Question about Whirlpool LSB6200KQ Top Load Washer
Whirlpool top load washer ( 8yrs old)
Whirlpool washer stuck in agitate mode. Tub is full and can't find out how to drain it nor how to get it into spin cycle. Please help to pinpoint my problem. Keep in mind I am an electrician so I'm familiar with wirng and switches. Thanks for any help, I need to wash my kids clothes for tomorrow. Help
  • dira May 12, 2008
    washing machine stuck on agitate. Manually turned timer bit it does not restsrt
  • 447 Answers
Very easy solution!!!chat with me online and ill step you through it save up to $65 (my in-home rate in florida is $75!!!!!!!)
Posted on Sep 27, 2007
6ya staff
SOURCE:
Whirlpool Cabrio WTW6600SBT Top Load Washer won't aggitate
My Whirlpool WTW6600 had the same problem. The tub no longer floated up and down on the center shaft, so it only spun, not agitated. You must remove the tub (with some effort) and lightly sand / clean the center shaft. Lube it lightly with wheel bearing grease so that after it is reassembled, you can pull the tub upward and feel about 1/2" movement. This will enable the proper gear assembly to engage. It can spin when it rests at the bottom of its travel, but once you fill the tub, it floats, moving upward, and engaging the agitation gear. Good Luck!
Nov 23, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
My washer agitator spins but the tub doesn't,also see metal insid
Repair or replace is always a judgement call. Most people will be better off replacing the machine. This is a rather big job, labor wise. On a difficulty scale of 1 -10, I'd give it an 8. The metal is the inner area between the inner drum and the transmission shaft, which has corroded and started to break apart. (located under the agitator) To repair, the agitator is removed, the washer front and top are removed to allow the washer's outer tub cover to be removed. This allows the inner tub to be removed. (caution: the big nut under the agitator drive spline is a left hand thread) Then, the drain hose, water level hose, suspension rods, and electrical to the motor are all removed to allow the entire drum to be removed from the washer to allow the inner tub to be removed. The actual metal part which needs to be replaced is then easy to replace by removing a few torx head screws from the underside of the inner tub.
Oct 02, 2009 | GE Profile WPSR3120WWW
Whirlpool Washing Machine Won't Agitate
Hi friend...
it is usually caused by anything stucked below tub,if its not then if is actualy timer,,,check them both...
thank u.....
May 03, 2009 | Whirlpool Washing Machines
Cabrio washer wont drain
Hello, LD stands for long drain.
If all the water isn't out of the unit within a certain time, the ld will flash.
Could be 2 things.
1) There's lint stuck in the pump preventing the water to drain properly or
2) You're using too much soap causing lots of suds also preventing the pump from draining properly. If this is the case, what you need to do is run the washer on full load with no detergent and clothes. Let it go thru the cycle and get rid of eccess suds. This is most likely your problem.
Best of luck :)
Apr 06, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Sheet stuck under washer agitator.
remove agitator top remove 7/16 bolt to remove agitator. tub mounting hub may be worn which allows the tub to drop down. the hub is located on the center post below the agitator.
Dec 20, 2008 | Kenmore 23822 Top Load Washer
Kenmore Washer 70 Series - sheets stuck around agitator
The transmission probably stripped the worm gear that drives the drum - you would have to crack it open and take a peek.
Nov 24, 2008 | Kenmore 15864/15862 Top Load Washer
My Whirlpool washer won't agitate or spin . But it does drain the water.
i also had the same problem, and it ended up being the coupler. It was not hard to replace, it cost me about 19.00. I didn't follow full recomende instructions. I tipped the washer backwards. Removed the drain pump and the motor itself. Then I removed the old coupling and placed the new one. The washer is working like new...
Oct 18, 2008 | Whirlpool LSR5132PQ Top Load Washer
Whirlpool Cabrio WTW6600SW1: Won't drain
The washer drew half a tub of water on the "Bulky items" cycle, and stopped. All the lights on the cycle dial light up and flash, the machine beeps and the me error message in the "estimated time remaining" field is "Ld". I've tried to shut the machine down and change the cycle to "drain and spin" but it will not agitate, won't drain or spin.
Sep 05, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool calypso
Have you checked the agitator? There may be sharp edges on the agitator blades. OR the towels may be getting stuck under the agitator and tub bottom. The agitator is supposed to suck the clothing down in the center and forcibly throw the clothing outwards against the tub. The cycle then repeats.
Sep 09, 2007 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool LSB6200KQ Top Load Washer Logo
65 people viewed this question
Marvin
Marvin
Gerry Harvey
Gerry Harvey
jimorris77
