Question about Lexmark T640 Laser Printer
933.00 service printhead
Printer is displaying error 933
  • Anonymous May 06, 2009
    I have the same problem. Have you resolve this?
    If you have pls tell me what to do!!! Thx
SOURCE: Service error
http://www.marketpoint.com/article.cfm?id=105
this work for me
Posted on Nov 27, 2007
  • 85 Answers
SOURCE: optra t610 error 935/933/934
replace printhead - scanner assembly. The scanner motor is not working correctly. Need to remove side covers, back of printer assembly, the top cover. Printhead is below the top cover
Posted on Mar 13, 2009
don_farr
  • 1011 Answers
SOURCE: Lexmark T630 has a 933 error. I have replaced the
933 - Mirror Motor - Locks/Lost Hsync* (*Horizontal Sync) Have you gone through this exercise yet: These errors usually indicate a failure in the HYSNC signal to the printhead. Check the continuity of the cables connected to J5 and J4 on the system board. If incorrect, replace the defective cable. The voltage at J4-1 measures approximately +5 V dc. If incorrect, replace the system board. The voltage at J5-7 measures approximately +24 V dc. If incorrect, replace the system board. If correct, replace the printhead assembly. Don
Posted on Jun 07, 2009
Mike Trivedi
  • 67 Answers
SOURCE: error message 933 service printhead error
f the printer continues to post a 930 Printhead Error, it thinks the wrong printhead unit is installed.
  • If the printer was recently serviced, make sure the correct parts were used. This is especially true if the parts replaced were either the printhead unit or the printer's engine/system board. It is in one of these two parts that the printer is detecting the problem. Note: If you are the person repairing such a printer, please be aware that parts from different, though similar, printer models may not be compatible with this printer. Also make sure to check the laser cable going from the printer's engine board to the printhead unit, as it reads that signal.
  • If the printer was not recently serviced before this error occurred and powering the printer off and on does not help, the printhead unit and possibly the laser cable or the engine/system board to this printer may need to be replaced.
Posted on Mar 03, 2010
printmastert
  • 3344 Answers
Creating Customers For Life
    Verified Fixya Pro
    SOURCE: 935 service printhead error
    Hello. Unfortunately, if that's the case, there's not much you can do about it but have it serviced. Hope I can assist you more with it.
    Posted on Apr 06, 2010
    My Canon iPF8400S displays a hardware error 03130031-2F4D message. What does it mean?
    Hi
    "VHT leak detection error of left printhead,
    in case of VHT exceeds rated value or falls
    below the rated value."
    So, error shows left printhead feeding voltage problem. It can be result of fault:
    -printhead;
    -Carriage relay board;
    -flexible cable
    -main controller.
    Low speed of printing can be when printhead have overrange with it temperature; and when printing, printer makes a pauses to cold printhead. More information you can get from file PRINT INF under SERVICE MODE.
    If you are a "ordinary user", looks like you can only try to change left printhead (success not guaranted!).
    Dec 12, 2016 | Canon imagePROGRAF iPF8400 44in Printer
    Why display error printer head too hot
    According to the user manual, when this error occurs, The printer stops; the ERROR light flashes.
    Caution •
    The printhead may be hot enough to cause severe
    burns. Allow the printhead to cool.
    The printhead is over temperature. Allow the printer to cool. Printing
    automatically resumes when the
    printhead elements cool to an
    acceptable operating temperature.
    Jul 03, 2014 | Zebra 110Xi4 RFID Label Printer Transfer...
    Error oxc18a0007
    If you observe an INK SYSTEM FAILURE message or 'Oxc' error then the permanent PRINTHEAD may be electrically damaged (unfortunately it is not replaceable; you can verify this by performing the following):
    To bypass INK SYSTEM FAILURE message please see the HP Printer Diagnostics Tests file (pdf) for instructions: http://inkjet411.com/?page_id=1813
    Verify the permanent built-in PRINTHEADs electrical performance inside this legacy printer model by running the TAP 43 diagnostic test (either one of the procedures below applies to all printers which use HP02 or HP363 ink cartridges): For additional HP02 support information, please visit our HP02 system support page which includes videos of everything mentioned below: http://inkjet411.com/?page_id=1372
    A.HP02 ink-series printers with KEYPAD (i.e. keypad numbers 1-9)
    Tap 43 PRINTHEAD Health Diagnostics:
    Video Procedure: http://inkjet411.com/?page_id=2391
      1.Press * and # keys simultaneously.
      2. "Enter Special Key Combo" will be displayed.
      3.Press 123 to display the 'Support/Service' menu.
      4.At 'Support/Service' menu, click the Right Arrow 3 times until Special Reports menu is displayed.
      5.Select Ok, then click Right Arrow 2 times until the 'print-mech button tap' menu is displayed.
      6.Select Ok ('code = 0' will be displayed); click and hold Right Arrow until 'code = 43' is displayed. Use the Left Arrow if you need to decrease numerical count.
      7.Select Ok. The test page prints.
