Question about Sony KP-51WS500 51" Rear Projection Television
Color bending the collor on my tv is afull arch (bending) like a curve. this is happening with the blue, yellow colors. how do i adjust the tuner t fix this problem.
    Scholar:
  • 136 Answers
Go into the menu and look for Screen Convergence. It may also have an auto convergance option try that first. If it gives a suto error or you cant adjust it manually the convergance IC's may be bad or a component on the convergance board.
Posted on Sep 15, 2007
SOURCE:
All the colors for all programs are blue and yellow on tv. have tried all the picture settings but nothing changes.
hi" do you try to adjust color settings.theres a red,blue,green color adjustment under picture setting.
try to set red color to full.
of you already do that.
probably your display driver board has a causes the problem.
display driver board produce image comes from the tuner, then it sent to x and y drive of your LCD screen.
Aug 30, 2011 | Sanyo DP26647 26 in. LCD TV
I Have a major convergence problem. It is a 55 inch Toshiba ColorStream Projection TV(tp55h95). It was fine until we moved it into the other room, and now it's like the color is bending at both sides of...
Color arching.... Ahhh Yeah they eventually do that after a few years. Good news is all you need is a screw driver and some of your time and patience.
The color gun is a small box with 3 screws on it. (Blue, Red and Green. Turning the screws (Slightly) on the gun will get rid of the color arching. I had blue arching on a sony 65" Rear projection a year later it was red arching if you leave it long enough it will be arching and in and out flashing of solid color. Whole mind trip you don't want to venture on.......
The box on my sony was in the very front of the tv. I removed the front speaker panels and accessed it very easily. The hardest part is getting the front panel off. Yours may be in the back.
Best regards and Semper Fi...
Aug 06, 2010 | Toshiba TP55H95 55" Rear Projection...
Yellow arch on bottom left of screen. I have
OK, HERE are the instructions:
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Toshiba entry to adjust
With the set on press MUTE on the remote.
Then press and HOLD mute for several seconds and while still holding it on the remote press Menu on the front of the set.
A (S) should appear in the upper right corner of the screen. (It means you are in the Service mode)
Press menu again on the front of the set
7 on the remote will call up the convergence grid
3 on the remote will change the color to adjust from red to green to blue(do not adjust GREEN)
You navigate the grid with 2, 4, 6, and 8 buttons.
To stop the cursor from blinking so you can adjust at any point use the 5 button—to move again use the 5 button.
When you finish you exit by hitting 7 on the remote again.
Sometimes you have to try a few times to get into the menu—I have had my problems but once in it is easy.
if adjusting does not cure the problem one of the convergence chips this set uses and or a resistor are bad.
Let me know what happens and if you need more help let me know
SD TECH
Sep 30, 2009 | Toshiba TP50H50 50" Rear Projection...
My Sony Projection TV middle of the screen curves down on top and curves up on bottom. Picture looks dubble like 3D, screen looks like concaved. Left side of the screen color is light green and blue, right...
This is a very common failure on Projection sets. Its called a convergence problem.
You may have one or more of the following symptoms.
Screen looks 3D
Colors don't line up
One or more colors can't be adjusted when using the convergence menu.
Screen is bowed or warped.
No Audio / No Video - Makes Chirping Sounds
You can see some examples and find a fix here...
http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Sep 26, 2009 | Sony KP-51WS510 51" Rear Projection...
Color seperation on rca 1998 46" rear projection tv
projection tvs have seperate color bulbs that put out the same picture the lenses just need to be adjusted. they probably shifted during the move.
Dec 04, 2008 | Televison & Video
I have a KP-65WV700 and the screen looks a lil to green
OK, I'm the guy that was having the same problem, but had a blue tint to the screen. I also had blue lines running across the screen, and when I followed the steps below that were posted by another user not only did the lines disappear, but the blue haze vanished as well. My tv looks like it's new again, so you may want to try this:
noavatar_s.gif Guest
Rank:nonexpert_s.gif Apprentice
Rating: 0%, 0 votes
I have fixed this several times on my KP 65WV700
As Slinteriors posted if it is a thin curved line you need to adjust the screen control, it's sorta like a brightness for each color, and if one color is too high it will produce a thin curved line.
The best way I have found to get to the controls is by removing the lower grey speaker cover front the front of the TV. There are 6 screws if i remember, 3 on each side. Then it snaps off, seems like its going to break but you have to pop it off pretty good.
Once its loose you have to remove a cardboard like cover plate in the center that will give you access to the small controller board.
Now be very careful while experimenting on which knob controls which colors. Turn them very slow, if you turn to fast you will cause your TV to shut down. If this happens, turn the adjustment back to original spot and turn TV back on and take it slow.
Adjust the correct color until the line just goes away. Its easiest to do this with a black screen.
Nov 18, 2008 | Sony KP-65WV700 65" Rear Projection HDTV
Sony kp-65wv700
I followed GuestUser/ Slinteriors advice and I fixed it. Open the front of the TV and there are 6 little nobs in the front. The botton 3 are what you need to adjust. from left to right the color controls are BLUE, RED GREEN. For the blue lines, slightly (I really mean very slightly) turn the botton left nob clockwise (right).
Mar 21, 2008 | Sony KP-65WV700 65" Rear Projection HDTV
Blue and yellow color
Blue should converge on top of "yellow".Bad connection(s)
on blue convergence IC.Replace both IC's for durable repair.
Check pico fuses.Reset convergence alignment.
Oct 17, 2007 | Samsung HCL552W 55" Rear Projection...
Re Degaussing
Now Degaussing and convergence are two different things, if you say its degaussing then you should have just a color differential in a certain area, meaning the color should not be arched, everything that passes through should pass throu only with the changing of color. Now if its a convergence the the color may lift upward in an arch, likely separated from the other colors, Red, Blue,or Green. So now which do you think you have? Deguassing usually give you a highish green color or yellow
Sep 11, 2007 | Panasonic PT-47WX52 47" Rear Projection...
Sony KP-51WS500 51" Rear Projection Television Logo
113 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
