Question about Xerox DocuColor 12 Printer
Xerox docucolor 12 system fault 15-362
Error comes up as soon as I turn on the machine. Any information is welcome.
Thanks in advance.
  • el_dany Apr 16, 2009
    Thanks, after i turn off the printer and turn on after a while. It seems to be OK now. There is no more the system fault, and i must have to correct the post, must be: "suddenly the printer sends the system fault 15-362"
    Best Regards
  • subashsiahja
    subashsiahja Jan 15, 2013
    Xerox docucolor 12 system fault mean power on off
    President:
  • 1,865 Answers
Fault Code 15-362 - CAUTION: The Fuser Roll remains in a cammed-up position if power to the copier is interrupted while the copier is in use. The Fuser Roll will not be released from its position until the power is restored, the Power Switch is in the On position, and the Start button is pressed again. If the Fuser Roll remains in the cammed-up position for a prolonged period of time, copy quality defects will occur. To prevent damage to the Fuser Roll, switch the Power On as soon as possible after the power is restored, and make a copy of a document. If the machine is a DC 12LP send a print job from a workstation to prevent damage to the Fuser Roll.
Posted on Apr 15, 2009
    New Friend:
System files mean power on off
Posted on Jan 15, 2013
I have the same problem, 15-362!The problem persist after i restart the machine again and again.Your solution its not working!something else?
Posted on May 24, 2010
Error code 10-356
Hi
10-356 code i pws mode
remplace the fuser
Feb 09, 2010 | Xerox DocuColor 12 Printer
Xerox docucolor system fault problem
hi please chek and tell what error code showes in your display.. some error codes showing in ur display, pls check it that.
Aug 25, 2008 | Xerox DocuColor 12 Printer
Docucolor 12 system fault turn off and turn on problem
tell about error code which is appear left bootom of screen
Xerox docucolor 12 please power off and turn back on.
you have a heater problem. The machine times out if it doesn't see an increase in temperature within a set time. What code are you getting?
Xerox Docucolor 12
Error in the Fuser. The description for this fault code is: External Heat Roll Contact Failure. Generally the external heat roll retract motor is defective. The xerox part number of this motor: 127K21350
Aug 20, 2008 | Xerox DocuColor 12 Color Copier
Xerox dc 12 copier system faulit 9-354
Hi ,
Sir I am have dc12 mech
its giving error code 9-354.
send me the solution as soon as posible.
Aug 09, 2008 | Xerox DocuColor 12 Color Copier
Xerox DC12 System Fault 6-355
06 codes refer to exposure lamp problems..(or scan) check lamp coming on, scan carriage position etc, don't have the code list, so carefully move the scan carriage up and down, make sure it moves OK
Jun 05, 2008 | Xerox DocuColor 12 Color Copier
Xerox DC12 Error code 9-355
That is a magenta toner empty message, either the magenta is empty of there is an issue with the magenta toner dispencing.
May 07, 2008 | Xerox DocuColor 12 Color Copier
Error code 15-380
15-380 means the exposure lamp in the scanner is not being senses.
Open the scanner and see if the lamp comes on.
If not, most likely the lamp has failed.
If it does come on, then the sensor or processor have failed.
Mar 19, 2008 | Xerox DocuColor 12 Printer
Xerox DocuColor problem
The only thing I can tell you to do is turn off the machine. On the back of the finisher, unplug the finisher from the processor and power up the machine, it will reconfigure, plug and play like, and send the pages to the center tray.
Once you do that. Go into machine status and into faults. Print out a fault page and tell me the finisher/stapler code coming up so I can let you know exactly whats going on.
I hate that software puts a machine down for functions you do not 100 percent need.
Mar 18, 2008 | Xerox DocuColor 12 Color Copier
Xerox DocuColor 12 Printer Logo
1,142 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
