Question about RCA L26HD31 26 in. LCD HDTV
After using the headphone jack on the side of the TV, I've removed my headphones and there is no sound. When I connect the headphones there IS sound coming from the headphones, but when there is no headphones no sound comes out at all.
  • 4 more comments
  • chris960 Apr 15, 2009
    No information in the Owners Manual.
  • chris960 Apr 16, 2009
    RCA L26HD31 HDTV, it's 26"
    function SubmitGForm()
    var ctlForm = document.forms.namedItem('cse-search-box');
    var mainForm = document.forms.namedItem('frmSearch');
    ctlForm['q'].value = mainForm['_s'].value;
    ctlForm.submit();
    ctlForm.submit();
    There's nothing like that on my TV's Menu, under sound there is no "internal speaker/headphone" setting
    As well in any other menu, or sub-menu.
    It's on stereo, I have no audio on any of my inputs, including my cable.
    Nothing is on mute, I still see no information on the internal speakers.
  • Anonymous Mar 14, 2014
    no sound from tv, no sound from headphone jack
  • RCA Master
  • 8,457 Answers
U can tries a little violent right at the earphone connection.
Sometime the soldier is crack,cold make no connection.
Use one hand hold the Bazel frame tight give it couple hits with ur
bottom hand of ur fist.
Posted on Aug 13, 2009
    Problem Solver:
  • 17 Answers
Try changing the sound output sometimes the tv will change to headphones only so you have so change it back to the tv speakers your owners manual should tell you how to do this
Posted on Apr 15, 2009
  • 4 more comments
  • gerald alarcon Apr 15, 2009
    Hi chris960
    I'm sorry this didn't help. Could you please tell me what kind of TV it
    is.
    Thanks
  • gerald alarcon Apr 16, 2009
    Hello again
    Ok there should be a sound menu on the tv where it lets you change the output of the sound. On the menu click where it says internal speakers then you should get sound. To get to this menu go to menu and then sound.
    Thanks again
    Sorry
    I now have the tvs manual. go to menu and go to sound. where it says analog tv sound make sure thats on stereo and make sure your sound isn't on mute in internal speaker mode
    If using DVI, S_VIDEO or Y, PB, PR, remember to also connect the device’s left and right audio output jacks to the TV’s L and R AUDIO INPUT jacks.
    If your audio source has only one jack or is a (mono) audio source, make sure you have plugged the
    connection into the L AUDIO INPUT jack on the TV.
    Ok
    Then your speakers might be blown or shorted out. youll have to have it checked by a profressoinal.
    I wish i could help you more but theres nothing else to resolve this because it looks like your speakers are blown or just went capoot sorry
    Thanks
I can't get sound through my headphones on my Bravia kdl-52xbr5 tv. First time I have tried to hook up the headphones which are sharper image wireless
I take it the headphones are charged up and known to be in good working order? Are you using the 3.5mm headphone jack on the side of the TV or the white and red RCA jacks labeled AUDIO OUT (VAR/FIX)? If using the headphone jack the TV should shut off the internal speakers and output to the headphones. If using the mentioned RCA jacks you need to go into the audio options settings and set to Audio System. Also under audio settings, Audio Out, you can pick Fixed or Variable. If you opt for Fixed you will use the headphones to adjust the volume. If you opt for Variable you can control the headphone volume and muting using your TV remote control. Just make sure you have the headphone volume turned up adequately.
Dec 16, 2016 | Sony KDL-52XBR5 52 in. LCD HDTV
Sylvania wireless headphones
Instructions
Set up the transmitter. Wireless headphones rely on a transmitter that sends audio via infrared or radio waves to your headset. Use the digital audio output (coaxial or optical), RCA outputs (red and white) or headphone jack on your TV to connect the transmitter. The connection will depend upon which outputs are available on your TV and/or the transmitter.
Use an RCA-to-headphone adapter. If you don't have a headphone jack on your TV and the transmitter includes only a headphone connection, connect an RCA-to-female headphone connector. This will allow you to plug the wireless transmitter into the female headphone end and then hook the RCA ends into your television's audio outputs. You may also need a 3.5 mm (mini jack)-to-1/4-inch adapter if the headphone plug on the transmitter doesn't match the television jack.
