Question about Princeton Digital VL1916 19" LCD Monitor
The normal procedure is when switch-on the monitor. The power light will lid green, the "NO SIGNAL" message apears and fade away, the power light will change to amber. Turn the computer, the monitor will switch-on and is ready to use. The problem is, that the above mentioned procudere, will suceed after serveral try's switching the monitor on/off for ready to use. Now the switch on/off tries doesnot help and the power on light remains green. I want to buy a SERVICE MANUAL with SCHEMATICS for this monitor. Please advise
    Scholar:
  • 136 Answers
In my years of working on LCD's, your inverter (basically like a ballast in a flourscent lamp) is bad/going out. Crack open the case and look for a big pink and white wire going to a pcb (usually located under a shield) and remove it and check for puffed capacitors. If there are some change them and that usually fixes the problem. If there are no signs of anything wrong on the inverter, get the numbers off the pcb and google or ebay the numbers, usually youll find a replacement realitively fast.
Posted on Sep 15, 2007
2 Suggested Answers
SOURCE:
guide2u
  • 461 Answers
SOURCE: Service Manual with Schematics for Princeton VL1916 LCD Monitor
this issue might not be because of your Monitor. Anyway, I can only provide manual to this legacy product of princeton if you want...
Posted on Sep 06, 2007
Describe your (VL1916) 19" LCD
Did you try this monitor with another PC and already verify that the VGA cable is OK.
Common problem with Princeton monitors are due to bad DC filter capacitors in the power supply board, see example here:
http://s807.photobucket.com/albums/yy352/budm/PRINCETON/
Sep 10, 2011 | Princeton Digital VL1916 19" LCD Monitor
Sep 06, 2007 | Princeton Digital VL1916 19" LCD Monitor
Princeton Digital (VL1916) 19" LCD
Try to decrease your screen resolution. see attach picture: or restart your computer then if windows xp booth press F8 then choose ENABLE VGA MODE. press enter. jimmyverdade_4.jpgjimmyverdade_5.jpgjimmyverdade_6.jpg
May 27, 2011 | Princeton Digital VL1916 19" LCD Monitor
Princeton vl1916 ''' I can´t figure out how
set it from menu, if it cant work adjust if from tv mainboard
Jan 22, 2011 | Princeton Digital VL1916 19" LCD Monitor
When cconnectng my ati radeon 7200 VGA output I get the "out of range" message. What is causing this?
It means your monitor is being fed a video signal that it can not process. In other words, you have settings that are not compatible with your monitor. Check your resolution, refresh rate and settings of the like.
Oct 18, 2009 | Princeton Digital VL1916 19" LCD Monitor
Princeton Monitor is "out of range"
The monitor is not getting a video signal. This is probably an issue with your computer. It could be a memory, hard drive or motherboard issue.
Make sure you are getting power to the pc (fans running, hard drive spinning...etc). Then check your memory. Try switching memory slots, or try different memory.
Turn on computer and see if you hear any bios beeps.
Try a different hard drive if you have one.
Good luck,
Hank
Aug 04, 2009 | Princeton Digital VL1916 19" LCD Monitor
Same problem
Check the Inverter card Connector which goes to pannel,Next Panel to AD card signal Cabble,..
Jul 10, 2009 | Princeton Digital VL1918 Monitor
Stuck in power save mode
Have you have selected the input you are using? You can switch between analog and digital input. The monitor would stay in power save if the input other than the one you are using is selected.
I believe the default input is DVI. Are you using VGA?
In the menu, under advanced, you can select the input.
May 04, 2008 | Princeton Digital VL1916 19" LCD Monitor
Princeton Digital VL1916 19" LCD Monitor Logo
247 people viewed this question
Top Princeton Digital Computers & Internet Experts
Ekse
Eric Rotmil
Eric Rotmil
Sr. Pelo
Sr. Pelo
Are you a Princeton Digital Computer and Internet Expert? Answer questions, earn points and help others
