Question about Zanussi TC7114W Electric Dryer
Zanussi TC 7114 W Condenser dryer leaking water
The machine has started leaking water from underneath. The valve and rubber 'o' ring on the water container look fine. Is this a common problem ?. Seems worse if the water collector is not emptied after every cycle.
  • martin_stirr Apr 16, 2009
    It leaks even when the water collector is half full of water so I don't think it is leaking from the upper side.
    Scholar:
  • 59 Answers
Maybe it's the water collector's upper side which leaks...
Posted on Apr 15, 2009
    Problem Solver:
  • 7 Answers
Zanussi 7124 tumble dryer drum not turning
Posted on Aug 06, 2009
Zanussi dryer tc
Did you locate the "tensioner" wheel that may have jumped out of the mounting hole...??
There are two wheels, one on the motor and one on the tensioner...
Apr 13, 2014 | Zanussi TC7114W Electric Dryer
Zanussi TC7114W Tumble Dryer manual
Just click here for the direct download from PDF : TUMBLE DRYER TC 7114 W TC 7114 S
No websites or forwarding, that is just the manual from factory support website.
Vote the solution if this is what you are looking for
Sep 22, 2008 | Zanussi TC7114W Electric Dryer
I HAVE A ZANUSSI CONDENSER THAT AFTER STARTING WITHIN ONE MINUETE THE LIGHT IS SHOWING THAT THE RESERVOIR NEEDS EMPTYING WHEN THERE IS NO WATER IN IT.
We have the same issue and i have turned the machine upside down today to find there is a condenser valve inside the connecting pipe that connects to the reservoir tank to allow it to fill. This valve has come adrift as an 'O' ring has come off of the end. I need to source a new 'O' ring from a hardware store or DIY store, which should solve the problem.
Dec 05, 2010 | Zanussi TC7102W Electric Dryer
I have a Zanussi condenser dryer TC 7114 w. It stops half way through the cycle indicating the water tank is full, but it is vertually empty and the water is collected in back of dryer and then leaks all...
I have just fixed this as below - your leak may be easier to see if you turn the machine on its front - there is a rear valve with a rubber bung and underneath a rubber pipe with a metal clip - check both for leaks - http://www.fixya.com/support/t4079509-full_water_indicator_lit_continuously
Oct 04, 2010 | Zanussi TC7114W Electric Dryer
ZANUSSI FJR1454 W WASHING MACHINE E10 ERROR . IT TAKES NEARLY THREE HOURS TO DO A QUICK WASH. IT BLEEPS AT LEAST 4 OR 5 TIMES THROUGHOUT A WASH CYCLE AND THE CYCLE COUNTER DOESNT SEEM TO COUNT DOWN...
Washer dryers often have cold water valves with 3 separate solenoids. One for the main wash and rinses (which is clearly ok) and one for the condition rinse (to take the fabric conditioner down) which is probably ok too, and the 3rd one is for the dryer. It's possible this 3rd solenoid has failed.
Washer dryers need on a steady trickle of cold water running into the condenser chamber to convert the steam into water, which then gets pumped down the drain.
e10 means that there is a problem with the water supply.
a condenser dryer needs cold water to operate properly. the e10 code will appear if:
1. the water is turned off
2.the water pressure is too low.
3.the solenoid valve is open circuit
4.there is a problem with the pressure switch (least likely)
Cold valve is at the end of blue inlet pipe remove lid and you will see it.
f E10 is only appearing when trying to dry, the problem almost certainly is the condenser valve solenoid open circuit. The green solenoid on the inlet valve. Should read about 4000 ohms.
My money would be on the solenoid coil being open circuit. The coil can be canabalised from most valves although you may have to modify the connections. For simpler repairs - contact Zanussi and get the entire triple inlet water valve to swap out.
http://www.zanussi-electrolux.co.uk/files/unitedkingdom_english/0-999/zanussi%20error%20codes.swf
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Oct 10, 2009 | Washing Machines
Water leak on Zanussi tc7102 dryer
I had a similar problem. There is a 'o' ring on the plastic part that keeps coming out. This 'o' ring is not big enough, you need to replace it with a thicker one, preferably one made from a harder material.
Feb 28, 2009 | Zanussi TC7102W Electric Dryer
Wash Machine WA950SCJ won't fill up
Jan 20, 2009 | Washing Machines
o ring fits on a slot round the spigot of the valve
Sep 25, 2008 | Zanussi TC7114W Electric Dryer
Not collecting water in the tank
I also have this problem and is leaking all over my floor underneath...i've only had it a day. the condenser is soppin wet and no water in the tank..i'm dead angry...anyone else have an idea how to fix this mother F*****...thanks...clair
Sep 21, 2007 | Zanussi TC7102W Electric Dryer
Zanussi TC7114W Electric Dryer Logo
2,374 people viewed this question
Top Zanussi Dryers Experts
Tim Whalen
Are you a Zanussi Dryer Expert? Answer questions, earn points and help others
