Question about Cycling
Do i need an electrican to fit angle eyes to corsa c
    Problem Solver:
  • 11 Answers
If you can use your basic tools then no you dont, angel eyes are a simple replacement light, the wiring on the back should be exactly the same as the old ones, so all you need to do is take the old ones out, remebering which wires go where, then put the new ones back in and connect the wires, it really is as simple as that.
Posted on Apr 21, 2009
Opel corsa baklie 1.6 sport 2007di engine light dont com on and dont haf sperk
the signal from the crank angle sensor thats mounted against the block pointing to the crank pulley is what tells the ecu that the engine is turning and to provide spark and injector pulse
so your possible problem area is the ecu
also check the ecu harness plug wires and pins
make sure the crank angle sensor is plugged in
Oct 02, 2016 | 2007 Opel Corsa Utility
Hi can you help me with torque settings for main and big end bearings for 1.4 opel corsa
Connecting rod cap bolts (you must use new bolts)
stage 1 ... 25 Nm (18 lb ft)
stage 2 ... angle tighten + 30 degrees
Main bearing cap bolts ( you must use new bolts)
stage 1 ... 50 Nm (37 lb ft)
stage 2 ... angle tighten + 45 degrees
stage 3 ... angle tighten + 15 degrees
Jun 21, 2016 | Opel Cars & Trucks
I want to know the torque opel corsa lite 1.4 cylinder head bolts.
stage 2 ... angle tighten + 90 degrees
stage 3 ... angle tighten + 90 degrees
stage 4 ... angle tighten + 90 degrees
stage 5 ... angle tighten + 45 degrees
Feb 26, 2015 | Opel Corsa Cars & Trucks
Dump valve on an opel corsa utility 1.7dti
Unplug electrical connection to valve. Unbolt old one, remove, attach new one, bolt up. Reattach electrical connector.
Suggest you get a workshop manual, they are cheap enough on eBay
May 12, 2014 | 2006 Opel Corsa 1.4
51 plate corsa need to change starter motor, how the hell do you undo the top nut?
normally takes a long extension up and over the top of the starter or one with a u-joint on it for angle changes on most models..try that unless you dont see any real channel for acess..aks the parts store for that particular model.. they will dictate the proceedure forthe car..
Jan 22, 2013 | Vauxhall Cars & Trucks
I have a Leisure Alto fan oven element to fit and instead of screws it looks pins/rivets how do I change it
Drill out the rivets and replace with screws.. you may need a right angle drill or right angle drill adapter to fit the drill in there. Always take care and be sure to FIRST cut off ALL power to the unit and give it a good once over with your eyes to determine where the drill bit would follow through to prior to drilling - just to be sure you are not going to hit any other critical component...
Jan 05, 2011 | Ovens
Replacement parts for Tasco binoculars
You'll need to measure your eyepiece in "mm". Also determine if your eyepiece has an outer ring the eyepiece will slip over. You can find eyecups/guards on Ebay. Search under Binocular Eyecup or Binocular Eye Guard. There are also eyecups under "rubber eyecups/rubber eyeguards" but alot of these are for Microscopes and may not fit. You will need to pay close attention to the mounting type and measurements.
Sep 18, 2009 | Tasco Wide Angle and Rubber 2023 (10x50MM)...
N REG VAUXHALL CORSA CENTRAL LOCKING NOT WORKING
central locking on my 93 corsa with standard key, not electronic type as used on later models, all doors are locked and refuse to open, ive checked fuse and thats ok, doors refuse to open from inside the vehicle and from outside, only the tailgate will open from the key, any ideas ,,, thanks dave
Apr 17, 2009 | Ford F Cars & Trucks
Car parts
how do you fit new wing mirrors to vauxhall corsa
Jan 09, 2008 | Ergo Baby Carrier
Cycling Logo
209 people viewed this question
Top Cycling Experts
Michial Gueffroy
John Egan
John Egan
Are you a Cycling Expert? Answer questions, earn points and help others