      8.Check the 4th line at the top of the printed report; an electrically good/stable PRINTHEAD 'Pen Status' will state "Pen Status: Pen OK".........if any other message is displayed then the PRINTHEAD may have failed and may need to be replaced (if part is still available). It is suggested to perform the 'Printer Reset' procedure below to first rule out printer firmware related problem.
      B.HP02 ink-series printer models that DO NOT HAVE a KEYPAD:
      Internal Test Print:
      1. Press the Menu button, press the Right Arrow button to select 'Tools', and then press 'OK'.
      2. Press the Right Arrow button several times to select 'Print Test Page', and then press 'OK'. The test page prints.
      Tap 43 PRINTHEAD Health Diagnostics - See Video Procedure: http://inkjet411.com/?page_id=2377
      1. Turn ON the printer.
      2. Press and Hold the "Print Photos" & "Red Eye Removal" buttons.
      3. Release both buttons.
      4. You will see a new screen that says, "Enter Special Key Combo"... The Key combo is: press and release in sequence the "Red Eye Removal", "Print Photos", and then "Red Eye Removal"
      5. Scroll through the menu by pressing the right arrow button until the display says 'Special Reports'.
      6. Select Ok, then press the arrow button until the 'print-mech button tap' menu is displayed.
      7. Select Ok ('code = 0' will be displayed); click and hold Right Arrow until 'code = 43' is displayed.
      8. Select Ok. The test page prints.
      9. Check the 4th line at the top of the printed report; an electrically good/stable PRINTHEAD 'Pen Status' will state "Pen Status: Pen OK".........if any other message is displayed then the PRINTHEAD may have failed (unfortunately the PRINTHEAD is not replaceable). It is suggested to perform the 'Printer Reset' procedure below to first rule out printer firmware related problem.
      NOTE: Costco USA/Canada, Fry's Electronic's, Microelectronics (along with some Best Buy stores in Canada) provide a top-notch refilling/chip re-programming service today...check it out:
      http://www.costcoinkjetrefill.com/pricing
      For additional and advanced HP printer diagnostics, please visit: http://inkjet411.com/?page_id=1813
      To help solve other HP02 ink-series printer/printing related issues please visit http://www.inkjet411.com
    Jul 26, 2013 | HP Photosmart C5180 All-In-One InkJet...
    Error 931
    Solution What the error means
    A Printhead Error message indicates that the printhead (laser scanner) unit inside the printer is not working correctly.
    NOTE: On the E250d(n) models, all service errors are signified by the flashing of all of the lights. To determine if this is a printhead error, quickly double-press the pattlnk_312007_2142-continuebuttonicon_e120_en_us.gif button to see the secondary code. If the !, pattlnk_3132007_1545-paperjamicon_e340_e342_en_us.gif, and pattlnk_3132007_1542-continuebuttonicon_e120_en_us.gif lights are the only ones blinking, a printhead or a motor failure is indicated. For more information on deciphering the error lights, click here (PDF file, 255KB).
    Clear the error
    Step Action 1 If this is the first time you have seen the error, turn the printer off. 2 Leave the printer powered off for 10 seconds or more before turning it back on. This gives the printer a chance to reset. 3
    Power the printer back on. If it goes to the Ready state, try printing again. If the error does not return, continue using the printer. 4
    If the printhead error returns when the printer is powered on or when you try to print again, follow the suggestions below.
    Check the power source the printer is plugged into
    If this is an intermittent error, you may want to check how the printer is plugged into the wall.
    Make sure the printer is plugged straight into the wall and not through a surge device or power strip. Please try this even if the printer previously worked correctly with this surge device. Power strips and uninterrupted power supplies can cause a low amperage problem, which can trigger a false printhead error.
    You may also want to try plugging the printer into a different wall outlet to see if the printhead error continues. This will eliminate the power source as a possible cause of the issue.
    If the error continues
    If the error does not clear, the printer will probably require service to correct the issue. Please contact Lexmark Technical Support or a local authorized servicer for assistance.
    When calling Lexmark Technical Support for service, please be prepared to describe the problem you are experiencing or the error message on the display. You will also need to provide your printer's model type and serial number. This information can be found on a label on the inside of the front cover of the printer.
    Please call from near the printer in case the technician asks you to perform a task involving the printer.
    Have a nice day and do not forget to rate please...!
    May 14, 2012 | Lexmark Optra S 1255 Laser Printer
    Printhead Error is displayed and therefore rendering the machine unuasable. Do you have any suggestions for a fix?
    Replace with new printhead if the print head is past it's service life. If not past it's service life when you get that error message press the online button and it should print fine.
    Apr 12, 2010 | Canon imagePROGRAF W8400 InkJet Printer
    Apr 06, 2010 | Lexmark Lemark E352DN Laser Printer
    I have a Lexmark E450dn displaying a "935.15 Service Printhead" error message and will not print. Seeing as Laser Printers do not have printheads, instead they have Scanners and Fusers, which should I be...
    a 935 printhead error is a fatal error which means the scanner motor has failed to initialize. the term printhead is short for printhead scanner. this error can be caused by either the engine board or the scanner % wise 40%engine board 60% scanner ive done 120 repairs on lexmark laser for the last 7 years trust me one of these is the problem
    Jun 16, 2009 | Lexmark E450dn Laser Printer
    Hp designjet 1050c printer displays a system error
    Printhead failure this is.
