Question about Lands Phones
Not working pHone
Is there a specific way to wire wall jacks to use with the merlin legend r7 system? When we plug the phone direct into the module it works, when we plug into the jack we have nothing, please help
  • grab1 Apr 15, 2009
    Maybe you can help me figure this out, I can plug the phone directly into the module and it works, the wires from the building go to a punchdown block then into the module, on the other end is a cat 5 jack using 4 wires, the 4 middle pins i get nothing at the jack
  • Lands Phones Master
  • 2,460 Answers
The Legend system uses pins 543and 6 as a two pair. In a 568B configuration, those are the blue and green pairs. If your house cable is wired straight through, it should be easy to use 4 conductor cables to the phone and to the modules.
Carl
Posted on Apr 15, 2009
  • Carl Navarro
    Carl Navarro Apr 15, 2009
    Probably becuase they're not the same 4 pins. Remember, 8 pin wiring comes in many flavors; 568-A, 568-B and sometimes a DIY wiring for Ethernet. The phone uses 5436 with the tab down the White-Blue and Blue wire are 5&4 and in A the White Orange and Orange wires are in 3&6. Iin 568-B, the White Green and Green wires are in 3&6. At some point, someone probably translated the pairs. To the Legend, they used 4 conductor cable, wiring the blue pair to blue, but the orange pair has to go to green if the house cable is wired 568-B style.
    In structured cabling, we don't have to worry about that, because jacks are the same at both ends :-) It's usually the older stuff that gets mixed because of the use or reuse of the cable.
Need a manual for at&t BIS-34D
It doesn't work that way. The phone plugs into a cabinet, either a Merlin or Legend system. Which is yours?
Here's a start http://www.wedophones.com/Manuals/AT&T/Merlin%20Plus%20R2%20User%20Guide.pdf
Through the magic of stripping, you can modify the URL to get all AT&T manuals.
Carl
Nov 02, 2012 | Avaya AT&T Merlin BIS 34D Telephone
How many lines does the at&t bis-10 phone have?
It depends on how the control unit is programmed. The BIS 10 can't be used as a stand-alone phone (as in....you can't connect it directly to a telephone line).
The BIS 10 will work with the following systems:
AT&T Merlin 206
AT&T Merlin 410
AT&T Merlin 820
AT&T Merlin 820D2
AT&T Merlin 1030
AT&T Merlin 3070
AT&T Merlin II (with the proper modules installed)
AT&T Merlin Legend (with the proper modules installed)
Jan 27, 2011 | AT&T Merlin BIS 10 Phone
I have the MLX10DP model and was told that I need some sort of special box to make them work?
An MLX phone plugs into ports on a Legend or Magix phone system made by Avaya/Lucent. If you don't have either one of those, the phone is a paperweight.
Carl
Oct 20, 2010 | Lucent Merlin Legend MLX-10DP Phone
Will the AT&T Merlin BIS 10 Phone work on my home phone line? I work from home and love this phone, but need to know if it will work with a regular phone cord to the jack. Thanks!
No.
The BIS 10 and related telephone units need to be connected to one of the following AT&T Merlin telephone systems:
AT&T Merlin 206
AT&T Merlin 410
AT&T Merlin 820
AT&T Merlin 820D2
AT&T Merlin 1030
AT&T Merlin 3070
AT&T Merlin II (With the proper modules installed)
AT&T Merlin Legend (With the proper modules installed)
Oct 20, 2010 | AT&T Merlin BIS 10 Phone
Number of Rings Before Call Goes To Voicemail
From the system programming menu either in the pc programming tool or from the console phone enter into system programming, options,more, group coverage delay. set here from 1 ring to 9. Good luck.
If this was helpful please send me a rating.
Thanks Dan
Jul 29, 2009 | Lucent Legend MLX-28D Corded Phone
How do I recall a deleted message Merlin Legend MLX-20L Phone?
I assume you are also using a Merlin Voice Mail? Once the message has been deleted there is not way to retrieve it.
Mar 09, 2009 | Lucent Merlin Legend MLX-20L Phone
How to change extensions
If you can find the box that controls the phones you can unplug the phone there at the box and plug it into a different jack on the same controler box.
Jan 21, 2009 | Lucent Merlin Legend MLX-10D Phone
Phone wont dial out
Phone systems can be programmed to selectively block access to outside lines (by dialing 9 in this case). Have that particular employee undo his or her handiwork.
Jan 09, 2018 | Lucent Merlin Legend MLX-10D Phone
Lucent Merlin Legen MLX-20L Phone
I have the Merlin Legend system. To change to auto attendant is an "administrator" funtion. From the main console, go into the administrator mailbox-enter passwords-go to the #3, which is automated attendant-press 1 for Day menu-press 6 to modify the menu. The menu "prompt" is what you want to change-the recording. If you no longer have an administrator or someone that knows the administrator's mailbox number and passwords, you will probably have to call Avaya and pay them the $650/hr they now want for remote programming, OR calla alocal person with Merlin Legend programming expertise.
Good Luck!!
Mar 26, 2008 | Lucent Merlin Legend MLX-20L Phone
Lands Phones Logo
46 people viewed this question
Top Lands Phones Experts
David Burbee
David Burbee
Are you a Lands Phone Expert? Answer questions, earn points and help others
