Question about Archos Internet Media Tablet MP3 Player
My Archos 5 is displaying a Code 101 error message. How can i fix that? I can't get to go past this message?
  • jlld Apr 18, 2009
    i call the company an they told me to send it back
  • 5 Answers
Your system is somehow corrupted, could be music downloaded from the net, whatever it is easy fixable.
A) Download the firmware from Archos and save it to your desktop (Make sure the file name on the desktop hasn't changed from the original download file name)
B) The Archos 5 or 7:
1- Plug the unit to you computer via the USB cable.
2- The unit should start automatically and open the following page:
3- From the recovery console (the screen that asks for repair or format etc…)
4- Select "Repair" by scrolling up and down with the volume control on the right of the unit (Do not press "Format" at any time)
5- Now that you are on "Repair" press the on and off button, shortly to validate your selection
6- The unit will go to "Plug the unit etc…" but it is already plugged from point 1 - DO NOT press anything anymore on the Archos
8- Wait until Pc should recognizes your Archos (around 5 seconds)
C) Computer
1- From your computer select the firmware file you downloaded from the net and put it in your Archos (in the root folder, nowhere else, where it has the folders, music, videos, pictures etc… as a file)
D) On the Archos 5 or 7
1- Select "Ok" on the Archos (on & off button) shortly to select and confirm the file is now on the Archos
2- you are done! The Archos 5 or 7 should now read through the file you have transferred and repair the system
3- DO NOT DISCONNECT the USB cable until the process is finished
4- when done safely disconnect (as you usually do, for Mac trash the letter of the Archos to the bin or for PC's: right click the green icon bottom right of the screen for xp & vista)
5- Press on/off button to reboot
Your unit should restart with a fresh repaired, updated system like day one.
Posted on Jul 24, 2009
THER IS 2 FILES YOU HAVE TO DOWNLOADS
1- firmware_archos5-7.aos
2 apks_package_3.0.aos
I Hope this help
Posted on Nov 22, 2009
I did that, and the screen is still up
Posted on Nov 17, 2009
  • Logan19 Nov 17, 2009
    i followed the instructions listed above, and the screen still comes up? now what do i do? try again?
I am pretty sure that is a FAT error i had that too when i first got mine. Go on the internet and follow the instructions to put it into recovery mode. Then simply install new firmware to fix it.
Posted on Apr 22, 2009
  • 3 Answers
I tried all these solutions and nothing worked. Always back to the same screen. I then decided to download and older .AOS system file. Copied it to the Archos 5 and to my surprise it worked. Archos 5 now back up and running (File was 58MB)
Posted on May 27, 2011
    Problem Solver:
  • 14 Answers
Sometimes Repair & Recovery doesn't work & you have to format which is bad if you don't have everything backed up. If you have everything backed up go thru the format function & follow the instructions above to format
Posted on Aug 24, 2009
Help--My 101 g8 will not turn on. It just keeps on blinking the Archos name. I have turned it off and on again but stays stuck in that mode???
You have a bad hard drive. Replace it with a new one. You did create recovery disks, right? If not, then you're gonna have to buy a new OS. sorry
Feb 23, 2014 | Archos 101 Internet Tablet
Where do i find screen for archos 101 tablet computer
http://cgi.ebay.com/ARCHOS-101-Internet-10-1-inch-LCD-screen-display-Panel-/320709787738?pt=LH_DefaultDomain_0&hash=item4aabcb005a This is a link to one selling on ebay, it's not cheap and doesn't include the digitizer. The biggest problem with buying lower volume brand name electronics is the lake of availability of parts. Apearently this manufacturer will not even rrepair these for you.
Aug 17, 2011 | Archos 101 Internet Tablet
Bought my tablet as a window display item. archos 101 How to end demo mode ? Thanks
Power off by holding the power button for 10 seconds.
Press "Volume +" button and power it on (press power button to start while holding "volume +" until the tablet displays recovery mode. Select the "Format System" option.
Jul 06, 2011 | Archos 101 Internet Tablet 16GB 10.1"...
My archos is showing recovery code 101
It is indicating that there is a hard drive fault. Here is another users suggested method to clear the fault.
