Question about Canon PIXMA MP130 All-In-One InkJet Printer
Set-up issues i am in desperate need of my printer but my computer CD drives are on the fritz is there an internet equivalent to the setup disk for a canon pixma MP130?
  • 136 Answers
Re: Set-up issues
Http:// Here ya go :-)
Posted on Sep 15, 2007
0 characters
3 Points
How can I reset the password on my Toshiba e-166?
Try this:
1. Use a computer that can link to Internet. Download a windows password recovery tool (I recommend windows Password recovery Tool 4.0 ) and install it on that computer. Note that there is a ISO image file. Burn the file into a CD or a USB flash drive.
2. Eject the created CD/USB and insert it into the locked computer.
3. Reboot the locked computer (it's necessary for you to change your computer's Setup to make it boot from CD drive or USB drive) and then follow the instructions. Just a few steps, the old password was removed.
4. Now login Windows and set a new password.
Mar 22, 2015 | Toshiba Printers & Copiers
I have set up disk for my PIXMA MP160. How do I install this into my gomputer at home. Do i just put the disk in and go from their?
Yes and if the disk does not auto start then open the disk by clicking on the CD drive and double click on the Setup fiel to install the print driver.
The instruction manual will also give instruction on how to setup/install the printer.
Jun 14, 2012 | Canon PIXMA MP160 All-In-One InkJet...
I NEED TO INSTALL THIS PRINTER MFC-7420 on my laptop which do not have cd rom player
You have several options to do this:
- If you have spare PC, you may copy the content of the CD to a USB disk and install from the USB disk on the laptop
- Or you may just insert the CD on another computer on the network and share the CD-ROM drive by going to My Computer-Right Click on the CD Drive and click share. Now on your laptop go to My Network Places (usually on Control Panel) where you can see the shared CD drive from your other machine.
- Or if your laptop has internet access, visit Brother website and type your printer model to download the driver installer on your laptop machine.
Good luck and hope this helps.
Nov 03, 2010 | Brother MFC 7420 All-In-One Laser Printer
Error Code Oxc18a0001 No service available in my area. How do I fix this myself if no service locations?
have you considered wipping your hard disk drive (format) ?
this may be the only way to solve this issue.
if you have a name brand computer, you should be able to set the factory deafult settings , by using the rec overy CDs that cam with the computer
if you need CD recovery disks, go here
Oct 18, 2010 | HP Photosmart C6180 All-In-One InkJet...
if u have the Disk of the printer insert in the CD disk drive and go to my computer and select the drive right click and use Explore to locate the program on the CD disk....
install all the printer program from the setup file...
May 05, 2010 | Panasonic Workio DP-2330 Printer
Pc asking for system disk but i have no was working fine until i changed the dvd rom
Any new Hardware install you need to setup, with some,sys drivers are installed, so auto install takes place.
Guessing, your "Poota" fails to find new drive prog, so it is asking for the setup disc to the dvd drive?
Go too DVD drive company, look for update driver download.
Do you have the dvd prog dvd/CD ??
Nov 13, 2009 | Printers & Copiers
Set UP of HP Photosmart C7280 All-in-One Fax Printer Scanner Copi
The cd that came with the printer did you install it?
Usually when it shows 1 through 5 it means that you need to complete 5 steps for that to work.
Dec 24, 2008 | HP Printers & Copiers
HP J6480 error message insert 'solution center disk'
When you get this error message again, insert the installation disc you used for the printer set-up. Then, click on "browse" and go to D:\Setup\SolutionCenter (D: denotes the drive letter of your DVD drive), and you'll find solutioncenter.msi there. Select it, and then click on "OK" should then repair the installation and the issue should be resolved.
Dec 12, 2008 | HP OfficeJet D135 All-In-One InkJet...
Making a network setup disc
i guess it has only option to make a floppy disk, you may try to make a floppy disk.
Nov 19, 2008 | HP PSC 1510 All-In-One InkJet Printer
Canon PIXMA MP130 All-In-One InkJet Printer Logo
43 people viewed this question
Top Canon Printers & Copiers Experts
old marine
old marine
Are you a Canon Printer and Copier Expert? Answer questions, earn points and help others
