Question about Asko Dryers
Asko t700 dryer wont shut off when placed in either of the automatic settings . Also I can't figure out how to get the unit open to work on it . would like to find a repair manual for it .
  • rzapor Apr 16, 2009
    I have already talked to "live chat " @ repair clinic .com and was told they do not have a repair manual for my machine .Are there any other possible sources for a repair manual for an Asko t7oo that you know of ? Askousa .com didn't have one either .    I'm guessing from what info  I have been to find that the machine needs cleaned out , But if that doesn't fix the problem I'm wondering how to determine if the humidity sensor is working properly , or just how to trouble shoot this machine .  As it is I don't yet know how to get the top off to access the controls .
  • 195 Answers
Dear rzapor,
You will find a Pay for only manuel at this site. Please paste and once there input your Model number. They also have parts available. A one stop shop for all your appliance repair needs,so remember to keep on file.
Your rating a Fix Ya is appreciated. Please ask for jj505 Thanks.
http://www.repairclinic.com/Appliance-Parts?s=t-Asko%20t700%20dryer%20-%3d%3d
Posted on Apr 15, 2009
  • Johnny TOLAND
    Johnny TOLAND Apr 16, 2009
    Dear rzapor,
    Will try other links and search. Will get back to you as soon as I locate info.
    JJ505
  • Johnny TOLAND
    Dear rzapor,
    Boy this has been a difficult search and the link below is my last hope,Please navigate thru and you will see somw models close to yours with a manual download which i hope will help you in the repair. I doubt a further search via FIX Ya .com will have any better results than this link...so if I have earned a Fix Ya at this point it would be appriciatve. Thanks jj505
    Try This Link:
    http://laundry.manualsonline.com/manuals...
I have an Asko T700 dryer which is working fine except tripping after half or less of drying time. I can reset and it dries for a while longer, usually tripping again. I have cleaned out the lint and...
Well, if the vents are perfectly clean and unobstructed the only thing I can think of is that the thermal switch designed to turn off unit when overheating is opening prematurely.
Might have to be replaced.
Sep 06, 2017 | Asko T700 Electric Commercial Dryer
The drum stopped turning on our Asko t700 dryer even though the dryer motor works fine so it runs and blows air but will not turn. Both of the fuses seem fine and as I say the motor and everything else is...
the belt is broken, here is a thread:
http://applianceguru.com/forum2/2043.html
here is a manual:
http://www.ajmadison.com/ajmadison/itemdocs/English-T711-721-731-761-781_UCG.pdf
Hope it helps Tim
Apr 25, 2011 | Asko T700 Electric Commercial Dryer
I have a asko t700 it goes on drum turns but no heat when set at high or low heat
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Sep 09, 2010 | Asko T700 Electric Commercial Dryer
Asko T700 dryer does not heat up, and start button does not work unless held down.
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The
Dryer is not Turning
Dryer Repair - The
heatman101
Dec 07, 2009 | Asko T700 Electric Commercial Dryer
Asko T700 overheats and shuts off
replace the timer or temp sensor
Aug 27, 2009 | Asko T721 Electric Dryer
MOD T700 ASKO DRYER REPLACED DRUM ROLLERS PUT BACK TOGETHER WILL NOT TURN ON
When I took the back off my Asko to clean it out I had to lay it on its face to get the drum to line up again with the back - in the doing this a wire pulled off its setting. Did not figure this out until I took the top off the dryer and found the loose wire. I have no idea if this is your problem but it was very frustrating. There is also a black reset button on the back of the dryer that you might try.
Jun 15, 2009 | Asko T701 Electric Dryer
Asko T700 Electric Commercial Dryer Problem
There's a reset button on the back of the dryer. It's a small black kinda rubber button about half way down the back panel near the center. push that button to reset it. should do the trick.
Jul 03, 2008 | Asko T700 Electric Commercial Dryer
Asko T700 loose belt, access from front?
I think you must replace the belt and the tensionarm. It MUST be done from the backside of the machine... Remove the backpanel, and the drum, change the tensionarm, and put the drum into the machine again. Put on the new belt, and mount it together again. Be careful for sharp edges! Hope this helps :-)
Jan 12, 2008 | Asko T700 Electric Commercial Dryer
Replacement part for Asko Dryer T700
Call Asko and order it there. Cant imagine that it is a expencive part. I only have the Norwegian partnumber.
Dec 24, 2007 | Asko T700 Electric Commercial Dryer
Dryers Logo
35 people viewed this question
Top Asko Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you an Asko Dryer Expert? Answer questions, earn points and help others