Following some extensive use I switched it on one day to find that it hung on the Archos home screen and kept going in a loop. Luckily I could see the red HDD light flickering so knew that the Archos was trying to do something and that the HDD was recoverable. When I entered into the recovery mode I found that I had an recovery code (101) which indicates a HDD fault.
I used the following steps to recover the HDD:-
1. Connect the archos to the PC using the USB cable (the unit will start but will need to be shut down again by pressing the power button)
2. Press the power button and the 'lock' button together for a few seconds and you should get a basic recovery screen
3. Scroll down to repair disk and select
4. Click on done and wait for a few seconds and you will see the archos as a drive in 'My Computer' (Note that this does take a few minutes)
5. You now need to back up your data, movies, music, widgets etc as the next step is to format the Archos HDD which will wipe it all.
6. Disconnect the Archos, turn it off and then turn it back on again by pressing the power and 'lock' buttons together.
7. Scroll down to format disk and select. The Archos will now delete all files on the HDD and you will get a message asking to connect to a PC and install the update file. This is the firmware file that can be obtained from the Archos website. You'll also notice that the recovery code has changed from 101 to 108
8. Connect the Archos to the PC, wait for a few seconds and you will see the archos as a drive in 'My Computer' again.
9. Drag the firmware update file from your PC where you've downloaded it to directly on to the root drive
10. Click 'done' on the Archos and it will begin to update the operating system.
11. Once this is complete then there should be an update successful message, select done and the archos should restart giving you the nice bubble screen and asking if you want to enable USB.
12. Note that the Archos is now in a 'factory built' condition so you'll need to adjust settings etc according to your preferences.
13. You can now start the long process of transferring your files back to the Archos.
Jan 12, 2010 | Archos Internet Media Tablet MP3 Player
Recovery code 101
8- Wait until Pc should recognizes your Archos (around seconds)
C) Computer
May 27, 2009 | Archos 5 Internet Media Tablet
Getting a white screen with 102 error message
I fixed my son's 605 4 GB had Recovery code (104) on it. This might work for other error codes too. These are the steps i followed
* Use the computer for this process that you always used for this archos Archos should be plugged in toPc before starting the process.
* Download the firware Upgrade 2.1
* Plug the Archos to Pc
* When the white option screen comes up pick the format disk
* Wait until all done do not pick any option on archos after format is done Pc should recognize your archos in 5 seconds
* Put the firmware in root section of the archos not in any folder.
* Safely remove the usb for Archos from your pc first and then unplug the cable.
* Do not pick any option on the Archos screen
* Just turn it off from the power button by holding it until it turns off
* Wait about 5 minutes and plug it back to pc
* it will come up with white screen again but this time it will start Update you will see the progress bar moving, wait until it is all done, it will shut off. Turn it back on and  your archos will be back to normal
Mar 13, 2009 | Archos 605 WiFi Digital Media Player
Just got Archos 5 goes into error 101...
Hi there, these instructions are for the archos 705 but they are the same for the 605.
B) The Archos 705:
1- Connect the unit to its power source.
2- Start the unit in recovery mode: Press the TV button first then the power on/off and keep pressing TV button (do not release it)
3- The recovery mode will start (the screen that asks for repair or format etc…)
4- Select "Repair" by scrolling up and down with the TV Button (it is all explained to move through the menu at the top of the Archos screen) (Do not press "Format" at any time)
5- Now that you are on "Repair" select it to validate your selection
6- The unit will go to "Plug the unit etc…" plug it with the USB cable to the computer
C) Computer
D) On the Archos 705:
2- you are done! The Archos 705 should now read through the file you have transferred and repair the system
3- DO NOT DISCONNECT the power cable until the process is finished
4- When done safely disconnect (as you usually do, for Mac trash the letter of the Archos to the bin or for PC's: right click the green icon bottom right of the screen for xp & vista)
Jan 21, 2009 | Archos 605 WiFi Digital Media Player
Hdd_recovery 2
LAST HOPE !!!
ERROR CODE 102!!!
I JUST FOUND OUT THAT I HAD THAT SAME PROBLEM TOO...AND I WAS ABOUT TO THROW IT AWAY OR GIVE IT TO MY WILD CAT TO PLAY WITH !!! BUT!!! HERE IS WHAT I DID FOR MY LAST HOPE IN SOLVING THIS PROBLEM...