Read more : http://www.ehow.com/how_4883556_use-wireless-headphones-tv.html
Set the transmitter on top of, or next to, the television. For infrared transmitters, you'll need a direct path between the headphones and the transmitter. Placing the transmitter on or near the TV will allow you to take advantage of the clear path you already have.
Plug in the transmitter and turn it on. Charge the headphones if necessary.
5
Turn on the headphones. Adjust the volume and settings and you're ready to watch TV.
good luck
Nov 14, 2013 | Sylvania SYL-WH930GB Wireless Headphones
Problems with headphone jack
Replace the headphone socket of the TV. It has contact fault.
Jul 12, 2012 | Vizio M260VA 26 in. HD-Ready LCD TV
Cant get sound from laptop to tv
Just to verify...you've made sure that your headphones jack will play audio in lets say, some headphones, or a set of computer speakers?
However, your T.V. may not recognize audio when using VGA. I say this because if you look at the hook-ups on your T.V., you notice that most sections contain audio and video together, not seperate. If the port is available on your computer, trying using HDMI, the single cord for HDMI carries both sound and video. One last thing you can try with your current set up is find a set of the red and white rca hookups that are independent of any other grouping, in other words excluding the yellow video or any other connections. If you're T.V. wont play the sound in that, then either your headphones jack is messed up or the T.V. just wont recognize it while using VGA.
Nov 21, 2011 | Computers & Internet
I need to connect a surround sytem to my tv but cannot find an audio out on it
Depending on the TV you have and the surround sound system you can use the following:
An optical out cable.
Headphone jack to headphone jack (a cable with a 2.5mm headphone jack on both ends) you then plug this into the headphone jack in the TV and the other end into the audio in jack in your surround sound system.
You can also use a standard scart lead to plug into your TV and surround sound system.
May 03, 2011 | Televison & Video
Sound
Except for the Headphone jack (mini-jack) and the coax audio, all of the audio jacks are audio IN. Which jack do you have your speakers connected to? The headphone jack is on the side next to the coax connection (ANT) and the coax audio out is at the bottom of that set of side jacks. The headphone mode should automatically cut the TV speakers. The coax audio out is set up by pressing Menu and then using the down arrow to highlight Audio. Then press the right arrow button to enter the submenu. Press the up or down arrow to reach SPDIF. Then you use the left and right menus to select PCM, Digital Dolby or OFF.
I hope this helps.
Jul 10, 2010 | Element ELC-HS321 32 in. LCD TV
If I hook up a set of headphones to the slot on the side of the TV the sound goes off and you can only hear sound through the headphones, no one else in the room can hear the TV. Is there a way to hook...
The headphone jack on the TV has switch built-in to kill the TV speakers when headphne jack is used, you need to use powered PC speakers with headphone jack and connect this PC speakers to the Audio line out of the TV set (RED and WHITE RCA audio line out). Basically the powered PC speakers are being used a headphone driver. Or you can get one of those wirless headphone system instead.
Jun 27, 2010 | Televison & Video
To play laptop thru samsung tv I am attempting to play laptop movie thru tv. I have tried the rca y cable with 3.5 mm plug from headphones of laptop to red and white audio in on the samsung tv., no sound....
So you are connecting the laptop to the TV using VGA port of the TV, right? To get sound in the PC input mode, you need to use the PC audio input jack (green jack, mini 3.5mm jack) not the RED and White RCA audio input, they are for Composite Video AV inputs. That is how I have my laptop and TV setup to watch Netflix.
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
Jun 16, 2010 | Samsung LN52A850 52 in. LCD HDTV
Headphones to tv have no sound
If you have connected your headphones directly to a headphone jack on your TV, it should work - check whether there is a separate headphone volume control.
If you have connected your headphones to the red/white "variable output" or "Line out" jacks on the back of your TV, these do not provide a headphone-level signal.
Please provide more detail on exactly how your headphones are connected to your TV, what make/model TV you have, and the connections between the two.
Apr 06, 2008 | Audio Players & Recorders
HEADPHONE SPEAKER WIRING
try using colored wire with the copper....colors act as sound carriers and copper acts as power only connect the copper one with ONly 1 color tho .......just try having everything on and just touching the wires together before sodering
Apr 05, 2008 | Hitachi DZ-MV730A DVD Camcorder
RCA L26HD31 26 in. LCD HDTV Logo
402 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
