Question about Makita 10" Miter Saw LS1030N
Makita chopsaw when cutting angles blade is cutting table
  • michelle_307 Apr 16, 2009
    thanxs but have no manual had it long time any other ideas as cutting main plastic groove
  • David Ford
    David Ford May 11, 2010
    Put the saw at a 90 deg. and lower the blade fully into the channel, does it bottom out, there is a blade depth adjustment that I think needs to be adjusted. Also are you using the right diameter blade on this tool. The teeth should just be below the surface of the table for the proper cut. Let me know if you see something else.
  • 2,176 Answers
Try going to Makitatools.com and typing in your model number on the right side of the page at the top. It will take you to another page where you can download an owners manual, I saw where page 6 and 7 would be helpful. Let me know if you need more help
Posted on Apr 16, 2009
  • 10,865 Answers
You can adjust the location where the blade drops into the groove in the table. Look on page 24 of this manual and you will see exactly how to adjust the table:
http://ec1.images-amazon.com/media/i3d/01/A/man-migrate/MANUAL000007351.pdf
Posted on Apr 15, 2009
My 71/4 table saw is week can't cut blade stops
Sounds like the motor is wore out! Or maybe the belt if its belt driven
Jan 14, 2013 | Makita Saws
My blade is not square to the table i,e if I make a 90deg cut, it is about 1/16 wider at the top of the board than it is at the bottom. I've lost my owners manual and was wowndereing holw I go about...
Set your saw square using a combination square if you have one. Then to to adjust the saw to stay square there should be a gold coloured nut that you can adjust on the right side below the lever you use to unlock the saw when setting what angles you want to cut. Either move it in or out to get the proper setting. Hopefully this answers your question.
Apr 25, 2011 | Makita 10" Dual Bevel Sliding Compound...
How do I remove the disk from a Makita 9009B 230mm Angle Grinder
The locking nut undoes in the same direction as the blade spins. It's done now!
Thanks
Apr 02, 2011 | Makita Angle Grinder
Have new hitachi chopsaw, need blade for laminate flooring
The blade that you need is carbide-tipped, many-toothed with the proper center-bore diameter. A chopsaw is usually used for cutting steel parts and not particularly precise for flooring. Good luck!
Nov 05, 2010 | Garden
Breaks support rings in all blades
are you using the proper inner blade flange?? that is the only thing that I can think of that would cause your problem
Jun 12, 2010 | Makita 9553NB 4" Angle Grinder
How do you tip the saw table to cut on an angle
Hi, usually there is a wheel or knob at the back side of the saw table , with a gage that will tip the blade for angle cuts
What make a model is your saw? I will search for details.
Please Vote !!
May 30, 2010 | Saws
My makita 2703 blade movement quirks
http://www.makita.com/en-us/Assets/images/Products/_PartsBreakdowns/PB_2703.pdf
http://www.makita.com/en-us/Assets/images/Products/2703/owners_manuals/2703.pdf
Here are two links for the parts manual and the owners manual. It is not uncommon for a tool to go slightly out of line with use due to vibration and and movement of the arbor. As for the tool not tilting, it just sounds like the worm screw and gear are off line. this is a pretty quick fix but it requires you to turn your saw upside down to access the set screws. I glanced at the diagram and it looks like the handle for the adjustment is held on by a set pin. you will also be able to access this from inside the cabinet.
Feb 24, 2010 | Makita 2703 10" Table Saw, Electric Brake
Dw703 beval adjustment
User manual for adjusting your saw here.
When you set it up, make sure you check for square to the table, square to the fence, and check square for toe-in or at a 45 deg. angle across the blade from the corner where fence meets table, like you would check a radial arm saw. (hold a framing square with one leg against line of fence/table and other leg against blade and inclined 45 to both table and fence. Make sure all three are dead square.
I never found any way to compensate for the play in the blade itself. It seems like the manufacturing tolerances are a little too loose.
You may need a heavier plated blade. You may simply need a different saw. Those Dewalts are great workhorses, and I love the design, but it's my experience that when you're trying to miter hardwoods of any substantial size there's a little bit of drift in the cut as the blade comes through the wood.
You can try cutting at a slower rate.
I've found that makitas are a little more solid through the cut, though I don't like the general ergonomics as much...
Kind of a pain, isn't it?
Well, good luck.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Sep 04, 2009 | Saws
LS 1013 chopsaw
There should be two knobs on the saw where you adjust the miter of the saw. One of these knobs if turned clockwise tightens the swivel. I have the same saw except it is a 13 amp.
Oct 22, 2008 | Makita LS1013FL 15 Amp 10 Inch Dual Bevel...
Chopsaw
hi hope to help you!
firstly see if the blade is going the correct way if so
you should replace the spindle shaft and also fit a now bolt only use makita parts though!!
the problem is the thread in the spindle and bolt are worn.
Hope that helps. Sean.
Mar 03, 2008 | Washing Machines
Makita 10" Miter Saw LS1030N Logo
228 people viewed this question
Top Makita Saws Experts
ray gallant
Are you a Makita Saw Expert? Answer questions, earn points and help others
