Question about Magic Chef CTB1722 Top Freezer Refrigerator
Evaporator fan top is cold bottom is warm should thr fan kick on right away 8 months old
  • 136 Answers
These can be easily fixed. Take the back cover out of the freezer and tap on the fan shaft (you wont hurt it) and squirt a dab or two of oil on the shaft next to the motor. If it loosens up let it run for a few hours and reoil. If its frozen up totally and you cant turn it at all then the motor needs to be replaced. Let me know :-)
Posted on Sep 15, 2007
Working but extremely noisy freezer
most likely noise is coming from evaporator fan motor.go here,it will show you the parts in your model,
unplug the freezer,remove shelves and remove back inside wall to get at the fan might see yellow stains around motor area,that's from the oil that leaked out of fan motor,also if noise stops and you notice that the freezer is cold on bottom and warm on top the fan motor died and needs to be replaced right away.hope this helps and you should change the motor out before you loose any food.
Dec 08, 2013 | Frigidaire PLFU1778ES (16.7 cu. ft.)...
I have a haier 3.3 freezer/refreg. Its 3 months old. The problem iam having is that the freezer is working but the refrig is warm. I looked at the circuit diagram on the back of the unit and did not see...
Gravity - cold air sinks to bottom of refrigerator. Make sure the damper door is open and allowing cold air from freezer to infiltrate into refrigerator.
Aug 31, 2017 | Refrigerators
Fridge not cold compressor running fine sides are warm to the touch, enough ventilation bottom freezer and top fridge setting at maximum cold both freezer and fridge fan are working with an external 12V...
There are three reasons for your fridge problem. 1. Malfunction of defrosting. 2.Gas chocked.3.Thermostat setting.
1. The freezer can be set to atemperature between.
Thanks, helpful?
-14°F and 8°F.
Feb 08, 2011 | Fisher and Paykel E522BLE Bottom Freezer...
My sub zero refridgerator (freezer on bottom fridge on top) is cold on the bottom of fridge and warm on the top of the fridge. Any idea what is causing this. Items are also damp in fridge. We just vacumed...
the evaporator coil inside the freezer compartment is iced over and can't transfer cold air in thes condition,remove panel inside freezer on back side of freezer compartment and thaw it out with a hair dryer,then check the defrost heating element for continuity,if its open replace it,if its good, ,check the defrost control that powers the defrost heater
Jul 15, 2010 | Sub-Zero 611 / O Bottom Freezer...
if you can; find the vent(s) between the top and, bottom boxes (where the evaporator fan is located: closing these vents makes the freezer colder and, the refrigerator warmer, opening these vents the reverse is true.
Jul 19, 2010 | Frigidaire FRT17G4B Top Freezer...
Maytag refrigerator isn't cold.
if freezer is working and ice mker is working . and fan / then only other is the damper in top center is not working . very common . mm
Apr 18, 2010 | Maytag MFD2560HES Bottom Freezer French...
Freezer on bottom is cold,refrigerator on top is warm. 2 days before failure there was a vibration noise intermittently between fridge and freezer that stoppped if freezer door was shut hard
This is a little strange to hear but something caused the vibration. Closing the doors hard or soft may make big changes in sound because of pressure change. I just want to know if the compressor is purring away without overheating. Anytime there is a restriction in ventilation the evaporator fan will struggle to push the air to the freezer and enough to refrigerator side to maintain safe temperatures. On the bottom even if the fan stopped the bottom would work because it is below and cold is heavier than warm. I will look over your parts breakdown to see what vent, dampers or fans that may cause this, work with me on this and I will help you solve this. Thanks Sea Breeze
Jan 21, 2010 | GE Profile PDS20SFS Bottom Freezer...
The top of the freezer part is getting cold but the bottom of the Refrigerator part is not getting cold. The Refrigerator is only 10-11 months old ; what is wrong?
you need to check and see if the fan in the back of the freezer compartment is running. when the fan is not running the cold air will not be passed to the refrigerator compartment. open the freezer door and turn the unit to its coldest setting until the compressor kicks in then listen to hear the fan in the freezer compartment.
Sep 16, 2009 | Refrigerators
Fridge warm at top cold at bottom
If the fan is no coming on inside the freezer this will need to be fixed soon. Both fans upper and lower must run while compressor runs. Inside the fresh food compartment close the damper on bottom left side next to the paned drawer. If this does not help send more cold air to the top let me know as there could be something else causing the dampers not to open and close properly.
Thanks, Sea Breeze
May 28, 2009 | GE Refrigerators
Admiral Side by Side Fridge is warm at top, cold at bottom
Feb 07, 2008 | Admiral 26 cu. ft. Side-By-Side...
Magic Chef CTB1722 Top Freezer Refrigerator Logo
149 people viewed this question
Top Magic Chef Refrigerators Experts
Level 1 Expert
John Tripp
John Tripp
Are you a Magic Chef Refrigerator Expert? Answer questions, earn points and help others
