Question about HP Photosmart C6180 All-In-One InkJet Printer
HP C6180 - IMPROPER SHUTDOWN
MY PRINTER IS IN THE MIDDLE OF PRINTING AND THE PRINTER TURNS OFF AND THE PRINTER RESTARTS AND CONTINUES TO FINISH PRINTING. THEN I GET THIS IMPROPER SHUTDOWN ERROR ON THE PRINTER SCREEN. I HAVE THIS PRINTER SET UP WIRELESS WITH MY HP COMPUTER.
    Scholar:
  • 169 Answers
Not a big problem,try resetting the printer using the # and the number 6 buttons,holding them down and then inserting the power cord at the back of the printer.
In case it doesnt you can always contact a free online technical
support with an online live techbuddies technician at
http://tinyurl.com/m7ghqz
Posted on Jun 20, 2009
I had the same problem and found the solution on another thread for another HP printer..
unplug printer in back while ON.
hold the "Cancel" and the "OK" button and put the plug back in.
I had to turn it on and then it worked.
Posted on Sep 05, 2009
Hp photosmart c6180 all-in-one keeps turning on and off improper shutdown message
Apparently some defective components were used in the construction of the logic board (see photo). On my C6180 there were 3 failed capacitors (the green cylinders - the puffed top indicates failure) and a 4th from the same manufacturer (TEAPO - many unfavorable web references to this manufacturer). I purchased 3x 330uF 16V and 1x 680uF 10v rated to 105 degrees Celsius (total about 60cents). On the logic board, the capacitors I replaced are labeled C613, C614, C660 and C662. If you are not comfortable replacing the parts yourself (or don't have a soldering tool), you will have to find someone who will. The time to repair should be less than 30 min - I did it in 25 min with only a solder pen. This fix stopped my printer from power cycling and also fixed the ink system failures the printer was having. A similar fix may apply to other printers. 859f1d1.jpg
Aug 26, 2010 | HP Photosmart C6180 All-In-One InkJet...
Improper Shutdown Message
1. Disconnect the power cord from back of printer ( while printer is powered on )
2. wait for 10 seconds
3. hold and press the Power button and connect the Power Cord.
4. Release the Power button after 3 seconds
5. Follow the Instructions on the printer screen.
Later try to shutdown it, it should not give the message again
Jun 16, 2010 | HP Photosmart C6180 All-In-One InkJet...
It continues to post a message on the screen that says," Improper Shutdown, To avoid Damage, use the ON Button . . . ., but when I press the ON button it cycles through that screen, the startup screen and...
disconnect the power cable from the back of the printer
press and hold the power button for 30 seconds with the power cable unplugged
connect the printer directly to the wall outlet without any surge protector
disconnect the power module with the power cable
and try to power onn the printer
if the same issue continues
call HP and let them know the trouble shooting that we did and if the printer is inwarranty they will surely replace the printer for you ....................... thank you
HAMID
Oct 20, 2009 | HP Officejet Pro L7680 All-In-One Printer
Model c6180 printer gives improper shutdown error
The printer is not getting enough power. When you get this error message it means the printer is being turned off by unplugging the power cord. In this case it maybe that the printer is not getting enough power due to being in a surge protector or perhaps the power module is no longer holding power correctly.
First step is to disconnect printer from any power strip, surge protector, or extension cords and plug in so directly to the wall. If printer still will not stop looping cycle you may need to contact hp for a new power module.
Sep 25, 2009 | HP Photosmart C6180 All-In-One InkJet...
HP 6150 printer shutting on and off
Open the unit up, you'll probably find a capacitor inside that doesn't have a flat top like mine. Replace that one from your electronics supply store, usually very cheap.
Aug 25, 2009 | HP Photosmart C6180 All-In-One InkJet...
My HP C6180 is caught in a start up loop...
Hi there, " Unplug the printer cable from the computer. " Unistall the printer drivers from Device manager and also unistall the all the printer appications " restart the computer " try to download drivers from the website " after installing drivers and software it will ask you to connect the printer. " then you can connect the printer and and try to Print the test page.
Print cartridge
When the print cartridge contacts are dirty and the printer cannot detect/communicate with print cartridge.
Clean the contact points on the cartridges with a dry, lint-free cloth.
1. Open the top cover of the printer.
2. Remove the print cartridges.
3. Clean the copper-colored contact points on the cartridges with a damp, lint-free cloth. Use a dry, lint-free cloth to remove moisture from the contacts.
5. Insert the cartridges back into the printer.
6. Close the top cover.
7. Try printing again.
If you still cant communicate try with new cartridge .
Aug 19, 2009 | HP Photosmart C6180 All-In-One InkJet...
Impropershutdown
Press 6 and # while disconnecting the power cord (wait a little bit) and connecting it again. When the display is turned on again you can release the buttons.
After this reset you need to enter language, location and any wireless settings etc.
Aug 09, 2009 | HP Photosmart C6180 All-In-One InkJet...
Same problem, hp c6150 turns on and shuts down in infinite loop.
In visiting with HP Support Personnel, this issue is most likely caused by a faulty power source. I have the same issue with our C6150 and they recommended that I look at replacing power cable. I am currently trying to find a new power cable.
Jun 30, 2009 | HP Photosmart C6180 All-In-One InkJet...
HP C6180
unplug the printer and then plug it back in. turn it on and Hold the 6 and # button until the printer shuts off, this should do a hard reset
Apr 02, 2009 | HP Photosmart C6180 All-In-One InkJet...
HP Photosmart C6180 All-In-One InkJet Printer Logo
2,737 people viewed this question
Seeker5211
Seeker5211
