Question about Avaya Computers & Internet
Wiring of Ethernet cat6 cable for computer to the modem asm32 to excess to internet
  • 5,660 Answers
Pinout is as follows:
http://www.mae.ufl.edu/sysinfo/cat6_cables.htm
Looking at the Cat6 connector with the lock tab facing up, look at the pins, (brass colored contacts) going from left to right.
From the left it's pins 1,2,3,4,5,6,7, and 8.
The wires are twisted together in pairs.
First pair
1.Pin 4 goes to the White wire with Blue bands.
2.Pin 5 goes to Blue wire.
Second pair
1.Pin 1 goes to the White wire with Orange bands.
2.Pin 2 goes to the Orange wire.
Third pair
1.Pin 3 goes to the White wire with Green bands.
2.Pin 6 goes to the Green wire.
Fourth pair
1.Pin 7 goes to the White wire with Brown bands.
2.Pin 8 goes to the Brown wire.
Posted on Apr 15, 2009
Networking Can you use 2 Ethernet switches on one Ethernet cable?
Yes, this setup will work, assuming your switches are not manageable (you will not configure any ports with separate VLANs on them)
Apr 07, 2018 | Smart Computers & Internet
Tip
Share Your Internet Connection with More Than One Computer- The Easy Way
Here is a simple way share your home internet connection with more than one computer. This will work for both wired and wireless and doesn't require alot of technical or computer skills to accomplish. I'm sure there are other ways, but if you're looking for a simple repeatable setup, here it is.
If you've got a dsl connection through a dsl modem, this TIP will work for you.
If you've got a cable modem, this TIP will work just as well.
Here's a list of what you'll need.
  1. Dsl or cable modem that works on your system and you can access internet with one computer (If you're using the internet, most likely you've got this already).
  2. Wired (Ethernet) or Wireless Router (wifi routers have 4-6 ethernet ports also).
  3. For Wired: Ethernet cable to connect modem to router.
  4. For Wireless: Wifi compatible computer or wifi card for your computer (follow manufacturer's instructions for proper install).
Procedure:
  1. Turn all components off. This includes anything on your existing network- computer, modem, printer and any router you may currently be using.
  2. With all power off, connect an ethernet cable between your modem and your new cable/dsl router(wired or wireless).
  3. Turn on the power to your new router only and let it boot up completely.
  4. Turn on the dsl/cable modem and allow it to boot. Since the router was booted first, the modem with recognize the router's MAC address (ethernet numerical address) and connect that address to the internet.
  5. Connect all the other components onto the router with the ethernet cables as needed and turn on the components- no particular order is necessary after the router and modem are booted. Your router will assign MAC addresses to all the ethernet components. Once the MAC address is assigned, your computer should work correctly with the internet and shouldn't drop out when the second computer is turned on.
  6. For wireless connections, boot up your computer with the properly installed Wifi card, airport card and allow it to "find" your router. Once you get confirmation of the signal, you're good to go.
Following this procedure will allow your modem, your router to use their designed software to connect you without a bunch of programming. You will actually enjoy having more than one computer sharing an internet connection.
Remember this procedure and follow the steps again if you lose power and have to reboot your network.
on Dec 04, 2009 | Computers & Internet
I have made a connection to my wireless modem and a hub with a 15 meters long utp cable with a straight connection pattern. i got my modem connected but to my computer internet loading it takes to long to...
It could be the size of the cable, although the problem you're claiming shouldn't have been caused by that (actually, most CAT6 cables can go up to 100m), unless there's a small break in the wire somewhere internally that still allows connection, but is intermittent, the only way to figure this one out is to replace the cable with a temporary cable that will preform the same function. Then you can attempt connecting the modem and hub with a shorter cable, if that works, then it's the length. And if that doesn't work, attempt to connect straight into the modem, if this works, then it's your wireless hub. And if that STILL doesn't work, close down ALL other tasks on your computer that require internet, and just try to use your web browser. And the FINAL option is attempting to replace your modem, but this is the last ditch effort.
I hope this helps!
May 06, 2011 | Cables Unlimited Connector, Cat6, 25pk,...
How can I connect two ethernet cables to this modem?
If your Internet Cable Provider allows it,you will need :
1. Crossover-wired, or "null," category 5 Ethernet cable for the cable modem to be connected.
2. 10BaseT or 100BaseT Hub or Switch.
3. Straight through, or standard, category 5 Ethernet cable (one for each computer to be connected).
Be sure to check with your Internet Provider first.
Dec 23, 2010 | RCA DCM425 DIGITAL CABLE MODEM (RCADCM425)
I only want to know the meaning of the different colours of cables that are used in crossover cables?
the standard colours for CAT5(e) or CAT6 ethernet cable are:
green, green stripe
blue, blue stripe
orange, orang stripe
brown, brown stripe
the typical setup for an ethernet connection in an RJ45 (the crystal end with the connection tab towards you) is
2 green
3 orange stripe
4 blue
5 blue stripe
6 orange
7 brown stripe
8 brown
Wires 1 & 2 are used to transmit data from the PC to the router/modem (TX) and wires 3 & 6 are used to recieve information from the modem/router (RX). in this fasion, information flows along one pair or another and is expected to arrive at that pinout. the router/hub/modem takes care of the transition to the next cable or out to the internet.
