Question about Ford 8N Tractor
My pto wont go in gear; 8n tracter.
I push the clucth in , try to move pto leaver but wont engage, dosent make any sounds, clucth seems to be disingageing. any ideas?
  • 491 Answers
Try it while just coming to a stop.or just starting to move forward.
Depress the clutch and push it back towards engagement position....because it's tied to wheel speed the moving parts might allow it to drop in.
Posted on Aug 14, 2009
Massey ferguson 135 pto keeps throwing out of gear drives but pto wont stay in gear why
possible that the teeth of the pto dog are worn to a taper and not fully engaged
the lever for the engagement is moving the full travel to engage
the bearings on the pto shaft are failing and allowing misalignment of the shaft thereby walking the dog out of engagement
Jan 05, 2017 | Toys
Was driving it before church and parked, came out and it started but it wouldn't shift into gear, shifter will move but won't engaged
Sounds like your linkage has separated.... but, first check the transition fluid make sure it is full and use the correct type for your brand of car.... the linkage goes from the bottom of your shifter and hooks to the transmission...as you move the shifter in the car it selects a gear on the tyranny by physically moving a leaver... a lot of times they are cable or leavers but some are electric..
May 03, 2015 | 2000 Cadillac DeVille
WHY DOESN'T JOHN DEERE 2320 MOWER DECK WILL NOT ENGAGE?
seev if you have no voltage at pto clucth replace bad pto if you dont check fuse and pto swich and safty switch
Aug 24, 2014 | Garden
PTO WONT WORK on myCub cadet ride on mower LT 1045
i seems you already found the cause its a electrical problem look at all the wires you have a loose connection some ware the wires also like to break where they go into the clutch
Jun 28, 2012 | Cub Cadet Garden
Ford 8n tractor.when i put a load on the pto , it pops off
You should repair that PTO system before it gets worse.
Get a repair manual and fix it.
I can't explain the repair here.
Keep in mind.......everything on your tractor is easy to fix.
Jul 21, 2009 | Ford 8N Tractor
8N PTO will not disengage
Pulls the bolts from the lever cover. You should be able to remove and inspect to see if the fork is busted or shaft it bent. go here for tech help and or parts/ manuals...http://www.just8ns.com/index2.htm
Jul 09, 2009 | Ford 8N Tractor
Cr250 clutch not engaging
sounds to me like your friction plates in your clutch assy. are worn down to much.
Apr 23, 2009 | 2002 Honda CR 250 R
My PTO will not engage without grinding but works great once engaged, Model is only shown on the engine as C10 with production code of 5F5B and serial A281771
when u engage u have to push in clutch and wait for spinning gears to stop the engage pto and let out clutch, excessive spinning of gears can be caused by low transmission grease also causing grinding
Apr 13, 2009 | RTO Ford Tractor 2000 3000 4000 5000 Water...
Ford 8N Tractor Logo
810 people viewed this question
Top Ford Toys Experts
D. E. Hev
Are you a Ford Toy Expert? Answer questions, earn points and help others
