Question about Home
Old crane toilet, leak between tank and toilet, need new gasket.
I have a Crane toilet, installed 1962. It had to removed recently to repair the wall behind it and when it was replaced & water turned on there was a leak between the tank and toilet. Bought a repair kit at a local store, but plumber said the gasket is not thick enough and it is not likely that I would find a repair kit locally that would fix the problem and the only solution is to get a new toilet. What do you advise?
  • heatguy May 11, 2010
    got to agree with smithbrother go to supply house you could find a gasket that will work but put a new toilet in and save some water
  • Thomas F. Schneider May 11, 2010
    If you need a thicker gasket, go to the plumbing supply and get a thiicker one. I am still getting parts for 1938 model toilets. Sound somewhat like a run around?
    Problem Solver:
  • 5 Answers
You might try looking in an hardware store, or a plumbing shop that has been in business for a long time. Sometimes they have parts that can't be found elsewhere. I would take the old seal with you, if you still have it.
Posted on May 02, 2009
It's leaking from the flush valve. I cleaned the top of the valve lip and replaced the flapper. This improved the problem but it still leaks alittle. The toilet is only two years old (...
You need to replace the flush valve gasket. It comes in a flush valve kit, it's a rubber gasket that goes between the tank and the bowl. You just pull the tank off and it's on the under side of it. Be careful the black stuff on the gasket doesn't come off your hands. Make sure you get the new one on there even and all the way on. This will fix your problem. Good Luck
Tool Belt Diva
www.toolbelt-diva.com
May 15, 2011 | Crane Plumbing 3755 Toilet-To-Go Metro...
We have a crane toilet, the tank does not have a flapper valve, but has a rubber gasket that has come loose and gets out of position on every flush causing the tank not to refill. It seems like a lousy...
You're right it is a bad setup but Crane will not change their design. Most of the time it is from age and you have to replace the flapper system. I would go to the local hardware and buy a FluedMaster setup and change out the flush tube although that means taking the toilet apart.
Feb 08, 2011 | Home
My Crane toilet is slowly leaking into the bowl. It is not the flapper (which I replaced) and doesn't seem to be from high water pressure. Could it be the seal?
Check your over flow pipe in the tank to see if you need to lower the water level amount in the tank. If thats not it, it could be the seal thats under your flapper between the tank and base. Simple fix just alittle time consuming
Sep 24, 2010 | Crane Plumbing 3755 Toilet-To-Go Metro...
We have a crane toilet that worked perfectly and now it just wont quit running and water is leaking out the side how do i fix this im tired of shutting off the water to the toilet after it fills up
It sounds like it is running constantly because of the leak. Where is the leak, at the bottom, around the plastic nuts underneath or is there a crack in the tank? Let me know.
Fix the leak and will have fixed the running problem
Jul 09, 2010 | Crane Plumbing 3755 Toilet-To-Go Metro...
Broken tank
The numbers you need should be stamped into the porcelain under the cover. Bring those numbers to your nearest plumbing supply house and they will be able to help you. Good luck.
Dec 28, 2009 | Crane Plumbing 3755 Toilet-To-Go Metro...
My toilet flushes very slowly. If I hold the handle down it is better, but still not right. I was on the roof and checked the vent, it is clear. I replaced the toilet, the old one was a cheap one that...
No. There is either a partial blockage between the floor flange and main stack or you have not installed the toilet properly and the wax seal has squeezed wax over the outlet hole. Always clean all old wax off of flange before installing new seal.
Sep 11, 2009 | Crane Plumbing Toilet To Go Tall...
Can't remove old assembly...stuck in there
You have to remove the tank bolts on either side of the flush valve. Once you remove it, there is a tank to bowl seal that will need to be replaced. Remove the old seal and there will be a huge plastic nut that holds the flush valve to the tank. Remember to use new hardware when reassembling the toilet so that it won't leak sooner rather than later!
Apr 03, 2009 | Crane Plumbing Toilet To Go Tall...
Home Logo
1,762 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