In a crossover cable ONE end is configured as above, but the colours for wires 1, 2, 3, and 6 are exchanged so that when no hardware is between the two PCs/components the signal is transmited at wire 1 & 2 and recieved on pins 3 & 6 on the other system/component. the other colours are placed for backward compatibilitiy and other applications, such as power over ethernet.
following the standard above allows anybody familiar with RJ45 connections repair a connection with a standard colour code and pattern without having to see the other end. If you know you need to replace one end of a patch cable, you use the standard termination.
Oct 12, 2010 | Computers & Internet
I have a RCA Thomson DHG 535-2 without the disk for the installation and the ethernet wont help everything is hooked up etherent/cable to tv power yes... and that's about ti all im really missing is the...
Thomson Cable modem has an ethernet connection...
The ethernet connection goes to your computer via a standard Cat5e patch cable. There is no USB that I know of...
Cablevision wire goes to the modem. It should be the first device on the cablevision wire. If you need a splitter, it needs to be a GOOD one, connected DIRECTLY to the incoming Cablevision wire as it enters the house. Use good copper wire.
Order of events:
Connect the cablevision wire to the Modem.
Connect the Ethernet cable to the computer and the modem.
Power on the cable modem.
Right click the network Icon near the clock and click 'repair' (Or reboot the computer)
Apply for and get an account for cable Internet from your Cable company.
After a few days, cable Internet should work.
Apr 16, 2010 | RCA Thomson Digital Cable Modem (DCM305R)
How can I connect my ps3 to my computer modem?
Here is a general guide I wrote. For Vista, however, I think you will have to go to the sharing tab instead of the advanced tab when you are browsing the properties of a connection...
1. Get a CAT5 or CAT6 crossover cable. The cable that came with the PS3 is a normal Ethernet cable, therefore it cannot be used for this operation.
2. Make sure you have two sources for network communication. For example, you can have 2 ethernet ports on your computer, or you can have a wireless card and a Ethernet port etc. It helps to draw out a connection blueprint such as this:
DSL Modem > CAT5 cable > Network Card 1 > Computer > Network Card 2 > CAT5 Crossover cable > PS3
3. Connect your computer to the modem and verify that you have an Internet connection. Then, click on Start, go to settings, control panel. Double click on Network Connections, and identify the connection to your modem (Network card 1).
4. Right click on the modem connection, and choose properties. Next, click on the advanced tab (Sharing tab for Vista users), and check the “allow other users to connect…” checkbox. After the checkbox is checked, click on the “Home networking connection” drop down box and select the name of the second network connection. Click OK and exit the properties window.
5. Finally, connect the CAT5 crossover cable from the second network adapter of the computer to the PS3, and voila, your Internet connection is now routed to your PS3. Please be aware that your computer must be on in order for your PS3 to stay online. In the long run, a router may be a much better device to use than your computer, since it consumes only a fraction of the electricity than your computer does.
Mar 16, 2010 | Sony Playstation 3 (PS3) Console
Enthernet cable
Ethernet 100/1000MBPS cables need to be Cat6 cables. These can be purchased at your friendly computer shop or over the Internet.
Do a Google search for Cat6 ethernet cables on the Internet.
Oct 23, 2009 | HP Module Enthernet 100/1000MBPS 1-PORT...
I don't know how to connect my router. please help
If you have DSL or cable internet, disconnect the ethernet cable going from the DSL or cable internet modem to the computer. Disconnect the end of that cable that plugs into the modem. Connect an ethernet cable from your cable or DSL modem to the router where it says something like "modem", "internet", or "in". If the router is a wired router, connect the ethernet cable that is still attached to the computer to any open ethernet port on the router.
Jul 15, 2009 | D-Link DI 514 Wireless Router (DI-514)
How to hook up the Ethernet 5port Workgroup Hub Model No. ew5HUB
To start with please make sure it says router on it as the title says "Networking Hub". These are two different devices. If not return the Hub and purchase a Linksys Router then follow instructions below.
Assuming you have a router:
Before you begin unplug the power from the Cable or DSL Modem before you start as they will have to be powered on in a particular order I will discuss later.
Your cable or DSL modem will have a cable coming out of it that looks similar to a phone line except a little larger. The cable will say CAT5 or CAT6 or Ethernet on it.
On your Linksys Router there will be a ports/jack that you can plug the Cable into from your Cable/DSL Modem. You want to look for one labled "WAN" or "Internet". Plug it in then plug in the power to your Cable or DSL Modem. When the "Ready" light is on the modem, plug in the power cable to your router.
The next step is hooking it up to your computer. There will be anywhere from 1 to 8 more ports available on your Router that is number 1,2,3,4, etc. Plug another Ethernet Cable into any one of those ports. With the other end plug it into your PC or Laptop, there is only one port/jack on your computer that this plug will fit in. Power up your PC and voila, you should be on the Internet.
Please let me know if this solves your problem.
Thanks,
Adam
Nov 28, 2008 | Linksys Instant Networking Hub
Computers & Internet Logo
561 people viewed this question
Top Avaya Computers & Internet Experts
David Payne
David Payne
PhantomLib
Level 1 Expert
Are you an Avaya Computer and Internet Expert? Answer questions, earn points and help others
