.
Sep 14, 2005 | NEC MobilePro 900 Handheld
Open Questions:
Computers & Internet Logo
156 people viewed this question
Ekse
Alun Cox
