Question about Maytag Dryers
It starts to squeak as soon as you turn it on and gets louder and loude. it willnot stop
I have a kenmore elite he4 dryer and I have pulled the bottom front panel off and can see the pulley but it hard to reach. What do i need to pull off to access the pulley?
Posted on Jun 21, 2009
    Novelist:
  • 108 Answers
There is a pulley that holds the belt tight (a tensioner) that usually is the culprit. Opening the dryer differs depending on which model you have. Most open by releasing the spring clips on the left and right sides of the front panel where the top meets the front. The top then tilts back, giving you access to the screws that hold the front on, so that it too can be removed. If these instructions don't quite work, post back with the model you have and ask for how to open it.
Once you have the front panel off you can get to the pulley (underneath everything).
It needs either a drop of oil on the axle, or if it is really worn, replacement. There are also two wheels at the back of the machine that the dryer drum rolls on that might be squeaking too.
Posted on Apr 15, 2009
My 2001 xterra started making a weird sound between 20 and 35 mph. It sounds like there is a leak in some pressure system.
Common Car Noises and Their Likely Causes Noise More Details Likely Cause Fixing It Clicking noise while turning Starts faint, gradually becomes more noticeable until very loud Failed outer CV joint (constant velocity joint) due to torn boot (most likely) or old age Replace either the whole axle assembly (recommended) or the outer CV joint Water pump noises Difficult to diagnose because of water pump's location Noise usually caused by damage to the bearings in failed water pump Only cure is replacing it. If possible do it at the same time as a timing belt replacement to cut down on labor costs Squeak or squeal from an engine belt Loud, high-pitched squeak or squeal Belts either need adjustment or replacing If belts only squeak when damp, they probably just need adjustment. If they squeak constantly, they probably need to be replaced Exhaust heat shield noises Rattle that you hear when car is idling Damaged heat shield Replace heat shield
Sep 28, 2016 | 2001 Nissan Xterra
Squeak near the serpentine belt
try a new belt they dry out after a while
Dec 01, 2013 | 2001 Buick Century
NEVER ENDING SQUEAK!!! Never ending loud squeking under the hood of my 2000 Blazer. Changed belts many times, sprayed with WD40, nothing makes it stop for more than a few minutes. Today, after driving,...
its a pulley, not the belt. most likely the idler pulley. the bearings inside are going up not a hard piece to replace and the pulley is around twenty dollars at advanced auto parts
Oct 18, 2012 | 2000 Chevrolet Blazer
Loud squeaking noise when you start up the dryer could it be a bearing dull squeak not high pitched a little bit of a grind sound
It does sound like a bearing or at least a lack of lubrication. But it could also be belt slippage if it only happens at the start. If it is the bearing it would be continuous and slowly get louder and louder.
Jun 18, 2011 | Whirlpool LER7646E Dryer
From the 1st day I picked up the car from the dealer, my new 2011 Toyota Avalon's wind shield wiper makes unwelcome loud squeeking noise when wind shield did not has enough water and wiping speed is in...
I would suggest putting new wiper blades on it or failing that have the screen cleaned as sometimes the cleaning stuff the valeters use can cause this annoying problem
Hope this helps
Steve
Mar 02, 2011 | 2011 Toyota Avalon
Starts loud getting louder and after about 10 or 15 minutes stops. will start again after cools down
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
Oct 18, 2010 | Crosley Dryers
My 1992 sl1 saturn was stolen and recovered when I got it back I got it back with a loud squeking noise coming from the serpentine belt area. Sounds like loud crickets and when I accelerate the squeak gets...
It sounds like an idler pully needs replaced. The bearings are going bad. It is not hard to do this, but more than likely that is what it is. You should also replace the belt.
Jun 23, 2009 | Saturn SL1 Cars & Trucks
Dryers Logo
109 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
