Question about Saniflo 013/003/005 Sanibest Toilet with Grinder Series Pump in White Round
Toilet will not stop pumping,unpluged all day pluged back in 10 hours later still pumping will not stop.??????
    New Friend:
  • 92 Answers
Sounds like pump is clogged or float is stuck i would not leave it running you may harm the motor
Posted on Apr 16, 2009
Kohler 3810 toilet wom't flush
Check and see if the handle or the chain inside the tank is broken. If it is, find out the make and model and get replacement. There are many different types of handles out there. Some universal handles won't work, so bring the handle with you when you buy a new one..
Mar 24, 2017 | Kohler Plumbing
Why is it beeping sporadically?
It looks like it needs service of some sort. Have you referred to its manual?
May 13, 2015 | Liebherr CS1601 (15.5 cu. ft.) Bottom...
The saniflo keeps cutting in even when not flushed
Water pressure makes the unit kick on and off. It will turn on by itself if water is somehow draining back into the pump. It could be water leaking from the toilet tank into the bowl and from the bowl to the pump or the flapper on the check valve inside the discharge elbow may be stuck open or could be defective and allowing waste water to drain back into the pump, once it builds up enough water pressure inside the pump, the unit will kick on and off by itself.
Jul 14, 2010 | Saniflo & Saniplus& Macerator Pump
After pluging in my new Heier it started to program itself. But i accidently stop it. Now it won't program. All i get is a blue screen that says no signal.
Unplug,replug the tv about an hour later.The tv should return it back to the factory setting.This tv hook up to a cable,satalite or a Telicom boxes?Unplug those boxes too,replug it an hour later too,let the boxes soft ware upgraded itself.Now do what u have to do.
May 24, 2010 | Televison & Video
My up flush toilet makes a humming sound every 5
The pump has either gone bad or it is siezed up...you can try to unplug the pum and let it sit for a few hours then plug it back in... sometimes if you jog it on and off a few times you can get tiit to break loose and work again...if not you will have to take it out and replace the pump.
heatman101
May 03, 2010 | Saniflo SaniPlus-Round SaniPlus Macerator...
97 Chevy Lumina Completly Stops while driving
When it stops, does it have spark? (crank sensor)
Apr 10, 2009 | 1997 Chevrolet Lumina
Looking for a compact toilet, 10'' rough-in
It's a year later... and you've probably already figured it out, but for those of you who may come upon this with a similar question: home improvement stores carry off-set flanges that you can install to give you a couple inches where your toilet (standard is 12" rough in these days) will fit in a smaller space. We needed a rough-in of 10 1/2" and the off-set flange did the trick!
Mar 12, 2009 | Home
Won't make coffee-doesn't appear to turn on.
Same thing here, just call the 1-800-726-0190, they will send you out a new one. You'll have to pay a $10.00 shipping and return the old one. You should have your new coffee maker in 7 - 10 days, customer service was nice and very helpful. No complaints here except, what do I do for coffee for the next 7 - 10 days?????????? LOL
Jun 06, 2007 | Cuisinart DCC-2000
Saniflo 013/003/005 Sanibest Toilet with Grinder Series Pump in White Round Logo
736 people viewed this question
Top Saniflo Home Experts
Paul Carew
Tim Whalen
Are you a Saniflo Home Expert? Answer questions, earn points and help others