FIRST HERE ARE THE DETAILED PROBLEMS I HAD...
*NO RECOGNITION OF MY ARCHOS IN MY PC...
*ERROR SCREEN..."SYSTEM DAMAGE...REPAIR? NO,REPAIR,FORMAT DISK"
*SELECTED ANY OF THE OPTIONS...SAME STUFF...BACK TO THE SCREEN...NEVER ENDING STORY...
OK...THIS IS WHAT I DID...
1 DOWNLOAD THE LATEST FIRM FROM WWW.ARCHOS.COM...TO YOUR PC !!
2.AFTER DOWNLOADING THE LATEST FIRM UPDATE TO YOUR PC... PLUG IN YOUR ARCHOS TO YOUR COMPUTER...
3 YOU WILL NOTICE THE ARCHOS IS NOT DETECTED AND YOU ARE IN YOUR SCREEN ERROR STILL...OK...TURN YOUR ARCHOS OFF BY CLICKING ON THE POWER BUTTON FOR ABOUT 5 SECONDS OR UNTIL IT TURNS OFF...(NOTHING ON THE SCREEN BUT BLACK...)
4. THEN...WE ARE ABOUT TO TURN IT ON AGAIN...BUT BEFORE THAT... LEAVE ONE FINGER ON YOUR TV/LCD BUTTON PRESSED !!! HERE IS THE SECRET...THEN TURN IT ON !! BUT...DO NOT LET THE TV/LCD BUTTON RELEASED !! IS LIKE YOUR ARE GOING TO PRESS BOTH OF THEM AT THE SAME TIME...AND WAIT FOR FURTHER INSTRUCTIONS...
5. THEN ANOTHER SCREEN WILL APPEAR..SORT OF LIKE...HDD RECOVERY 2...YOU MIGHT WANT TO UNFORTUNATELY FORMAT YOUR DISK...
6. ONCE IT TELLS YOU DONE ! DO NOT PRESS ANY BUTTON... THE PC WOULD NOW RECOGNIZE YOUR ARCHOS...AS A HARD DRIVE..ETC...
7. ONCE IS DETECTED BY YOUR PC...REMEMBER THE FILE YOU DOWNLOAD IT... DRAG IT DOWN TO YOUR ARCHOS..IN THE ROOT SECTION... THAT MEANS...IN NO FOLDERS INSIDE THE ARCHOS...BUT BY ITSELF...JUST LIKE ANY OTHER FILE IN A FLASHDRIVE IF YOU MAY...
8. THEN IT MIGHT ASK YOU AGAIN YOUR PC...YOU WANT TO FORMAT THIS DRIVE...JUST SAY YES....OK...WHATEVER... AND LET IT FORMAT...
9. FINALLY AFTER THE FORMAT SITUATION HAPPENS...YOUR ARCHOS WILL ACCEPT THE FILE...AND IT WILL BE DOWNLOADED AUTOMITICALLY...THEN REOPEN IT TO MAKE SURE IS THERE ALREADY...
10. FOR THE LAST STEP... ENJOY ! MY ARCHOS IS BACK TO NORMAL..IT REBOOT AND EVERYTHING IS FACTORY MADE...HOPE THIS WORK GUYS...AS FOR ME IT DID...
PS. PLEASE BE PATIENT ON THAT OPTION OF THE TV/LCD FOR IT MIGHT NOT WORK RIGHT AWAY...I TRY IT LIKE TWO TIMES BEFORE IT LET ME FORMAT EVERYTHING...BECAUSE YOU MIGHT GET ERROR MESSAGES LIKE..."MEDIA FAILED" ETC... JUST KEEP ON TRYING UNTIL IT ACCEPTS IT.. LET ME KNOW WHAT HAPPENED...
Jul 16, 2008 | Archos 605 WiFi Digital Media Player
Archos Internet Media Tablet MP3 Player Logo
6,630 people viewed this question
Top Archos Audio Players & Recorders Experts
kaiserh1
 Grubhead
Grubhead
Are you an Archos Audio Player and Recorder Expert? Answer questions, earn points and help others