    Turn the printer on.
    Following initialization,
    use the Down Arrow key to scroll to the Ink system menu icon and press Enter.
    NOTE:If the error code appears during initialization press the Enter
    key to allow printer to complete the rest of the initialization process.
    Scroll to Replace Printheads and press Enter.
    The printer should now move the carriage to an accessible position.
    Open the top cover.
    Remove all four printheads.
    Turn the printer off using the main power switch located on the back of the printer.
    Following initialization, insert one printhead at a time, starting with the black printhead.
    Determine whether or not the printer accepts the printhead.
    Turn the printer off and repeat steps for each of the printhead.
    Replace the failed printhead.
    Hope this helps
    Regards
    Apr 17, 2009 | HP DesignJet 1050c InkJet Printer
    Lexmark C510 - 930 Printhead Error
    93x Printhead Error
    Each printhead error has its own error code number. The error codes and their respective meanings are listed below, together with some actions you can take to resolve the problem.
    ALL printhead errors:
    If this is the first time the error has occurred, try turning the printer off and on.
    Let it sit turned off for at least 20 seconds before powering it back on.
    If powering off and on the printer clears the error, please continue using the printer but watch it to see if any printhead errors return.
    If your printer continues to display a Printhead Error message, make sure it is plugged straight to the wall and not through a surge device or power strip. Power strips and uninterrupted power supplies can cause a low amperage problem in your printer. This can trigger a printhead error even if the printer has worked on this surge device for months.
    If the printer continues to post a 930 Printhead Error, it thinks the wrong printhead unit is installed.
    If the printer continues to post a 931 Printhead Error, it thinks there is an error in the signal going to the laser or the Hsync part of the printhead assembly.
    If the printer continues to post a 932 Printhead Error, it thinks there is an Hsync error occurring in the printhead assembly.
    If the printer continues to post a 933 Printhead Error, it thinks there is a failure in either the Hsync signal or with the mirror motor unit of the printhead.
    If the printer continues to post a 934 Printhead Error, it thinks there is a "lock" failure with the mirror motor assembly within the printhead assembly.
    If the printer continues to post a 935 Printhead Error, it thinks the mirror motor unit within the printhead unit cannot reach its operating speed.
    If powering the printer off and on does not clear any of these errors and it is already connected directly to the wall, your printer may require service. It could have a defective printhead unit or there might be a problem with the engine board or one of the printhead cables. Note: If you are the person repairing such a printer, check all of the cables going from the printer's engine board to the printhead unit for any damage. Also check the continuity across these cables.
    Source: Lexmark KnowledgeBase
    Jul 28, 2008 | Lexmark C510 Laser Printer
    Infronprint 1352 93x Printhead error
    Basically this is a Lexmark printer.
    Try these if no result replace printhead ( can be expensive will try to find the comparable to the lexmark.
    93x Printhead Error
    1. If this is the first time the error has occurred, try turning the printer off and on.
    2. Let it sit turned off for at least 20 seconds before powering it back on.
    3. If powering off and on the printer clears the error, please continue using the printer but watch it to see if any printhead errors return.
    4. If your printer continues to display a Printhead Error message, make sure it is plugged straight to the wall and not through a surge device or power strip. Power strips and uninterrupted power supplies can cause a low amperage problem in your printer. This can trigger a printhead error even if the printer has worked on this surge device for months.
      • If the printer continues to post a 930 Printhead Error, it thinks the wrong printhead unit is installed.
      • If the printer continues to post a 931 Printhead Error, it thinks there is an error in the signal going to the laser or the Hsync part of the printhead assembly.
      • If the printer continues to post a 932 Printhead Error, it thinks there is an Hsync error occurring in the printhead assembly.
      • If the printer continues to post a 933 Printhead Error, it thinks there is a failure in either the Hsync signal or with the mirror motor unit of the printhead.
      • If the printer continues to post a 934 Printhead Error, it thinks there is a "lock" failure with the mirror motor assembly within the printhead assembly.
      • If the printer continues to post a 935 Printhead Error, it thinks the mirror motor unit within the printhead unit cannot reach its operating speed.
    5. If powering the printer off and on does not clear any of these errors and it is already connected directly to the wall, your printer may require service. It could have a defective printhead unit or there might be a problem with the engine board or one of the printhead cables. Note: If you are the person repairing such a printer, check all of the cables going from the printer's engine board to the printhead unit for any damage. Also check the continuity across these cables.
    Jul 02, 2008 | IBM Infoprint 1352 Laser Printer
    Lexmark T640 Laser Printer Logo
    692 people viewed this question
    Top Lexmark Office Equipment & Supplies Experts
    mukhtar21 shaikh
    mukhtar21 shaikh
    Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
