Question about Maytag Neptune MDE5500AY Electric Dryer
Loose baffles in Maytag dryer
Does the top just pop up?
    Genius:
  • 1,198 Answers
To remove the top, you usually have to push a putty knife in at the top corners, from the front. This pushes a spring catch. On some Maytags, the front comes off, screws below the door area, and it swings out.
Posted on Apr 23, 2009
How do I take the top off of the Maytag Atlantis dryer?
they are called baffles. and can only be accessed by getting to the outside of the drum. have to remove the body but u may have a bad baffle if the screw hole is busted up?
Sep 14, 2014 | Maytag Atlantis MDE7400AY Electric Dryer
How to fix a drum baffel screw on a maytag dryer
This is an easy fix. You need to pop the top of the dryer up to do so. Depending on the model you may have to take the front off (older models), or just locate the clips located on the left and right side under the lid, and with a flat head screw driver push them in and lift up. (newer models). After you have the top up, located the baffle thats broken and install. Keep in mind that if the baffle is loose its more than like the hole where the screw goes is stripped and the whole baffle should be changed.
Apr 25, 2012 | Maytag Dryers
Maytag neptune dryer one of the dividers the screws came loose how can I fix this without calling for service
You are probably referring to the drum baffles. The baffles securing screws can be retightened by raising the top which requires the removal of the front panel. Click on the link below for the detailed steps.
Retightening the Baffle Screws on Maytag Neptune Dryers
Jan 24, 2011 | Dryers
2 dryer bars
The bars are called BAFFLES P/N: 12002559
They are attached by 4 screws through the drum. You must pop the top to reinstall the baffles. Take one of the baffles to the hardware store and buy some good fitting screws. Then pop the top 660ff1d.jpgand use a screwdriver to reattach them. Fairly easy to fix. IF you have the old ones. Do dry tennis shoes in there. Oopz LOL
Apr 22, 2010 | Maytag SDG3606A Gas Dryer
Need to repair loose Baffle on Maytag Electric Dryer MDE7675AYW
On this model you will see 4 phillips screws in the recessed area when the door is open. 2 on each side. Take the 2 on the right out and then the 2 holding the hinges to the cabinet. Remove the door and then pull the front panel off by pulling toward you. Then you will see 2 screws holding the top down. 1 on each side near the top. Remove these and the top will lift back resting against the wall. From here you can get to the baffles. Good luck and thanks, Rick
Feb 28, 2010 | Dryers
Short baffle is loose
You can pop the top with a drywall putty knife there is two tabs on each side. This will allow you to access the drum. Then tighten the screws holding the baffle in place.
Jan 22, 2010 | Maytag Dryers
Inside of drum baffles coming loose on maytag neptune dryer
Hello.
Remove the door and the plastic pieces on the opposite side. Take the front panel off. There will be one metal bracket on each side holding the top panel down. Remove those brackets and lift the top. Turn the drum where the loose baffle is up top and tighten loose screws or replace missing ones.
Jul 18, 2009 | Dryers
HOW DO I TIGHTENED UP A LOOSE BAFFLE IN MY GAS DRYER
if you have the model with the lint filter on top,remove the 2 lint filter screws,pull the top toward you and up and your in-mike
Jun 01, 2009 | Kenmore Dryers
Loose and broken baffle
d
Take off 4 door screws 2 right 2 left remove door pull front forward them two screws 5/16 in front with two brackets that hold top down. thats it just rotate drum and tighten or replace fin . ten minutes tops is all it takes.
my fin broke the screw holes so i will try longer screws if not i will leave off and run with two.
Mar 07, 2009 | Maytag MDE7600AY Electric Dryer
Dryer Baffle Coming Loose
See if there are 2 screws located at the bottom front of dryer,unscrew anft panel up untilthe clips that are at the top disengage, disconnect door switch and any other connections , taking note of the connections.
W
Jan 05, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Maytag Neptune MDE5500AY Electric Dryer Logo
237 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
